 Slow openvpn performance
TSyongtjunkit
post May 1 2022, 02:05 PM, updated 4y ago
Hi, I'm getting slower than 30mbps on speedtest over openVPN. I'm not sure if this is normal or is this a bottleneck of the Asus AC68U which is running the openVPN sever
Host side
Asus AC68U
Maxis fiber 30mbps
Client side
Unifi 300mbps
Tried a few different clients, including iPhone 12 and got similliar results(including using mobile data - Digi)
teslaman
post May 1 2022, 02:11 PM
iPhone is via wifi?
TSyongtjunkit
post May 1 2022, 02:44 PM
QUOTE(teslaman @ May 1 2022, 02:11 PM)
iPhone is via wifi?
Tried both Wi-Fi and mobile data
heLL_bOy
post May 1 2022, 04:13 PM
openvpn is quite complicated, you have to tweak the server setting and client setting to match up the speed.
original setting might not give you the best performance.
alucard89
post May 1 2022, 08:58 PM
Try wireguard? Seems like the better option
Oh your router model probably not supported yet
This post has been edited by alucard89: May 1 2022, 09:00 PM
teslaman
post May 1 2022, 09:51 PM
QUOTE(yongtjunkit @ May 1 2022, 02:44 PM)
probably bottleneck at your router compute ability, because data is encrypted
TSyongtjunkit
post May 1 2022, 10:16 PM
QUOTE(heLL_bOy @ May 1 2022, 04:13 PM)
Hmm, so far I only touched the general settings other than for IPV6 which is located in advance, any suggestions on which settings I could change?
QUOTE(alucard89 @ May 1 2022, 08:58 PM)
Yup, only PTPP and OpenVPN is available
QUOTE(teslaman @ May 1 2022, 09:51 PM)
Hmm, is there anything that I can do to reduce the effect by any chance? Also btw, for routers how high of a cpu usage(%) is too high for a router? 😅
This post has been edited by yongtjunkit: May 1 2022, 10:18 PM
teslaman
post May 1 2022, 10:26 PM
QUOTE(yongtjunkit @ May 1 2022, 10:16 PM)
try change compression, and 128 or 256 bit encryption? and tcp or udp setting, udp recomended
GOPI56
post May 1 2022, 10:34 PM
QUOTE(yongtjunkit @ May 1 2022, 12:05 AM)
Host side
Asus AC68U
Maxis fiber 30mbps
Client side
Unifi 300mbps
Are you currently using the stock Asus firmware or Asus WRT Merlin firmware?
Are you currently using the Instant Guard app and option in the router?
SUSpetpenyubobo
post May 2 2022, 12:45 AM
QUOTE(yongtjunkit @ May 1 2022, 02:05 PM)
Host side
Asus AC68U
Maxis fiber 30mbps
Client side
Unifi 300mbps
Change your VPN protocol type like some has suggested.
Suggest using SoftEther, WireGuard, or VMess/V2Ray. Dump OpenVPN it's already showing its age with very high overheads and inefficiencies.
TSyongtjunkit
post May 2 2022, 06:30 AM
QUOTE(teslaman @ May 1 2022, 10:26 PM)
hmm.gif , was able to get the download speed up to 20mbps after disabling compression, encrytion is already the on 128 bit encrytion and it's also on UDP by default
QUOTE(GOPI56 @ May 1 2022, 10:34 PM)
Stock firmware, the VPN sever options were PPTP and OpenVPN sever only
This router doesn't support Instand guard
QUOTE(petpenyubobo @ May 2 2022, 12:45 AM)
Unfortunately, this router only supports PPTP and OpenVPN sever only sweat.gif
This post has been edited by yongtjunkit: May 2 2022, 06:32 AM
teslaman
post May 2 2022, 09:20 AM
QUOTE(yongtjunkit @ May 2 2022, 06:30 AM)
run server on PC as alternative not on router.
TSyongtjunkit
post May 2 2022, 12:13 PM
QUOTE(teslaman @ May 2 2022, 09:20 AM)
Hmm, would prefer if it’s being run on the router instead as I don’t have any spare PC available 😅
TSyongtjunkit
post May 2 2022, 12:20 PM
Read up on ASUS wrt Merlin on it’s website and found this
QUOTE
Performance optimizations to some CPU-bound components like OpenVPN
Wondering if it makes a difference? Also can this be installed remotely(over the internet)?
GOPI56
post May 2 2022, 12:48 PM
QUOTE(yongtjunkit @ May 1 2022, 10:20 PM)
It will make some differences in terms of performance and stability depending on the router model. Some tweaks and enhancements while maintaining all the router functions.
In order to install the WRT Merlin firmware you will need direct access to the router because you will be uploading the firmware file to the router.
TSyongtjunkit
post May 2 2022, 01:06 PM
QUOTE(GOPI56 @ May 2 2022, 12:48 PM)
I see the was able to have remote web access to it(like on local network except it’s over the internet) and there’s an option to upload the firmware file, is that sufficient? Or do I need to physically do things like switch off the wall switch?
This post has been edited by yongtjunkit: May 2 2022, 01:10 PM
GOPI56
post May 2 2022, 01:13 PM
QUOTE(yongtjunkit @ May 1 2022, 11:06 PM)
I see the was able to have remote web access to it(like on local network except it’s over the internet), is that sufficient? Or do I need to physically do things like switch off the wall switch?
You can try it via the remote web access.
But it is recommended to directly connect the router to your laptop via LAN cable. Normally I do it this way.
TSyongtjunkit
post May 2 2022, 01:15 PM
QUOTE(GOPI56 @ May 2 2022, 01:13 PM)
I see, I believe all the settings would carry over from the last eat ac68U firmware too?
GOPI56
post May 2 2022, 01:18 PM
QUOTE(yongtjunkit @ May 1 2022, 11:15 PM)
Yes, your existing settings will be preserved.
But it is better to make a backup of the current configuration before proceeding to flash the firmware.
TSyongtjunkit
post May 2 2022, 04:29 PM
QUOTE(GOPI56 @ May 2 2022, 01:18 PM)
hmm.gif , I'm getting ERR_NAME_NOT_RESOLVED when connected to openVPN on PC but on my iPhone 12 it works fine(can load website) after flashing asuswrt merlin firmware, I've tried remotely rebooting the router, reseting the openVPN sever settings and manually reenter the settings.
2 Pages  1 2 >Top
0.0237sec    1.16    5 queries    GZIP Disabled
Time is now: 24th December 2025 - 07:51 PM
