 dif p45 jr t2rs cant change vcore value, it stuck at default value.
TSzackskate666
post Jan 10 2010, 12:16 PM, updated 16y ago
hi..i just bought a dfi jr p45 t2rs from a forumer here.she claimed it brand new,but when i received it,there's a lot of dust stuck at the NB cooler..then,its not a new one right?..the problem with this Motherboard is when i go into the bios setting,i try to add the cpu vid to +50mV then try to boot at 4ghz for my e8400 E0,but i cant boot at all.when i check inside the bios,the value of cpu vcore still at 1.20v even i've added +50mV..then i add to +100mV and reboot it..it still cannot reboot into windows and the bios value still show 1.25v..any of u guys encounter like this before??
TristanX
post Jan 10 2010, 12:27 PM
Where is my stars?
Elite
Settings for DFI boards are different. It's a headache for me when I tried to OC with the board but after browsing DFI's support site, I know what to do.
You can also visit this site for DFI:
http://csd.dficlub.org/forum/index.php
Here is some settings for quad core:
http://forum.lowyat.net/topic/773477/+1020
You don't this much for dual core.
kujaboyde
post Jan 10 2010, 12:37 PM
jaHat macam MoRza
restore defauilt setting 1st, reboot, then oc it again..i lost all my JR setting last time.. or u can try to flash to latest bios..so far JR never give me probs
TristanX
post Jan 10 2010, 12:46 PM
Where is my stars?
Elite
Also, you need to flash your BIOS if you are using RAM with 1066mhz. This board is bugged when you have 1066mhz installed.
TSzackskate666
post Jan 10 2010, 12:48 PM
i've done the e8400 e0 at 4.1ghz with +50mV on my blood iron board..i've tried it.set the cpu vid to +100mV and boot as stock speed..then check in the windows,still the value is 1.25v..why izit that that it wont change even i've added the vcore?
TristanX
post Jan 10 2010, 01:50 PM
Where is my stars?
Elite
I have no idea. The only answer you can get is from DFI. Just ask in their support site, not here.
uzairi
post Jan 10 2010, 10:39 PM
Team almostthere
DK P45 T2RS bios have several cases of corrupted bios, re-flashing them would solve the problem but it would just not go permanently as it might occur again in the future.
tech_frix
post Jan 10 2010, 11:16 PM
Boo Yah!
this is bad news zack...
i think better return back to d seller since this one is consider as faulty prob...
ask her to refund and buy other board...setel..
heizad
post Jan 11 2010, 12:01 AM
~ Harimau Malaya ~
got 1 to 1 exchange or not?
TSzackskate666
post Jan 11 2010, 11:32 AM
just flashed the mobo with the latest bios..currently working at 4.1ghz with 1.28vcore..finally..but 1thing i dont like this mobo is the NB cooler touch with my CM 212.thus need to change the position of the fan.cannot use dual fan setup anymore as in my cm690 case its already cramped..and also the board 12v+ connector is really far away at the back,and my vantec psu cable is a lil short..darn..need to direct route it..cannot hide it as the back case..for sumone that wants to make a sff pc,its a nice board..but its not very friendly to cm690 case and cm hyper 212 heatsink..u guys using which type heatsink??
kujaboyde
post Jan 11 2010, 11:48 AM
jaHat macam MoRza
i use geminII, geminS for my sff..if u think changing to sff, visit out sff thread
TSzackskate666
post Jan 11 2010, 11:56 AM
geminII is kinda high its heat pipe right?.so,it wont touch the NB cooler right..right now full load is around 68C..if use dual fan setup it will be around 60c..
tech_frix
post Jan 11 2010, 11:58 AM
Boo Yah!
QUOTE(zackskate666 @ Jan 11 2010, 11:32 AM)
ambik gambo and post can r??
cant imagine d situation...
TSzackskate666
post Jan 11 2010, 11:59 AM
balik nanti ako kasi gambo tu direct ke YM ko and also this topic oso..
0.0173sec    0.66    5 queries    GZIP Disabled
Time is now: 12th December 2025 - 02:18 AM
