 New to pedals.gettin stompboxes instead of multis?, advice pls..
TSdrew1.0beta
post Nov 11 2007, 05:13 PM, updated 19y ago
hi guys..
at 1st i wanted to get a multi effects pedal...because some said that it'll be better to get a multi effects as a 1st pedal, so i'll know what effects i need..
but i went to a gig last 2 days..and i saw few of the guitarist with just few stompboxes manage to get great sound from it..(it actually sound better than multi effects rite?)
i was looking at the ax3000g and the zoom g7..
and after that gig..i decided to get stompboxes instead..
but i'm worried it will be difficult to operate single stompboxes...as i thought that multieffects will be easier..because there's memory to save the settings..and also patches..and multis can change lotsa effects with just a stomp,,while stompboxes, i need to bend down and turn the knob to change the sound..
due to financial prob..i dont plan to change my amp as during performance, mostly i get different amps provided by the organisers..
currently using the MG30dfx ( i know it have a bad reputation)..
can i get good sounds from it? must i use the clean channel? or od channel when operating the stompboxes?
last question, i play from pop-punk>alternative>classic rock>metalcore>emo, and my budget its around RM800..what is the 1st few pedals that i need to suit my style of playing?
if you're me would you go for the multi of stomp-ies? lol
what about stompbox for distortion and multi effects for delay,reverb etc?
thanks a bunch!
This post has been edited by drew1.0beta: Nov 11 2007, 05:17 PM
SweetTooth
post Nov 11 2007, 05:32 PM
i'd suggest a metalzone/moen mo-vm for killer distortion, other pedals are up to you really, see what kind of sound you wanna get. common pedals used are usually distortion, chorus, flanger.. i don't think many people use reverb pedals cuz they're pretty expensive so they use it from their amps/multi fx.
for me the most important is distortion, don't need anything else tongue.gif
the metalzone/violent metal would be great for what you play cuz they are very versatile and can get you many tones thumbup.gif
if you want, you could even get an equalizer pedal or an acoustic simulator biggrin.gif
skindred
post Nov 11 2007, 05:39 PM
Honestly, it's individual preference..
If you think the stompboxes give you good sound then go for it lah.. If you malas wanna buy so many stompboxes, get multifx ..
They say analogue pedals give better warmer tone etc .. But I never regretted using my multifx pedal, loving it.. Had bad experiences with stompboxes before. Hahaa.. That's for me.
Cause in the end, which ever one u choose.. you'll end up getting used to it. And u'll learn to love what you get used to.
If not.... ..... ....
You'll switch to the other alternative la, what else??!
gapnap
post Nov 11 2007, 05:40 PM
this
BOSS ML-2
then this
BOSS NF-1 MADE IN JAPAN
This post has been edited by gapnap: Nov 11 2007, 05:41 PM
led_zep_freak
post Nov 11 2007, 08:08 PM
TS, get whichever suits you better. biggrin.gif If you're on a tight budget, go for the multi-fx route. Safer and you're guaranteed to get a good tone out of the box (Unless you buy one of those old, small Zoom ones tongue.gif )
FreakOnLeash
post Nov 11 2007, 08:53 PM
gapnap
post Nov 11 2007, 09:21 PM
QUOTE(led_zep_freak @ Nov 11 2007, 08:08 PM)
just suggesting some pedals , with pictures so that he can identify which one
anyway , BOSS ML-2 and NF-1 ,is quite a good suggestion right ? emo now or days use fkin lots of gain biggrin.gif
blacktrix
post Nov 11 2007, 09:39 PM
Scott Pilgrim Vs The World!
VIP
Hmmmmm..... Honestly, in his situation, a Multi-FX pedal with Amp modelling would be a better choice, mainly due to the not as expected Marshall distortion from the MG30.
The Tonelab LE would be a good choice, as it has a decent amount of effects, but great amp modelling. If you're looking for something with more effects to play with but with decent amp modelling, then maybe you can try out the Line6 Floor POD (or the POD XT Live if you have the budget).
