 Windows Tint, worth or not?, For Rental house, house Tint...
Worth [ 23 ] ** [62.16%]
Not worth [ 14 ] ** [37.84%]
Total Votes: 37
Guests cannot vote
TSmoon yuen
post May 21 2020, 09:26 PM, updated 5y ago
It's a condo, for rental
purpose....
But, during afternoon, the condo quite hot.
Is it worth to do windows tiny? The cheap one... Around RM800...
Or Any suggestion to reduce the house temperature without incur too much cost?
I already bought d curtain.
U can share here or pm me any method.
This post has been edited by moon yuen: May 23 2020, 11:34 PM
SUSbronkos
post May 21 2020, 09:34 PM
you still need curtain coz ppl from outside still can see inside esp. when light is on during nite time.
Salary
post May 21 2020, 09:43 PM
QUOTE(moon yuen @ May 21 2020, 09:26 PM)
It's a condo, for rental purpose....
Not required for rental. Cheap tint is going to make your windows look terrible after 2 or 3 years and doesn’t reject much heat.
If it’s for your own stay, absolutely.
mayonggglyt P
post May 22 2020, 02:59 PM
Probation
Just wondering, if I tint my windows but I open them, what's the efficiency like of reducing heat into the house?
Is tinting windows more for keeping heat out when your windows are closed (and the aircon is on)? So less electricity used to cool the room?
TSmoon yuen
post May 23 2020, 07:17 AM
Wah, 50 vs 50
Just wondering, those vote Worth, what tint quality u guys pick?
cryheart
post May 23 2020, 10:49 PM
i see shopee got sell glass tinted paper, quite cheap but maybe not that effective, can try it first; car with exp tinted also hot without aircond haha
can try mist fan (with cold water inside) + heavy curtain to close all window
eric3417
post May 23 2020, 10:53 PM
If done right is worth. Provides privacy, reduction of heat / glare & also can be aesthetically pleasing. Security also. Coz ppl cannot see in.
Salary
post May 25 2020, 10:33 PM
QUOTE(moon yuen @ May 23 2020, 07:17 AM)
Wah, 50 vs 50
I believe those that voted yes think that it’s for your own stay. If I’m looking to rent a unit, tinted windows is far down my “nice to have” list. It’s not something that will sway a potential tenant into renting your unit. If you spend money on high quality tinting, it will cost you a minimum 4-figure and you’re better off providing more complete furnishing with that cash. If you go for cheap tints, you’ll probably need to remove it before renting out to your next tenant.
mainsikitsikit P
post Jul 7 2020, 09:41 PM
Probation
Hi all. I am thinking of tinting my sliding door and all my windows for condo. My sliding door is quite large as well.
mainsikitsikit P
post Jul 7 2020, 09:59 PM
Probation
Couldnt edit above post. But I wonder if someone can provide expected quotation for this? The sliding doors will have about 8 panels.
mainsikitsikit P
post Jul 7 2020, 10:07 PM
Probation
QUOTE(mainsikitsikit @ Jul 7 2020, 09:59 PM)
My bad its 6 panels based on the post from sinaran group here.
Sinaran Binastra Progress - Click here
SUSceo684
post Jul 7 2020, 10:34 PM
Component Burner
I think a set of blackout curtains and rods will be better for that RM800 if for own stay.
stchoong
post Jul 8 2020, 11:43 AM
Willing to DIY? Can get from Taobao, a 1450 x 1850 cm (approx.) tinting film cost less than RM30 (better quality around RM50).
Shopee also does have it.
Saw reviews, its quite easy to DIY, just that you need patient.
blancpain4470
post Jul 8 2020, 11:59 AM
Why would anyone wants to do window tinting for rental property?? You can’t get higher rental and cheap ones will discolored or ineffective quickly.
It only makes sense to do this for own stay ... with decent quality tint
GamersFamilia
post Jul 8 2020, 04:58 PM
Proud to be Malaysian
for rental not worth , for your own condo definitely worth it
mainsikitsikit P
post Jul 8 2020, 07:52 PM
Probation
QUOTE(stchoong @ Jul 8 2020, 11:43 AM)
How do i know what is the better quality tint from shopee or lazada?
stchoong
post Jul 9 2020, 09:51 AM
QUOTE(mainsikitsikit @ Jul 8 2020, 07:52 PM)
Getting 'no-brand' things from online is a bet, might be inferior, normal or superior quality at a good price.
I ordered mine form TaoBao, haven't stick it on yet. But reviews on the seller are mostly positive. I saw some sellers on Shopee were flood with positive reviews too.
Anyhow, based on those reviews, it can be easily stick on, also easily tear off (with intention, not auto-drop off). So, I am willing to give it a try at such price. I PM a few tinting shop online, they quoted me somewhere around RM150 - 200 for the similar size i mentioned earlier.
mainsikitsikit P
post Jul 9 2020, 12:17 PM
Probation
QUOTE(stchoong @ Jul 9 2020, 09:51 AM)
I see. And with the size of the sliding doors here , the price should be way higher ya?
Thank you.
dannyw
post Jul 9 2020, 12:42 PM
I purchased my from TaoBao too on year 2013. The price i save compare to local is huge different. Quality wise hard to compare.
As at now, the color fade a bit compare to original, tiny part which keep under hot sun wrinkled a bit, but overall not noticeable.
For the price and years of usage consider ok for me. Not sure those local branded which quote me few k can last for how long?
Irresistible
post Mar 1 2021, 02:12 AM
QUOTE(dannyw @ Jul 9 2020, 12:42 PM)
Pinjam topic, my condo mgmt disallow reflective tint.
What are the criteria to look into when choosing tint? Main purpose reduce heat in house? Without making it too dark.
2 Pages  1 2 >Top
0.0458sec    0.32    7 queries    GZIP Disabled
Time is now: 16th December 2025 - 08:57 AM
