 IDE to SATA Bridge Converter, .. Welcome to Discuss
TSintune
post Apr 1 2007, 11:18 PM, updated 19y ago
LOWYAT 1ST MALAYSIA 2nD
I have just bought Biostar Tforce 965PT and I noticed that mostly new Mobo with Intel 965PT chipset thesedays comes with only 1 IDE port..the rest are SATA slots.
I still own a DVD-RW drive which still utilise IDE and also 200GB WD IDE drive which i dont want to upgrade to SATA.
Dilemma was to put the 200GB IDE and the DVD-RW on 1 IDE cable. This is because performance and lag problem occurs whilst accessing the DVDR-W .
I was searching for IDE to SATA bridge converter which can either convert either my 200GB IDE or the DVD-RW drive into SATA compliant drive.
After searching thru google..i found the product..
This product saved my from buying a SATA DVR-W or a new SATA drive. Also i can save one of pci slot (if i use pci-IDE/raid)
Setting up was bit troublesome (jumper setting need to be set at master on drive) for this to work.
But all in all it works great! Btw i use the ide to sata converter on my DVD-RW drive rather then my 200GB ide.
Anyone try this device before..? IS it selling at lowyat?
This post has been edited by intune: Apr 2 2007, 08:09 AM
AMDunFreak
post Apr 1 2007, 11:23 PM
I am the best!
how much you bought it?
TSintune
post Apr 1 2007, 11:24 PM
QUOTE(AMDunFreak @ Apr 1 2007, 11:23 PM)
I bought it around $15 SGD
sopen2003
post Apr 1 2007, 11:42 PM
nice product.. how about u do a bulk on this.. biggrin.gif maybe got many buyyer..
TSintune
post Apr 1 2007, 11:48 PM
QUOTE(sopen2003 @ Apr 1 2007, 11:42 PM)
Dunno if i want to a bulk.. i dun if i can cheaper i probably consider. Just want to share this great product.
Im still testing it. Before this I did a test on my IDE drive..but perfomance increase only a bit.. 1-2%. Thats why i connect it to my DVDRW drive.
Actually item look more like this :
and draws power from floppy type power connector. Doesnt come with any manual or instruction. only with 1 sata cable and floppy to 4 pin power adapter.
Also uses Jmicron SATA controller chipset. after install reboot dvd-rw now detected as SATA device.. rclxms.gif
This post has been edited by intune: Apr 1 2007, 11:54 PM
mulut99
post Apr 1 2007, 11:52 PM
I am using 2pcs of this product. Running well on my IDE HDD.
I still wanna buy 1 more but hard to find it here nowaday.
This post has been edited by mulut99: Apr 1 2007, 11:56 PM
TSintune
post Apr 1 2007, 11:56 PM
QUOTE(mulut99 @ Apr 1 2007, 11:52 PM)
I am using 2pcs of this product. Running well on my PATA HDD.
I still wanna buy 1 more but hard to find it in Malaysia nowaday.
Where did u get it? I found it at a retail store in Brunei .. just wondering if selling in lowyat maybe can get it cheaper.
sopen2003
post Apr 1 2007, 11:58 PM
does it easy to use?? windows friendly right??.. got hang-up during transfer/copy/paste any data/files??
u using this on ur main partion (setup OS), or just for backup hdisk.. storage data..
bro.. got link/web about this product??
mulut99
post Apr 1 2007, 11:59 PM
QUOTE(intune @ Apr 1 2007, 11:56 PM)
1st one get it from my friend and 2nd one i bought it at a Computer Shop at Cheras but no more selling it now. The 2nd one is the same like the picture u post but got a plastic casing. It is a Silicon Image product.
This post has been edited by mulut99: Apr 2 2007, 12:00 AM
TSintune
post Apr 2 2007, 12:01 AM
QUOTE(sopen2003 @ Apr 1 2007, 11:58 PM)
Setting up actually is difficult.. because have to play with device jumpers. I finally got it working if i set my device jumper on the drive at MASTER. (no instruction manual rclxub.gif )
Once setup properlly works great! I now use it for my LG-4163B DVDRW and have now burn many DVD without problem. rclxms.gif
Added on April 2, 2007, 12:03 am
QUOTE(mulut99 @ Apr 1 2007, 11:59 PM)
Maybe i look for it myself at lowyat see if available. The one i have uses Jmicron controller.
This post has been edited by intune: Apr 2 2007, 12:03 AM
sopen2003
post Apr 2 2007, 12:05 AM
QUOTE(intune @ Apr 2 2007, 12:01 AM)
can use Cable Select (CS) right?? ur mobo is sata2 or sata?? bios detect same device (LG-4163B) u plug on dvdrw on this converter..
mulut99
post Apr 2 2007, 12:06 AM
Saw it at All IT LYP but no confident on it cause it is running with dunno what chip sweat.gif .
