Hi all sifus,
Which type sifu's prefer on their meat? Dry rub or wet marinate? May I know why?
Wet Marinade or Dry rubs?, Which you all prefer?
Jun 8 2017, 02:15 PM, updated 9y ago
#1
619 posts Joined: Feb 2005 |
Hi all sifus,
Which type sifu's prefer on their meat? Dry rub or wet marinate? May I know why? |
Jun 8 2017, 02:21 PM
#2
60 posts Joined: Nov 2014 |
prefer wet marinate since flavour stick inside compare dry rub
but cannot eat meat anymore due to gout sadface... |
Jun 8 2017, 02:32 PM
#3
1,420 posts Joined: Nov 2013 |
"Yeah Boiii..."
Dry rub if you want to have the original taste. Wet Marinate is when you cant stand the original smell of the meat/vege...(example beef or lamb) |
Jun 8 2017, 02:33 PM
#4
455 posts Joined: Dec 2007 |
depend on how u want to prepare. steak go for dry
Jun 8 2017, 02:45 PM
#5
Jun 8 2017, 02:46 PM
#6
Jun 8 2017, 02:52 PM
#7
Jun 8 2017, 03:04 PM
#8
Jun 8 2017, 03:09 PM
#9
Jun 8 2017, 03:10 PM
Jun 8 2017, 03:34 PM
Jun 8 2017, 03:43 PM
Should dry rub be cooked immediately? Or should we let it rest say 3-4 hours?
Jun 8 2017, 10:37 PM
3,940 posts Joined: Jul 2009 |
Jun 8 2017, 11:10 PM
21,457 posts Joined: Jul 2012 |
It is a waste of money to wet marinate or dry rub a good piece of steak. Whether wet marination or dry rub, flavour doesn't penetrate deep but stay at surface only. However, the salt is marination and rub will tenderize the meat a bit. |
Jun 9 2017, 08:47 AM
QUOTE(patryn33 @ Jun 8 2017, 10:37 PM) lovely share.. thanks ! |
Jun 9 2017, 11:57 AM
#16
QUOTE(icemanfx @ Jun 8 2017, 11:10 PM) It is a waste of money to wet marinate or dry rub a good piece of steak. Whether wet marination or dry rub, flavour doesn't penetrate deep but stay at surface only. However, the salt is marination and rub will tenderize the meat a bit. Salt method is not about marinate since it's wash offhttp://steamykitchen.com/163-how-to-turn-c...ime-steaks.html Really depends on time http://www.food.com/recipe/steak-marinade-...-and-easy-39145 This post has been edited by patryn33: Jun 9 2017, 12:00 PM |
Jun 9 2017, 03:53 PM
QUOTE(patryn33 @ Jun 9 2017, 11:57 AM) Salt method is not about marinate since it's wash off Hi ..http://steamykitchen.com/163-how-to-turn-c...ime-steaks.html Really depends on time http://www.food.com/recipe/steak-marinade-...-and-easy-39145 I dont know it's just me or what, most of the reference was to beef meat.. How about lambs? Does this apply the same? Should we put salts to remove the moist inside the meat? So far i've tried aged beef.. Is there anyone who aged lamb meat? Probably after aged got no more meat left? |
Jun 11 2017, 01:09 AM
#18
QUOTE(shinchan99 @ Jun 9 2017, 03:53 PM) Hi .. Beef and lamb not same, diff cut calls for diff styleI dont know it's just me or what, most of the reference was to beef meat.. How about lambs? Does this apply the same? Should we put salts to remove the moist inside the meat? So far i've tried aged beef.. Is there anyone who aged lamb meat? Probably after aged got no more meat left? https://www.chowhound.com/food-news/139125/...for-lamb-chops/ http://www.thekitchn.com/5-mistakes-to-avo...-of-lamb-229889 Lamb is young and tender, mutton you could get age http://www.foodnetwork.com/videos/dry-aged-lamb-0156346 This post has been edited by patryn33: Jun 11 2017, 01:11 AM |
Jun 12 2017, 04:47 PM
Today's experiment :
1. Dry rub Lamb Rack with Herbs (Dry rub consist of garlic powder, dried thyme, dried rosemary, sea salt, black pepper) LAMB RACK 2. Salt & Pepper beef short ribs (Sea salt on meat for 1 hour) BEEF Both lamb rack and beef are served with Balsamic Reduction Sauce.. Technique used: Room temperate on meat and a hot pan with olive oil and butter seared up both the meat for about 1 minute each side.. Into small home oven pre-heated with 250c top and bottom heat at about 10 minutes. Verdict: Both the lamb rack and beef are good.. A very good alternative to wet marinate.. All the while I've only tried wet marinate in my life being a typical chinese mindset.. With this new experiment on dry rub and sea salt only, it can be as good as wet marinate.. Mistake made: 1. I think I should not add more salt to the beef after putting the sea salt on top of the meat for 1 hour.. Should had remove all the excess salt and just put black pepper only.. End up my steak is slightly on the salty side.. 2. Slightly overcook my beef .. Should had set probably 5-7 minute for medium rare.. Feel free to comment, add in ideas or share your personal experience or tips for me to improve (Sorry presentation of food not great, i am just a home cook not a professional chef) This post has been edited by shinchan99: Jun 12 2017, 04:49 PM |
Jun 13 2017, 12:16 PM
#20
QUOTE(shinchan99 @ Jun 12 2017, 04:47 PM) Today's experiment : Get a https://anovaculinary.com, yield good results1. Dry rub Lamb Rack with Herbs (Dry rub consist of garlic powder, dried thyme, dried rosemary, sea salt, black pepper) LAMB RACK 2. Salt & Pepper beef short ribs (Sea salt on meat for 1 hour) BEEF Both lamb rack and beef are served with Balsamic Reduction Sauce.. Technique used: Room temperate on meat and a hot pan with olive oil and butter seared up both the meat for about 1 minute each side.. Into small home oven pre-heated with 250c top and bottom heat at about 10 minutes. Verdict: Both the lamb rack and beef are good.. A very good alternative to wet marinate.. All the while I've only tried wet marinate in my life being a typical chinese mindset.. With this new experiment on dry rub and sea salt only, it can be as good as wet marinate.. Mistake made: 1. I think I should not add more salt to the beef after putting the sea salt on top of the meat for 1 hour.. Should had remove all the excess salt and just put black pepper only.. End up my steak is slightly on the salty side.. 2. Slightly overcook my beef .. Should had set probably 5-7 minute for medium rare.. Feel free to comment, add in ideas or share your personal experience or tips for me to improve (Sorry presentation of food not great, i am just a home cook not a professional chef) |
| Change to: | 0.0181sec
0.61
5 queries
GZIP Disabled
Time is now: 13th December 2025 - 06:25 PM |
