 MSI Laptop sudden shutdown when running games
TSSweetPuff
post Nov 14 2017, 11:30 AM, updated 8y ago
Hi Sifus.
My MSI GT72 2QD have an issue of sudden full shutdown whenever I run games. It's like fully no power at all. I have to switch off power from the wall socket and turn it back on, in order to be able to restart the laptop.
Some details:
1. the shutdown can happen anytime between 2mins to 5mins of running games, with or without being plugged to power.
2. Temp for GPU when this happens is below 65C. CPU is about 50C.
3. If I'm not running games, the laptop behaves normally.
4. I tried using heavenmark, which also causes the shutdown issue.
I have attached the MSI Afterburner log. Not sure if you can point me to some clues for a fix. The laptop is out of warranty, and MSI official support requires about 2-3 days to diagnose and up to 14 days to order parts, which is a bummer. Hope you can point me to the right direction.
Attached Image Attached Image
greg25
post Nov 14 2017, 11:43 AM
Seems like a GPU hardware issue. Best resolution is to send it in for service.
omg7788
post Nov 14 2017, 11:48 AM
Kampung Style Information Technology
I would say most likely overheating issue or power adapter faulty means it can't draw high power from the wall to supply to your laptop when you are running high load. Take to laptop service shop for further checking.
xiaoc.wu
post Nov 14 2017, 11:50 AM
Sounds weird, I would suggest try unstall/upgrade the driver for your graphic card, if it is not the overheating problem.
crumpetss
post Nov 14 2017, 12:13 PM
dummie
QUOTE(omg7788 @ Nov 14 2017, 11:48 AM)
cpu and gpu is not overheating, i would say its the vrm overheating triggering the thermal protection measures
crumpetss
dummie
also ts does the laptop just kaput and black screen? or got blue screen?
TSSweetPuff
post Nov 14 2017, 12:39 PM
QUOTE(crumpetss @ Nov 14 2017, 12:13 PM)
Total power off. Can't start unless I unplug the power cord from the wall socket and then plug it back in.
Thanks a lot for the quick replies, guys.
omg7788
post Nov 14 2017, 12:50 PM
Yeah agree on that, so i would say assume it is overheating.
crumpetss
post Nov 14 2017, 12:54 PM
dummie
QUOTE(SweetPuff @ Nov 14 2017, 12:39 PM)
seem like issue related to power delivery, i advise you take back to msi official store
crumpetss
post Nov 14 2017, 12:55 PM
dummie
or if you want to do more digging you could install hwmonitor, run some stress tests then check the voltage/ wattage figures, and possibly the vrm temps
tsg_7
post Nov 14 2017, 12:56 PM
Probably temperature too high? Vendalition need improve probably.
TSSweetPuff
post Nov 14 2017, 02:05 PM
If it's VRM issue, does that mean changing the graphics card will help?
e_mc_square
post Nov 14 2017, 04:28 PM
Is mostly overheat.
you try to monitor the temperature when you running 3D program like games, benchmark program.
If it is power brick issue like above said. you will see this behavior which is when you run the 3D program it can't perform up to the GPU standard. That is due to the GPU need to draw more current from the power brick but the power brick didn't deliver enough. And then after a while the power brick will failure due to the high current draw.
destee88
post Nov 15 2017, 03:33 PM
QUOTE(SweetPuff @ Nov 14 2017, 11:30 AM)
Hi Sifus.
Some details:
pm me if want sell it off tq
woxife
post Nov 16 2017, 05:55 PM
Use latest Help Desk to export the system info and post the text information in here.
I also would suggest checking those with AC mode. Because the problem might cause by your old battery which couldn’t provide enough power with heavy loading task.
