 which 1 I should get... suggestion plz, Kawasaki ninja 250cc or honda CBR 250cc
TSganabathi
post Apr 1 2012, 02:29 PM, updated 14y ago
Associate of Master Photographers Association UK
hi guys i need ur opinion on getting any of these bikes
Honda CBR 250cc
or
Kawasaki Ninja 250cc
* performance,
* maintenance
* Speed
* Quality
* service centers
zauq_23
post Apr 1 2012, 03:00 PM
QUOTE(ganabathi @ Apr 1 2012, 02:29 PM)
Honda CBR 250cc
or
* performance,
* maintenance
* Speed
* Quality
* service centers
new or second?
Lelouch Lamperouge
post Apr 1 2012, 03:23 PM
been asking this question since last year and get the advice from various forumer and finally decided on ninja
Aaron135LC
post Apr 1 2012, 07:45 PM
To cut things short.. Cbr is more agile than ninja during traffic.. And low rev rpm is better than ninja during traffic.. Ergonomic wise.. Cbr better than ninja.. Ninja front tank n windbreaker covershoot very long.. Its as tho u drive a dodge viper compared with normal car..
But bad point is that.. U'll easily get bored with the cbr.. Riding wise ninja outperform cbr in highway.. Cause the tank able to give u to relax ur body in long distance and also the 2 cylinder characteristics.. Less vibration.. Cant say cbr vibrate like mad.. But more cylinder.. Wont give much strain to the engine compared to cbr..
But if u rarely go highway.. Cbr is a goood bike ! If use highway.. Ninja is the one to go.. =)
kakashi...
post Apr 1 2012, 08:07 PM
ever consider duke 200?
skeleton202
post Apr 2 2012, 09:54 AM
Perdana Malaysia ke-9
somehow i think kawasaki is overate here
TSganabathi
post Apr 2 2012, 11:23 PM
QUOTE(zauq_23 @ Apr 1 2012, 03:00 PM)
new or second?
looking for new
masz94
post Apr 2 2012, 11:57 PM
Ninja uses ancient ZZR 250 engine.... A very lazy revving engine....
CBR 250R uses a new high tech engine....
FC also better than Ninja.... Climbing hills is much easier with the CBR....
Talking about sound, both also crap....
So the choice is obvious....
TSganabathi
post Apr 6 2012, 06:04 AM
QUOTE(masz94 @ Apr 2 2012, 11:57 PM)
any opinion on its sound.. exoze pipe sound
cbr 1 cylinder
ninja 2 cylinder
which 1 better?
NoobboyZzZ
post Apr 6 2012, 07:36 AM
top speed
ninja
daily ride cbr
resale = honda > kawasaki anyway
and lagenda also sound crap too
TSganabathi
post Apr 6 2012, 09:55 PM
QUOTE(NoobboyZzZ @ Apr 6 2012, 07:36 AM)
top speed
ninja
daily ride cbr
wht u mean daily ride here
EyraYus
post Apr 6 2012, 10:14 PM
sTRe3tHunt3R
QUOTE(ganabathi @ Apr 6 2012, 09:55 PM)
seriously, tell us why you need the bike for? What is your usual riding condition? Where are you going to go with the bike?
upmost systems
post Apr 6 2012, 10:22 PM
tired of flashing
QUOTE(ganabathi @ Apr 6 2012, 06:04 AM)
cbr 1 cylinder
ninja 2 cylinder
which 1 better?
i guess cbr...
2 cylinder parallel twin sound not nice..unless v-twin like ducati
TSganabathi
QUOTE(EyraYus @ Apr 6 2012, 10:14 PM)
to my workplace..
every day im traveling around 130km...
now using 100cc motorbike.... this bike not suit for long journey.. small bike really tiring....
upmost systems
post Apr 6 2012, 10:24 PM
tired of flashing
QUOTE(ganabathi @ Apr 6 2012, 10:22 PM)
to my workplace..
in that case..kawasaki..twin cylinder better for long journey
EyraYus
post Apr 6 2012, 10:28 PM
sTRe3tHunt3R
to my workplace..
130km of highway riding or city riding?
both are suitable for you. let me try to explain the difference between these two bike.
Ninja are using inline 2 engine, a very lazy engine in low rev, you are going to work a bit harder in traffic, but have the top speed advantage if you get a clear highway (how often do you find that in KL..)
CBR are using a single cylinder engine, engine response in very quick. better for traffic, not as powerful in top RPM, but how often do we do that on everyday basis?
CBR are the lighter and nimbler bike for traffic
maintenance, the CBR use less amount of engine oil, so CBR win.
well, i`ll be damned, the CBR win hands down. 250`ers not going to like this..
anyway, my suggestion is test drive both first..
Added on April 6, 2012, 10:29 pm
QUOTE(upmost systems @ Apr 6 2012, 10:24 PM)
depends, once in my short life i travel 100km everyday, through heavy traffic doh.gif
This post has been edited by EyraYus: Apr 6 2012, 10:29 PM
TSganabathi
post Apr 6 2012, 10:43 PM
QUOTE(EyraYus @ Apr 6 2012, 10:28 PM)
old road, from taiping to selama... the road consider wide and straight, thats y im thinking to get a bigger bike..
so what bout full maintenance? CBR high or kawasaki?.
resell value which 1 high?
what bout the sound of the exzos pipe? im looking for a rough sound...
EyraYus
post Apr 6 2012, 11:07 PM
sTRe3tHunt3R
QUOTE(ganabathi @ Apr 6 2012, 10:43 PM)
CBR cheaper as the engine have less moving part compared the Ninja.
Resell...not sure though..no 2nd hand CBR at the moment..
upmost systems
post Apr 6 2012, 11:09 PM
tired of flashing
QUOTE(EyraYus @ Apr 6 2012, 11:07 PM)
kawasaki can be considered "motor sejuk"
masz94
post Apr 7 2012, 01:33 AM
top speed
ninja
daily ride cbr
Trolololol.... u own Lagenda too....
haha....
Added on April 7, 2012, 1:51 am
cbr 1 cylinder
ninja 2 cylinder
which 1 better?
Depends on you.... But I think CBR sounds better... to me la....
Ninja also ok... but on mid to high revs sounds crappy....
This post has been edited by masz94: Apr 7 2012, 01:51 AM
2 Pages  1 2 >Top
0.0193sec    0.37    5 queries    GZIP Disabled
Time is now: 25th November 2025 - 04:22 AM
