TCaseMax : 65'c
In this case, what is considered a safe overclocking core temp?
Can a CPU be overclocked until the temp is at TCaseMax or should it be like 3-5'c below the max?
TCaseMax, How high is a safe max temp?
May 19 2007, 06:54 PM, updated 19y ago
#1
Elite
14,576 posts Joined: May 2006 From: Sarawak |
TCaseMax : 65'c
In this case, what is considered a safe overclocking core temp? Can a CPU be overclocked until the temp is at TCaseMax or should it be like 3-5'c below the max? |
May 19 2007, 06:58 PM
#2
10,688 posts Joined: Jan 2005 |
not quite sure, but when im stressing my cpu, sure the load temp alot higher than TCaseMax's temp
May 19 2007, 09:35 PM
#3
Elite
May 20 2007, 10:07 AM
#4
2,471 posts Joined: Jan 2003 |
This is a new type of program, which checks AMD64 CPUs for their maximum rated case temp or TCaseMax and reports the TDP which corresponds to the processor in question.
On most AMD processors TCaseMax and TDP values are constant, and depend on CPU type and model, but on the E Revision chips, both this values and the default voltage are variable. These are the chips that have variable values: Athlon64 (Venice, San Diego) Athlon64 FX (San Diego) Athlon64 X2 (Manchester, Toledo) All Rev E Opterons and Dual Core Opterons What this all means is this: On 90nm manufacturing process, the power leakage of transistors on individual processors differs greatly, this is why AMD implemented TCaseMax. Each CPU has a different TDP rating, here's how it works: A program reads the TCaseMax value off the CPU, then depending on the processor (CPU type like A64, Opteron;CPU Rating like 3500+, 146) it finds the processor's Thermal Profile (If you download the "AMD Opteron(tm) Processor Power and Thermal Data Sheet" and look at pages 10-11 you'll see the different thermal profiles). When the thermal profile is determined, the program finds the TDP rating that corresponds to the CPU's TCaseMax value. So in a few words, the higher the TCaseMax, the higher the TDP of a processor will be (the transistor leakage is higher), so the processor will run hotter. Several people have reported that the Opterons rated at 71C TCaseMax were pretty hot. On the other side these processors will be able to reach higher clock speeds. That is why we see that on average processors with higher TCaseMax can usually reach higher CPU speeds when overclocked. Every CPU type (A64, FX, X2, Opteron, DC Opteron) has a different thermal profile, that is why you see that on an FX a TCaseMax rating can be "only" 57C and it'll overclock way better than an A64 with a 57C TCaseMax rating. That is because at 57C TCaseMax, an FX has a TDP of 77W while the A64 has a TDP of 44W. Right now we're working on getting a php page up where the user will be able to upload his CPU stats to the server and be able to see what other people could manage with the same chips, or look at other CPUs with different ratings and see what they're capable of. We believe this will be a great way to be able to roughly predict the overclockability of a CPU even before overclocking. We hope you find this software useful. |
May 20 2007, 10:36 AM
#5
QUOTE(kmarc @ May 19 2007, 09:35 PM) Aaa? Aren't you supposed to NOT go over the TCaseMax???? i dont know.. when im user of AMD, my load temp never exceed the TCaseMaxMy TCaseMax is 65'c and I'm already but when i change to Intel, my load always further than TCasemax.. around 80c~88c |
May 20 2007, 11:32 AM
#6
Elite
@gsan, thx for the info but I've read it before and roughly know what it is about.
What I'm asking is that how NEAR can we get to the TCaseMax in overclocking. Like what gengstapo said, he's core temp goes above TCaseMax!!! Is that recommended? Or is there a low temp recommendation? I guess in OC, everyone would say that the lower the temperature, the better it is for the CPU...... |
May 20 2007, 01:00 PM
#7
QUOTE(kmarc @ May 20 2007, 11:32 AM) @gsan, thx for the info but I've read it before and roughly know what it is about. bro, as I told you before, the TCaseMax is not the measurement as what you meant by. if you really scare the proc will gone in one day later, then do not overclock. What I'm asking is that how NEAR can we get to the TCaseMax in overclocking. Like what gengstapo said, he's core temp goes above TCaseMax!!! Is that recommended? Or is there a low temp recommendation? I guess in OC, everyone would say that the lower the temperature, the better it is for the CPU...... |
May 20 2007, 01:11 PM
#8
Elite
QUOTE(gsan @ May 20 2007, 01:00 PM) bro, as I told you before, the TCaseMax is not the measurement as what you meant by. if you really scare the proc will gone in one day later, then do not overclock. Aiyaaa.... you don't understand my meaning. What I mean is "safe" overclocking.Everybody knows that OC will shorten the lifespan of your PC components. What I'm trying to get at is OC in a safe way to maximum performance while also maximising pc components lifespan e.g. CPU. That's why I brought up the issue on TCASEMAX as there are no other references as to how hot a CPU can be before it is considered unsafe! |
May 20 2007, 02:12 PM
#9
VIP
4,809 posts Joined: Jan 2005 |
hhhm. i think there is sufficient info here.
thread closed pm me if anything |
| Change to: | 0.0164sec
0.30
5 queries
GZIP Disabled
Time is now: 20th December 2025 - 05:06 AM |