Yes, effects can help, but if you have a crappy amp to start with, it needs alot of pedals to coax out a good tone....... easiest solution is to buy something with an amp modeller.
Even if you're using the house's amps, you'll never know what quality you're going to get, which is why alot of them use multi-fx units anyway (unless you're a MAJOR headliner where they will provide you with top of the line Marshalls or Mesa)..... Heck, even the guitarist from Deja Voodoo Spells uses a POD during the clinics I've seen him in. tongue.gif
That's just my 2 cents btw..... the decision is entirely up to you. Yes, individual pedals COULD sound better, but you'll be shelling out quite a bit if you're an FX junkie. Even that, it all depends on the amp. For me? I use a combination of both. Use my Tonelab LE mostly for the amp modelling and chorus effects, while depending on my MXR Overdrive and Wah + my Digitech Whammy as my effects.
And don't worry Gapnap. I see nothing wrong with your posts AT THE MOMENT tongue.gif
FreakOnLeash
post Nov 11 2007, 11:20 PM
Eh Blacktrix I thought you usin Tonelab SE ? And where can I find the Zakk Wah you using now.. Hoping to get one while year end sales tongue.gif And how much is it around ?
enteryourusername
post Nov 11 2007, 11:27 PM
entermyusername
he always got confused with SE n LE..... -.-
supercolossal
post Nov 11 2007, 11:34 PM
Just think if you need that many effect combinations for the type of music(s) you play. I believe that most guitarist would not need more than one or two distortion pedals (overdrive included), a delay, chorus, and maybe a wah. At least that works for me.
soraxroxas
post Nov 11 2007, 11:44 PM
QUOTE(gapnap @ Nov 11 2007, 05:40 PM)
this
BOSS ML-2
then this
yup , i second that
blacktrix
post Nov 11 2007, 11:58 PM
VIP
Wait wait..... I AM using the SE......
I meant for him to get the LE
And the Wylde Wah can be bought at Bentley's or Do Re Mi music.
But the Wylde Wah is an acquired taste..... It's a very good Metal wah, but don't expect Funk sounds coming for that. If you have a little more cash, go for the Dimebag's Crybaby from hell as it's much more versatile. I bought my Wylde Wah because...... well...... duh. Zakk fan here tongue.gif
This post has been edited by blacktrix: Nov 12 2007, 12:00 AM
led_zep_freak
QUOTE(gapnap @ Nov 11 2007, 09:21 PM)
QUOTE(FreakOnLeash @ Nov 11 2007, 11:20 PM)
The SE is expensive, naturally one would recommend the LE which is more practical in this case.
Though, the Tonelab series isn't really flexible in terms programming your own sound. For example, you can't use the wah with an OD pedal or any 2 pedals listed on the pedals section at a time. Kinda limits what you could get from the unit. I would recommend Line 6's XTL or GT series instead. If you're more concerned about the amp modeling and less on effects, I guess you could put the Tonelab into your list too. smile.gif
Added on November 12, 2007, 12:00 am
QUOTE(blacktrix @ Nov 11 2007, 11:58 PM)
Crap. I'm using the LE.... Live Edition.
You're using the SE lar... Stage Edition. The SE came out before the LE (Light Edition?) and is the one in blue & comes with twin pedals.
This post has been edited by led_zep_freak: Nov 12 2007, 12:00 AM
blacktrix
post Nov 12 2007, 12:02 AM
VIP
I suck at my gear, don't I?
Well, end of the year..... it's simpler.
Guitar -> Wah -> Overdrive -> Spider Valve (FX Loop the Whammy).
I might be tempted to get a A/B/Y pedal and hook up my Tonelab SE, GCB-95 Wah and my Laney to get 2 sounds........
Mmmmmmmmmmmm....... BRUTAL
soraxroxas
post Nov 12 2007, 12:14 AM
haha rclxms.gif u guys use so much pedals >..<
I use 1 BOSS MT-2 enough liao lo:P
i dont plan to buy other pedal(maybe overdrive, but the amplifier got liao)
so aiyo, buy multi-fix,also no use all...
but thats my opinion, im only a stupiak teenager
liew90kw
post Nov 12 2007, 12:15 AM
i partially agree with blacktrix...
