Hi,
I would like to analyse the bandwidth usage by each of the PC in LAN. Any recommended software?
P/S: All the internet connections go tru the router.
Thanks.
Bandwidth Analyze in LAN
Aug 8 2008, 12:07 PM, updated 18y ago
#1
70 posts Joined: Jan 2003 |
Hi,
I would like to analyse the bandwidth usage by each of the PC in LAN. Any recommended software? P/S: All the internet connections go tru the router. Thanks. |
Aug 8 2008, 03:22 PM
#2
604 posts Joined: Oct 2007 |
Oct 15 2008, 04:14 PM
#3
603 posts Joined: Apr 2005 From: banglo bebudak pompuan af5 |
bump again !
any other suggestion? im also looking for this kind of software |
Oct 15 2008, 08:28 PM
#4
1,263 posts Joined: Jan 2007 From: Marehsia. |
unless u got access to all the pc on the network...u can try networkmagic...or one of its brothers....but it requires u to install it on all the pc first....
these kind of softwares are hard to do/find...because...each pc goes to a different port so unless the software can access and instruct the router to provide or collect such information...it is impossible to do... |
Oct 16 2008, 11:48 PM
#5
950 posts Joined: Jan 2003 From: Kuala Lumpur,Cheras |
if using ddwrt firmware...rflow collactor can do the job i think...have to enable rflow on the router to which lan ip 1st...
Oct 17 2008, 12:45 AM
#6
879 posts Joined: Jan 2007 |
if you use cisco, you can enable the netflow
Oct 23 2008, 02:50 PM
#7
4,414 posts Joined: Feb 2005 |
QUOTE(neuromancerx @ Oct 17 2008, 12:45 AM) U mean solarwinds software right? Their software damn good, unfortunately its more businesses and it cost a bomb, USD 2700 for their orion network software. But its very comprehensive since it looks true nearly all network layers.I can even check your PC stats using the orion, not to mention what applications are being used on a computer over network to connect to the net and what protocols are being used. |
Oct 23 2008, 10:07 PM
#8
1,035 posts Joined: Feb 2008 |
I also look for this kind of software for LAN n WLAN.
Oct 24 2008, 11:53 PM
#9
176 posts Joined: May 2008 |
cfos speed?
Oct 29 2008, 11:59 PM
693 posts Joined: Apr 2007 |
wireshark works as well i think.
Oct 30 2008, 07:12 AM
1,536 posts Joined: Jan 2003 From: Member No.: 9870 |
Nov 3 2008, 08:53 PM
854 posts Joined: Sep 2005 From: 25.0000° N, 71.0000° W |
Nov 5 2008, 01:37 AM
725 posts Joined: Jul 2008 |
| Change to: | 0.0182sec
0.93
5 queries
GZIP Disabled
Time is now: 21st December 2025 - 12:45 PM |
