> Luggage check in.airasia, Need advise
TSkokanchai
post Aug 3 2017, 03:31 PM, updated 9y ago
Just brought a new size 24 inch luggage
So is it allow to handcarry into plane cabin?
I know the weight is less hen 7kg.should be ok for me
Just concerned abit the size.
I am a bit dilemma
Does it alow the size 24 inch hand carry into plane cabin
Cos I don't wanna last minute buy the check in luggage cabin with expensive pricing
Somebody please advise.
This post has been edited by kokanchai: Aug 3 2017, 03:32 PM
mafioso
post Aug 3 2017, 03:32 PM
i think as long as not over 7kg
u can bring it in
or something
ISawYou
From: Tawau -> Menumbok, Sabah(Land Below The Wind)
no. 24 inch confirm cannot
amxpayne67
post Aug 3 2017, 03:33 PM
The Coon
QUOTE(mafioso @ Aug 3 2017, 03:32 PM)
u can bring it in
or something
QUOTE(ISawYou @ Aug 3 2017, 03:32 PM)
this.
TSkokanchai
You confirm bro?
fuddle_duddle
post Aug 3 2017, 03:35 PM
you can read it here
https://www.airasia.com/ask/template.do?id=61
WaCKy-Angel
PeACe~~
iinm 20" or 22" only
However its actually see luck. If the the jaga stop u then u jialat.
alextan99
Wassup
bro come on ... use your logic a bit. The max size allowed in cabin is 21inch.
ISawYou
post Aug 3 2017, 03:36 PM
QUOTE(kokanchai @ Aug 3 2017, 03:33 PM)
You confirm bro?
QUOTE(fuddle_duddle @ Aug 3 2017, 03:35 PM)
there someone posted already. you need to comply both the SIZE and WEIGHT rules for hand carry baggage.
zeese
post Aug 3 2017, 03:40 PM
Warning Level
dont buy that bag lorr.. buy a smaller one.. so, less heart pumping everytime you check in...
lyc1982
post Aug 3 2017, 03:46 PM
ExpectNoMercy
24"...prepare to pay for luggage check-in
Feugo
> go klia2
> find this stupid thing
> test first before check in
https://forum.lowyat.net/topic/4218161/all
This post has been edited by Feugo: Aug 3 2017, 03:47 PM
acbc
post Aug 3 2017, 03:54 PM
24 inch confirm cannot carry-in. Only 21 inch below can. Kena b4.
SUSneoFluidic
post Aug 3 2017, 04:02 PM
QUOTE(Feugo @ Aug 3 2017, 03:46 PM)
> go klia2
this
ekoh
post Aug 3 2017, 04:05 PM
24inch is not cabin sized luggage, too big
SUSMatrix
post Aug 3 2017, 04:08 PM
King of Char Siew!
Dont be an arsehole. Both size and weight needs compliance. Your big bag just buy luggage check in .
TSkokanchai
post Aug 3 2017, 04:11 PM
hey guys
i just measure my new luggage
Height is 58cm width is 38cm
slight over abit.
Standard need
Height 56cm and width is 36cm
ckokwei
post Aug 3 2017, 04:12 PM
is okay. you may try to bring in. but 99% you will keep yourself even more busy. either throw away your luggage if no time allow, or if there is time, you will need officer to bring you to the check in counter and check in your luggage.
a NO for 24inch to cabin. (only can check in)
cheer!
AyamBlend
post Aug 3 2017, 04:15 PM
20 inch cabin bag la
0.0163sec    0.56    6 queries    GZIP Disabled
Time is now: 15th December 2025 - 08:19 PM
