Which brand is better? Which one offer more color codes?
How many color codes for
Nippon = ?
Jotun = ?
Dulux = ?
Nippon vs Jotun vs Dulux, which one is better?
Jul 25 2023, 02:46 PM, updated 3y ago
#1
795 posts Joined: Nov 2004 |
How many color codes for Nippon = ? Jotun = ? Dulux = ? |
Jul 25 2023, 02:50 PM
#2
9,789 posts Joined: Jun 2008 From: Rubber Duck Pond |
I picked Dulux cause price cheaper compared to the rest. Color and quality wise macam sama je
Jul 25 2023, 02:51 PM
#3
4,694 posts Joined: Jan 2005 |
Every brand is good. If u follow their instructions.
Most important is surface preparation. U skip on that, what brand also tak guna. |
Jul 25 2023, 02:56 PM
#4
QUOTE(scorgio @ Jul 25 2023, 03:51 PM) Every brand is good. If u follow their instructions. What mean surface preparation? Means need to paint base layer with sealer /undercoat first? What if my new house already have undercoat?Most important is surface preparation. U skip on that, what brand also tak guna. |
Jul 25 2023, 03:01 PM
#5
153 posts Joined: Mar 2016 |
for outside house i ask for cheapest, for inside i ask for no smell lol
Jul 25 2023, 03:02 PM
#6
1,420 posts Joined: Nov 2013 |
Nippon, I choose special colored
Dulux, choose for their white color Jotun, I choose exterior paint |
Jul 25 2023, 03:42 PM
#7
13,783 posts Joined: Jan 2006 From: stress & confuse world |
Jul 25 2023, 03:44 PM
#8
216 posts Joined: Feb 2016 |
Jotun is best. I use Nippon too. Not bad
Jul 25 2023, 04:20 PM
#9
Jul 25 2023, 04:30 PM
I give paint shop this color code OW 1087 P (Nippon Paint) but they said it can be mixed and matched. Any idea why need to mix only can get the color I want?
Is it because not in their color chart https://www.nipponpaint.com.my/assets/np-co...-collection.pdf ? This post has been edited by goolie: Jul 25 2023, 04:39 PM |
Jul 25 2023, 04:54 PM
142 posts Joined: Sep 2008 |
nippon easy to get tompok putih kulat lol
Jul 25 2023, 07:54 PM
QUOTE(goolie @ Jul 25 2023, 04:20 PM) Which model of Jotun is best? Jotun cover plus, ok? Jotashield and weatherbond outside.. So far satisfied for both my houses. What is different btw Jotun Cover Plus vs Nippon Paint Easy Wash? Not sure of the difference maybe you can refer to specialists. Won't go wrong with either of the brand |
Jul 26 2023, 11:26 AM
4,412 posts Joined: Jan 2013 |
QUOTE(goolie @ Jul 25 2023, 04:30 PM) I give paint shop this color code OW 1087 P (Nippon Paint) but they said it can be mixed and matched. Any idea why need to mix only can get the color I want? all paints really have to use their machine to mix & match and come out with your color code accordingly.. there is no ready color code paint available in each shop.. but they have their machine to come out the code u wantIs it because not in their color chart https://www.nipponpaint.com.my/assets/np-co...-collection.pdf ? |
Jul 26 2023, 11:28 AM
QUOTE(ChuanHong @ Jul 26 2023, 12:26 PM) all paints really have to use their machine to mix & match and come out with your color code accordingly.. there is no ready color code paint available in each shop.. but they have their machine to come out the code u want Ok, but it won't guarantee 100% accurate, right? Different shop will use different machine to mix and match and come out my color code. What if they use cheaper brand of machine? I was wondering how it may differ from my expectation. |
Jul 26 2023, 11:50 AM
#15
5,542 posts Joined: Dec 2006 |
QUOTE(goolie @ Jul 26 2023, 11:28 AM) Ok, but it won't guarantee 100% accurate, right? Different shop will use different machine to mix and match and come out my color code. What if they use cheaper brand of machine? I was wondering how it may differ from my expectation. Jotun call it multicolour machine, not sure what nippon call it, every machine is maintained by their respective manufacturer, nippon will be maintain by nippon , jotun by jotun, there is no cheap or expensive machineYou go to the shop tell them the colour code and also the type of paint you want, when they key in the info in machine they will be able to tell you the price The colour is mostly accurate, if you buy the same colour but from different shop, and you found that the colour is different side by side then you can try to contact the paint manufacturer for warranty, but I'm not sure how is the process here For nippon I find that the painted colour is very different from the catalogue, while Jotun painted colour is always very closely matched to the catalogue, but nippon has better wood stain colour, I like their hydrowood wood stain series, I haven't tried Dulux before so no comment on that brand If you want to choose colour that is not in the catalogue, you can go to shop and request for fan deck, nippon has 1000 colour fan deck, while Jotun has 800 if I'm not mistaken, but choosing from fan deck is risky because you can't take the fan deck back home to match with your house lightning condition |
Jul 26 2023, 02:34 PM
QUOTE(goolie @ Jul 26 2023, 11:28 AM) Ok, but it won't guarantee 100% accurate, right? Different shop will use different machine to mix and match and come out my color code. What if they use cheaper brand of machine? I was wondering how it may differ from my expectation. i cant confirm whether it isnt 100%.. but it is almost identical.. just after paint on your wall + lighting effect, color looks a bit different.. cause browser/catalogue show dark black, might turn outemaybe a bit dark green/dark blue.. too many factors.. some do have white color wall as base, some have otthhr color on wall as base.. paint on it might create different color too.. machine wise should be provided by paint manufacturer if they are authorised dealer for the paint.. like earlier member shared, nippon color slightly off in my opinion as well, but jotun is quite identical.. but go home and back on it, slightly different feel again.. hahaha |
Jul 26 2023, 02:55 PM
2,892 posts Joined: Nov 2004 |
#18
2,610 posts Joined: Aug 2011 |
QUOTE(goolie @ Jul 26 2023, 11:28 AM) Ok, but it won't guarantee 100% accurate, right? Different shop will use different machine to mix and match and come out my color code. What if they use cheaper brand of machine? I was wondering how it may differ from my expectation. All machines are brand dependant. Nippon got Nippon machine, Jotun got Jotun machine etc. Authorized dealers will use their respective brand machine. No "cheap" machine unless they're scam shop 😂😂😂 Usually paints don't keep ready stock in store unless is basic colors in some bigger chain hardware store, and even then only small amounts for small DIY projects (not enough for full house). As far as whether what you see is what you get, must consider both the finish and also the LRV of the paint. What you see on screen/in shop might not be true when put in your house, because of different lighting condition. Best bet is to ask for samples, if you're DIYing https://thelandofcolor.com/lrv-light-reflec...f-paint-colors/ |
Jul 26 2023, 03:13 PM
QUOTE(tvcat @ Jul 26 2023, 02:55 PM) Thanks. My outside wall get dirty mark very fast after repaint, is it because of not doing skim coat? not really. skim coat is just to make the surface even and less wavey before apply painting or else you can see lot of uneven/wavey walls under the lightsi guess the dirty part is more to the weather and you need some good exterior paint tvcat liked this post
Jul 26 2023, 03:24 PM
QUOTE(hihihehe @ Jul 26 2023, 03:13 PM) not really. skim coat is just to make the surface even and less wavey before apply painting or else you can see lot of uneven/wavey walls under the lights I see, thanks for the info.i guess the dirty part is more to the weather and you need some good exterior paint |
| Change to: | 0.3152sec
0.74
5 queries
GZIP Disabled
Time is now: 3rd December 2025 - 07:56 AM |