TSSweetPuff
post Nov 16 2017, 06:04 PM
QUOTE(woxife @ Nov 16 2017, 05:55 PM)
Thanks for helping. Here are the details:
System Information
Serial Number: 9S7178131672ZEB000022
Product Name: GT72 2QD
OS: Microsoft Windows 10 Home Single Language 64-bit Ver.1709(OS build 16299.15.amd64fre.rs3_release.170928-1534)
Windows Product Key: 6F4BT
HDI Build: non-OEM
BIOS Version: E1781IMS.110
BIOS Release Date: 2015/07/23
EC Version: 1781EMS1 Ver5.12, 05/06/2015
CPU: Intel® Core™ i7-4720HQ CPU @ 2.60GHz
Memory: 8192 MB @ 800 MHz
- 8192 MB, DDR3-1600, Kingston MSI16D3LS1KBG/8G
Graphics: NVIDIA GeForce GTX 970M, 3072 MB
VBIOS Version: 84.04.22.00.08,3145728
Drive: HDD, HGST HTS721010A9E630, 931.51 GB
Network: Killer E2200 Gigabit Ethernet Controller
Network: Killer Wireless-n/a/ac 1525 Wireless Network Adapter
Network: Bluetooth Device (Personal Area Network)
SHIFT mode: None
Power Plan: Power Scheme GUID: 381b4222-f694-41f0-9685-ff5bb260df2e (Balanced)
Programs and Features
Synaptics Pointing Device Driver , 19.3.4.184 ,
Nahimic 2 Audio Driver , 2.3.2001 , 20171113
NVIDIA Control Panel 388.13 , 388.13 , 20171113
NVIDIA GeForce Experience 3.10.0.95 , 3.10.0.95 , 20171113
NVIDIA Update 29.1.0.0 , 29.1.0.0 , 20171113
NVIDIA SHIELD Streaming , 7.1.0402 , 20171113
NVIDIA Install Application , 2.1002.259.2253 , 20171113
NVIDIA Backend , 29.1.0.0 , 20171113
NVIDIA Container , 1.8 , 20171113
NVIDIA TelemetryApi helper for NvContainer , 1.8 , 20171113
NVIDIA LocalSystem Container , 1.8 , 20171113
NVIDIA Message Bus for NvContainer , 1.8 , 20171113
NVIDIA NetworkService Container , 1.8 , 20171113
NVIDIA Session Container , 1.8 , 20171113
NVIDIA User Container , 1.8 , 20171113
NVIDIA Display Container , 1.2 , 20171113
NVIDIA Display Container LS , 1.2 , 20171113
NVIDIA Display Watchdog Plugin , 1.2 , 20171113
NVIDIA Display Session Container , 1.2 , 20171113
NVIDIA NodeJS , 3.10.0.95 , 20171113
NVIDIA Watchdog Plugin for NvContainer , 1.8 , 20171113
NVIDIA Telemetry Client , 7.8.8.0 , 20171113
NVIDIA Telemetry Container , 7.8.8.0 , 20171113
NVIDIA Virtual Host Controller , 2.02.0.5 , 20171113
NVIDIA ShadowPlay 3.10.0.95 , 3.10.0.95 , 20171113
NVIDIA SHIELD Wireless Controller Driver , 3.10.0.95 , 20171113
NVIDIA Update Core , 29.1.0.0 , 20171113
NVIDIA Virtual Audio 4.02.2 , 4.02.2 , 20171113
MSI Afterburner 4.2.0 , 4.2.0 ,
Help Desk , 1.0.1707.2501 , 20171114
Dragon Gaming Center , 2.0.1701.0601 , 20171113
Realtek High Definition Audio Driver , 6.0.1.8117 ,
Microsoft OneDrive , 17.3.7076.1026 ,
CPUID HWMonitor 1.33 , 1.33 , 20171113
Microsoft Office 365 - en-us , 16.0.8625.2121 ,
ProductDaemonSetup Install , 2.3.2001 , 20171113
Microsoft Visual C++ 2010 x64 Redistributable - 10.0.40219 , 10.0.40219 , 20171116
AudioLaunchpad Install Configurator , 2.3.2001 , 20171113
UIInstallUpgrade , 2.3.2001 , 20171113
Microsoft Visual C++ 2012 x64 Additional Runtime - 11.0.61030 , 11.0.61030 , 20171113
CheckDevices Install Configurator , 2.3.2001 , 20171113
Microsoft Visual C++ 2015 x64 Minimum Runtime - 14.0.24215 , 14.0.24215 , 20171116
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.6161 , 9.0.30729.6161 , 20171114
LauncherSetup Install , 2.3.2001 , 20171113
Office 16 Click-to-Run Licensing Component , 16.0.8625.2121 , 20171113
Office 16 Click-to-Run Extensibility Component 64-bit Registration , 16.0.8625.2121 , 20171113
Microsoft Visual C++ 2013 x64 Additional Runtime - 12.0.21005 , 12.0.21005 , 20171113