Unless you know you're gonna have good amps to do justice to your little stompboxes, get a multiFX and use the amp modelings inside.
Personally, i think stompboxes give a better overall sound quality compared to multiFX, but i still bought a multiFX first, mainly becasue of the amps issue.
FreakOnLeash
post Nov 12 2007, 12:22 AM
That's what I talking about.. I dont want a Funky Wah.. biggrin.gif I need a Metal Wah.. Jahat jahat drool.gif How much are them around now ? Zakk and Dime Wah..
freakfingers12
post Nov 12 2007, 05:49 PM
Honor thy father
Metal Muff+Crybaby 535Q+Some sorta Delay
Or even better,get the 5150
Sorry,I didn't see.Based on your budget I guess you could save up a little more for a GT8
This post has been edited by freakfingers12: Nov 12 2007, 05:50 PM
hanhanhan
post Nov 12 2007, 06:36 PM
(͡ ͡° ͜ つ ͡͡°)
what is 'emo' genre? like.. what bands/songs
TSdrew1.0beta
post Nov 13 2007, 12:09 AM
thanks for the replies guys..
oh..guess i'll be goin for the multi instead due to my amp..
the tonelab le is nice..but its sooo expensive..not sure bout the price here..but musicianfriend.com is selling for 399$ us? defienelty over my budget..hehe
what u guys think about the korg ax3000g?
tot i could get a different pedal since my fren has bought the ax3000g..lol
planned to get the g7 but loose hope after i found out few common prob on the Gseries..(the footswitches could fail, altho the pedal sound amazing)
hanhanhan : emo? bands like - hawthorne heights, taking back sunday,panic at the disco,My Chem Romance..etc
This post has been edited by drew1.0beta: Nov 13 2007, 12:13 AM
oxalato
post Nov 13 2007, 12:38 PM
im considering to get my FIRST multifx and music store from ipoh quote me rm595 for g2.1u WITHOUT adaptor. hows the deal?
i think its quite normal for shops here to jack up the price here. i seldom travel to KL so it might be quite a hassle if i were to take a trip down there just to get it from the music shop. BUT if its a whole lot cheaper than of course its worth it biggrin.gif
another question, do all multiFXs come with amp modelings? amp modeling basically means simulating tones from big names amps like Marshall right? i asked the dude working there and he said g2.1u does not have amp modeling. which makes me very confused. need someone to enlighten me.
last question, how does g2.1u stand compared to a floor pod? which has more value for money?
thanks a bunch guys !
led_zep_freak
post Nov 13 2007, 12:53 PM
This?
http://www.zoom.co.jp/english/products/g21u/
"16 Classic Amp & Stomp Box Models"
Yes, there's amp modeling and it does mean simulating tones from bigger amps. biggrin.gif
If possible, give the Floor Pod and the Digitech RP series a try. biggrin.gif The Digitech has gotten some good reviews, not sure if it's available at your place though, but Bentley carries Digitech. smile.gif
blacktrix
post Nov 13 2007, 01:05 PM
VIP
Again, I don't like Zoom because
a) They don't last long....... both my Zooms suffers from broken pedal syndrom.
and
b) They sound like microchips.
Like Led_Zep, I too would recommend the Floor Pod or the Digitech RP.... but they ARE more expensive then the Zoom.
If you're on a tighter budget, try out the Korg Ax1500..... it lasts longer and sounds better then Zoom IMO.
oxalato
post Nov 13 2007, 02:14 PM
QUOTE(blacktrix @ Nov 13 2007, 01:05 PM)
and
thanks for the quick reply blacktrix and ledzep
will check out the digitech RP and floorpod. but not sure whether its available at my place tongue.gif
quarantined
post Nov 13 2007, 07:16 PM
Create Not Imitate
Have anyone tried the Rocktron Utopia?
blacktrix
post Nov 13 2007, 08:14 PM
VIP
Hilary Duff? as your avatar? BANNNNNNED!!
