 Flashing red light when switching on the XBOX360, And no activities on screen/TV
TSXrossfire
post Apr 21 2007, 09:41 AM, updated 19y ago
Ten Hut!
Elite
Hope this is the right place for me to ask and seek help.
What happen is whenever I switch on the XBOX360, instead of booting up normally, nothing happens and the indicator light on the console flashes red.
Anyone knows what's wrong with the console?
ventriloquist
post Apr 21 2007, 09:46 AM
3 red light or 4 light?
US/JP or Asian console?
use transformer or not?
if 4 light then check ur cable, plug out and plug in again.
my problem is either my console is out or something wrong with my power adapter. flashing red light when connect to transformer.
TSXrossfire
post Apr 21 2007, 09:50 AM
Ten Hut!
Elite
Flashing 3 red lights.
It's a Korea machine, i suppose it's Asian console
Transformer? Nope, just the power adaptor.
ventriloquist
post Apr 21 2007, 09:54 AM
QUOTE(Xrossfire @ Apr 21 2007, 09:50 AM)
Oh your god... i think try asking our frenz here at 3 light of death thread, u might got really serious problem over there.
here : 3ROD Thread
This post has been edited by ventriloquist: Apr 21 2007, 09:55 AM
judge-the
-Judge-Jury-Executioner-
power indicator got 4 lights... according to your post, you said it's 3 red lights. does the upper corner red or nothing?
TSXrossfire
post Apr 21 2007, 09:56 AM
Ten Hut!
Elite
If you're looking at the console standing vertically, the side with no light is upper right corner
judge-the
post Apr 21 2007, 09:59 AM
QUOTE(Xrossfire @ Apr 21 2007, 09:56 AM)
you just got hit by the deadly 3ROD... sorry telling you this. please unplug everything to the console and then replug back everything, just give it a try.
* at the same time, you need to check on the warranty issue now. if can send warranty then get a replacement set. if no warranty then you need to get professional help from bro tot31 or metalgrindsolid for the xclamp fix.
cylon
Isn't it obvious!
Poll: Have you experience the Xbox360 3 Ring of Lights?
3 Blinking Red Lights Of Death..Is it the END?
There's hope though...LIVE after Death....No More 3ROD Worries....
xxboxx
post Apr 21 2007, 10:01 AM
The mind is for having ideas, not holding them
TSXrossfire
Ten Hut!
Elite
oh damn, what's 3ROD? Sorry I'm not up-to-date on XBOX360 scene
Very serious issue, eh?
Yeah, will ask on warranty from seller.
judge-the
post Apr 21 2007, 10:08 AM
QUOTE(Xrossfire @ Apr 21 2007, 10:01 AM)
3ROD in other words meaning hardware failure and also means your 360 is dead gone for good.
i was a 3ROD victim too. my 14 months japanese 360 died but lucky 2 forumers revived it last week using hot gun and xclamp fix. so far so good and still working.
Eisenmeteor
post Apr 21 2007, 10:28 AM
Night Ghost
QUOTE(Xrossfire @ Apr 21 2007, 09:41 AM)
It happens evrytime kah?
alkt
post Apr 21 2007, 10:29 AM
^_^
VIP
beetle_larvae
post Apr 21 2007, 10:39 AM
I got same 3rod problem but my adapter is the cause...
you might wanna head over here...
http://www.llamma.com/xbox360/repair/Xbox-...error-codes.htm
and see first what the problem.
Microsuck_360
post Apr 21 2007, 10:46 AM
QUOTE(ventriloquist @ Apr 21 2007, 09:46 AM)
ventriloquist
post Apr 21 2007, 10:53 AM
QUOTE(Microsuck_360 @ Apr 21 2007, 10:46 AM)
hah, today i go check it out... coz since i pick up my console, i tried to turn it on but no respond at all. by mean of red light, its not flashing at console but my power adapter... so not sure either my adapter is broken or my console is broken in first place...
well spongebob... u wan to follow me n reen to go to ss2 or cineleisure 2pm today? forgot to ajak u sekali...
Microsuck_360
post Apr 21 2007, 10:59 AM
QUOTE(ventriloquist @ Apr 21 2007, 10:53 AM)
limlim78
post Apr 21 2007, 12:24 PM
Do you mean the three red light blinking?
I facing this problem when me AV cable no connet correctly or loose, after i fix the AV cable , it can be on again. Can i know the 3rod mean the 3 light on permanantly or it blinking?
Microsuck_360
post Apr 21 2007, 12:33 PM
QUOTE(limlim78 @ Apr 21 2007, 12:24 PM)
SUSleenaz
post Apr 21 2007, 01:37 PM
wehh ventri
sudah dapat kaaa 360??
so takder laa berebeut dgn demonic lagi??
ventriloquist
post Apr 21 2007, 01:52 PM
QUOTE(leenaz @ Apr 21 2007, 01:37 PM)
wehh ventri
dah dapat tapi tak boleh on tu yang aku bengang sekrg
SUSleenaz
post Apr 21 2007, 02:17 PM
bawak jumpa rossi laa
tanya apa prob
aku punya dah dapat balik
dalam masa 2-3 hari nie kalau oke aku akan live balik
Eisenmeteor
post Apr 21 2007, 08:25 PM
Night Ghost
Juz now when playing Virtua Tennis 3,the console suddenly hang...Another 3ROD symptom kah?
judge-the
post Apr 21 2007, 08:49 PM
QUOTE(Eisenmeteor @ Apr 21 2007, 08:25 PM)
dont think too much... just sits back and enjoy. if really got that 3rod then only work out on the solution unless your 360 no longer under warranty.
aegis`-
post Apr 22 2007, 09:11 AM
sometime our normal console hangs but very rare la
but if hang like 2-3 times in an hour or day thats a symptom from what i see
Xrated
post Apr 22 2007, 10:11 AM
sometimes 3rods happens cause the power adaptor itself...not because of the console...
it happen to my friend xbox360...the main plug at his house got some probs...so when he turn on his 360 got the 3ROD because the adaptor cant receive enough power to turn on the Xbox360...
when he called the electricians to came over and repair the main plung and etc....after that he just give a try to turn on and play the 360....walla 100% okey and seems no problem until now...
3ROD flashing sometimes not because of the console....general hardware failure...can be the adaptor itself...
Added on April 22, 2007, 10:18 amEisenmeteor ,
Your virtua tennis the original xbox360 games or the pirated once?
This post has been edited by Xrated: Apr 22 2007, 10:18 AM
Eisenmeteor
post Apr 22 2007, 10:30 AM
Night Ghost
QUOTE
Eisenmeteor ,
Mine's original..The Console Original..
Xrated
post Apr 22 2007, 10:49 AM
QUOTE(Eisenmeteor @ Apr 22 2007, 10:30 AM)
did ur others xbox360 game have the same probs ( hang ) when u play it?
if not i think may be the virtua tennis 3 CD`s...
Eisenmeteor
post Apr 22 2007, 11:03 AM
Night Ghost
I think there's once whn i played Dead Or Alive 4..But kinda forgot bout dat...
TSXrossfire
post Apr 23 2007, 04:16 PM
Ten Hut!
Elite
QUOTE(alkt @ Apr 21 2007, 10:29 AM)
Well, regarding the 3ROD...no doubt I've been 3ROD'ed...sad case.
Anyway, working on alternative solution to get it fix.
Thanks guys for all the tips and so on. Probably will look for Sifoos to fix it.
0.0188sec    0.50    5 queries    GZIP Disabled
Time is now: 25th December 2025 - 02:25 AM
