 C2Q9450..., need some reference
TStgairborne
post Sep 30 2008, 03:11 PM, updated 18y ago
Hi guys,
Was wondering how far can this chip go ? Has anyone reach 4GHZ using air cooling here ? I tried playing with this chip (all settings auto) , the most I can reach is 420 FSB x 8 (stable). Idle temperature is around 34c-36c (non aircond environment), full load reach 64c.
One question, I used Core temp to monitor my core temp, it shows 70c-80c for all the core. Where else my Dual Core Centre shows only 64c. Which value should I rely on ?
Thanks alot.
PS: If anyone got any good guide / hints on OC-ing this chip.. please do share share here. Thanks rclxms.gif rclxms.gif
-pWs-
post Sep 30 2008, 03:13 PM
Elite
-pWs-
xk2
post Sep 30 2008, 03:29 PM
Temporary OFF
for ur info,the MSI duo core center always provide fake temp laugh.gif ,it show my proc temp 22 sweat.gif but everest and core temp show normal 44.which cooler u use ?
This post has been edited by xk2: Sep 30 2008, 03:30 PM
TStgairborne
post Sep 30 2008, 03:34 PM
QUOTE(-pWs- @ Sep 30 2008, 03:13 PM)
-pWs-
QUOTE
for ur info,the MSI duo core center always provide fake temp  ,it show my proc temp 22  but everest and core temp show normal 44.which cooler u use ?
Hmm, but my bios showing same temperature with my core center.Im just using stock cooler currently.
Silverfire
Cruxiaer
QUOTE(tgairborne @ Sep 30 2008, 03:11 PM)
Hi guys,
Thanks alot.
Use RealTemp... AFAIK 64'C at full load is OK! What voltage did you use to achieve 420*8?
TStgairborne
post Sep 30 2008, 03:37 PM
QUOTE(Silverfire @ Sep 30 2008, 03:34 PM)
Hi there,
As far as I remember, I set Vcore on Auto. And CPU-Z shows that the Vcore is at 1.18-1.20 range.
Silverfire
post Sep 30 2008, 04:44 PM
Cruxiaer
QUOTE(tgairborne @ Sep 30 2008, 03:37 PM)
Hi there,
If you would set it to 1.3 I'm quite sure you processor can bump up to 450~480 bus speed.
tkh_1001
post Sep 30 2008, 05:24 PM
Hi guys,
Thanks alot.
yes it can hit 4ghz... but it depends on ur chip n mobo.....
jsut use the coretemp 0.99.3 or realtemp 2.75 as ur temp reader
DaRkSyThE
post Sep 30 2008, 07:01 PM
VIP
sorry but there are C2D Quad threads around to ask these kind of questions
0.0161sec    0.18    5 queries    GZIP Disabled
Time is now: 6th December 2025 - 01:23 PM