Microsoft Visual C++ 2013 x64 Minimum Runtime - 12.0.21005 , 12.0.21005 , 20171113
ProductNS Install Configurator , 2.3.2001 , 20171113
Nvidia Share , 3.10.0.95 , 20171113
SonicMapper Install Configurator , 2.3.2001 , 20171113
Microsoft Visual C++ 2012 x64 Minimum Runtime - 11.0.61030 , 11.0.61030 , 20171113
ApoDispatch Install Configurator , 2.3.2001 , 20171113
Microsoft Visual C++ 2015 x64 Additional Runtime - 14.0.24215 , 14.0.24215 , 20171116
Google Chrome , 62.0.3202.89 , 20171113
RivaTuner Statistics Server 6.4.1 , 6.4.1 ,
Steam , 2.10.91.91 ,
Heaven Benchmark version 4.0 , 4.0 , 20171114
Microsoft Visual C++ 2013 x86 Minimum Runtime - 12.0.21005 , 12.0.21005 , 20171113
Microsoft Visual C++ 2012 Redistributable (x86) - 11.0.61030 , 11.0.61030.0 ,
Google Update Helper , 1.3.33.7 , 20171116
Microsoft Visual C++ 2015 x86 Additional Runtime - 14.0.24215 , 14.0.24215 , 20171116
Microsoft Visual C++ 2013 Redistributable (x64) - 12.0.21005 , 12.0.21005.1 ,
Office 16 Click-to-Run Extensibility Component , 16.0.8625.2121 , 20171113
Office 16 Click-to-Run Localization Component , 16.0.8326.2076 , 20171113
Microsoft Visual C++ 2008 Redistributable - x86 9.0.30729.6161 , 9.0.30729.6161 , 20171114
Microsoft Visual C++ 2012 x86 Additional Runtime - 11.0.61030 , 11.0.61030 , 20171113
Microsoft Visual C++ 2015 x86 Minimum Runtime - 14.0.24215 , 14.0.24215 , 20171116
Microsoft Visual C++ 2012 x86 Minimum Runtime - 11.0.61030 , 11.0.61030 , 20171113
Microsoft Visual C++ 2012 Redistributable (x64) - 11.0.61030 , 11.0.61030.0 ,
Microsoft Visual C++ 2013 Redistributable (x86) - 12.0.21005 , 12.0.21005.1 ,
Microsoft Visual C++ 2015 Redistributable (x64) - 14.0.24215 , 14.0.24215.1 ,
Microsoft Visual C++ 2015 Redistributable (x86) - 14.0.24215 , 14.0.24215.1 ,
Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 , 10.0.40219 , 20171116
Microsoft Visual C++ 2013 x86 Additional Runtime - 12.0.21005 , 12.0.21005 , 20171113
Windows Hotfix
KB4048951 , Security Update , KB4049179 , Security Update , 20171211
KB4051613 , Update , KB4048955 , Security Update ,
OS Activation
Name: Windows®, CoreSingleLanguage edition
Description: Windows® Operating System, RETAIL channel
Partial Product Key: 6F4BT
License Status: Licensed
sonicstream
post Nov 17 2017, 06:28 AM
I have same problem too with my laptop shutting down for no reason when on AC charger mode when under load. It turned out that it's the deteriorated battery that's the culprit when attached to laptop together with AC charger.
I don't think it's the overheat issue since gaming laptop have higher temperature threshold and can withstand internal temperature of 80-90C just fine. One thing I will suggest is when plugging AC charger to laptop, detach the battery and play games on laptop in AC-only mode.
And battery replacement maybe.
This post has been edited by sonicstream: Nov 17 2017, 01:26 PM
TSSweetPuff
post Nov 17 2017, 04:23 PM
QUOTE(sonicstream @ Nov 17 2017, 06:28 AM)
Wow. You're right! Seems to be ok so far after disconnecting the battery.
TSSweetPuff
post Nov 19 2017, 09:57 PM
Quick update. Shutdowns still happening but at longer intervals after disconnecting battery. Looking at 20 to 30 mins.
crumpetss
post Nov 20 2017, 01:36 PM
dummie
then try another charger, seems like power delivery issue
2 Pages  1 2 >Top
0.0240sec    0.59    6 queries    GZIP Disabled
Time is now: 18th December 2025 - 02:51 AM