And um...... no..... Haven't tried the Rocktron. quite hard to find Rocktron actually.
FreakOnLeash
post Nov 13 2007, 09:41 PM
I used to own a Zoom G2.1U.. But bad it sounds too digital for me.. And the pedal got the 'ngeh ngeh ngeh' sound.. I sold it by the way thumbup.gif
quarantined
post Nov 13 2007, 09:45 PM
Create Not Imitate
biggrin.gif I know you totally crazy for her but man you gotta share some love yo! haha
Anyway does anyone knows where can I check out the Rocktron pedals here? Also is AX1500g still available for sale? Sorry for borrowing this thread but I thought maybe you should check out these two multi-efx too.
This post has been edited by quarantined: Nov 13 2007, 09:53 PM
TSdrew1.0beta
post Nov 13 2007, 10:09 PM
quarantined : haha no prob..
the ax1500g, as i know its not in production anymore..but some shops in pg is still selling, got stock i guess..around 600plus if im not wrong..
i've seen the digitech RPs..i feel its not that durable..footswitches are fully plastic..and it doesnt look that good too..ehhe..but not sure bout the sound..
btw, any review for the floorpod? how is it againts the ax3000? it's not that tweakable i guess..
This post has been edited by drew1.0beta: Nov 13 2007, 10:11 PM
NZX
post Nov 15 2007, 08:31 PM
for beginner multi fx good for experimenting with, but good wan also mahal, cheap wan ppl say sounds bad. haha.
I think multi-fx good for live gigs, easy to set pads n save, gig time just pijak pijak change on the fly.
stomp box definately better than multi-fx, ask any sound engineer, especially those dat do recording in studios. I have never come across one who preffers multi over stomps. But for live gig, if u need diff diff fx then hard to adjust one by one especially when diff songs are diff tempo for delay pedal u need adjust the RATE. Dats y pro artists have many delay pedals, each set for one song. But they r rich or sponsored.
So wut i said doesnt solve any problem. hahaha. CHeers!!!
blacktrix
post Nov 15 2007, 08:52 PM
VIP
Actually, The POD XT has been used by many engineers in the studio......
enteryourusername
post Nov 15 2007, 09:36 PM
entermyusername
mind some examples?
blacktrix
post Nov 15 2007, 09:41 PM
VIP
Skwisgaar Skwisgelf uses it.
And he's the fastest guitar player in the world.
So if he uses it, it's the equivalent of the entire world uses it.
You can find the rest of the slow world here:
http://line6.com/podxtpro/artists.html
This post has been edited by blacktrix: Nov 15 2007, 09:43 PM
Snipe_EX`
post Nov 15 2007, 09:47 PM
my ax3000g broken allready cry.gif cry.gif maybe save money for gt8 lor
This post has been edited by Snipe_EX`: Nov 15 2007, 09:48 PM
SweetTooth
post Nov 15 2007, 10:41 PM
QUOTE(blacktrix @ Nov 15 2007, 09:41 PM)
it still amazes me that brandon small is a stand up comedian doh.gif laugh.gif
hanhanhan
post Nov 15 2007, 10:48 PM
(͡ ͡° ͜ つ ͡͡°)
how much is a boss gt-8?
SweetTooth
post Nov 15 2007, 11:06 PM
about rm1.6k iirc
sean392
post Nov 15 2007, 11:23 PM
Hirano Aya-Tard
QUOTE(Snipe_EX` @ Nov 15 2007, 09:47 PM)
what did you do to it shocking.gif ><
liew90kw
post Nov 16 2007, 12:15 AM
LOL Skwisgaar Skwisgelf.
crazychris
post Nov 16 2007, 12:10 PM
Bass!!!
lookin for single pedals now
0.0240sec    0.56    5 queries    GZIP Disabled
Time is now: 21st December 2025 - 05:08 PM