This post has been edited by mulut99: Apr 2 2007, 12:07 AM
TSintune
post Apr 2 2007, 12:07 AM
I tried cable select wont work.. anyways its on MASTER now. but i dun think it maters because its on SATA .
Bios detect as LG-4163B SATA . My mobo is SATA2/1 compatible.
Added on April 2, 2007, 12:09 am
QUOTE(mulut99 @ Apr 2 2007, 12:06 AM)
I had to peel a QC CHECK sticker on the chip to find out the brand chipset. I prefer SIliconImage then Jmicron for some reason. blush.gif
I also notice when sometimes reboot my mobo doesnt detect the device..after shutdown properly and power up again..device detect properly.
Your have same problem?
This post has been edited by intune: Apr 2 2007, 12:11 AM
zeroglyph
post Apr 2 2007, 12:12 AM
woot!!! senior member now?
just to share experience, i bought one of this things before too. it didn't work. brought it back to the shop, even they can't get it to work. mad.gif. ended up using the raid interface for my 2 hd. good to know that there are some that really works.
btw, mine was with Jmicron chip.
This post has been edited by zeroglyph: Apr 2 2007, 12:28 AM
sopen2003
post Apr 2 2007, 12:14 AM
TSintune
post Apr 2 2007, 12:15 AM
QUOTE(zeroglyph @ Apr 2 2007, 12:12 AM)
just to share experience, i bought one of this things before too. it didn't work. brought it back to the shop, even they can't get to work.  mad.gif. ended up using the raid interface for my 2 hd. good to know that there are some that really works.
I almost gave up too.. but i brought it back to the shop's technician and he managed to make it work..according to him need to experiment with jumpers. with some patience i got it too work after few minutes.
The reason why i uses this rather then my raid card is because i cant disable my raid card bios check (takes 4-5secs on boot) mad.gif .. with this device boot is so much faster now..and i can save 1 pci slot. biggrin.gif
This post has been edited by intune: Apr 2 2007, 12:17 AM
mulut99
QUOTE(intune @ Apr 2 2007, 12:07 AM)
Tried on 2 type of HDD. WD and Maxtor.
For WD i didnt put any jumper but for Maxtor HDD must set jumper to MASTER. Weird sweat.gif .
Both HDD i use it for storage.
This post has been edited by mulut99: Apr 2 2007, 12:17 AM
TSintune
post Apr 2 2007, 12:19 AM
QUOTE(mulut99 @ Apr 2 2007, 12:15 AM)
exactly .. need to experiment on jumper settings.. i think works differently on diff brand of HDD.. no wonder no manual. doh.gif
mulut99
post Apr 2 2007, 12:20 AM
QUOTE(intune @ Apr 2 2007, 12:19 AM)
U are right.
edwin3210
post Apr 2 2007, 12:28 AM
lll
Hey TS, where u bought it? i;ve be lookin for it for as long as i live (for a year..lol). i look around in lyn but cant find any. really hope if u can do bulk. or maybe COD. i really interested on this product.
mulut99
post Apr 2 2007, 12:32 AM
Here is the picture of my PATA to SATA dongle. Hope someone can bring it in cause i need 1 more sweat.gif .
This post has been edited by mulut99: Apr 2 2007, 12:34 AM
Attached image(s)
Attached Image Attached Image
TSintune
post Apr 2 2007, 12:43 AM
QUOTE(mulut99 @ Apr 2 2007, 12:32 AM)
I like the casing..protects the PCB.. my version doesnt have the plastic casing..sometimes i worry when i try to remove it from PATA connector
I think my version works both ways.. IDE to SATA or SATA to IDE (why wud u wanna do that?) unless u have only sata hdd and have limited sata slot but many ide slot.. doh.gif
This post has been edited by intune: Apr 2 2007, 12:47 AM
mulut99
post Apr 2 2007, 12:47 AM
QUOTE(intune @ Apr 2 2007, 12:43 AM)
Got a green led when running the HDD. It is good running at eSATA motherboard.
TSintune
post Apr 2 2007, 12:49 AM
QUOTE(mulut99 @ Apr 2 2007, 12:47 AM)
Mine has 3 led's .. havent tried it with E-sata (mobo doesnt have feature). I cud get PCI-E X1 card if available..and try the e-sata feature.
E-J@1
post Apr 2 2007, 04:17 AM
Capital Eâ„¢
Here's my PATA to SATA Converter:
Gigabyte [OEM Product] - Got 2 units of this converter brows.gif both using on DVD Burner
Abit Serillel 2 - Got 1 unit for this converter brows.gif Using on my old HDD biggrin.gif
so far no problem at all, just set the drive's jumper to Master, hook it up, then badaboom badabam, all set laugh.gif
btw, really notice the different when use it on old HDD, for burner's no different i think hmm.gif just ease the cable management for me thumbup.gif
casperito
post Apr 2 2007, 04:42 AM
221.133.99.99
hmm.. interesting stuff... i need one of these... where can i find it?? if anyone can order me one of these, PM me...
TSintune
post Apr 2 2007, 08:02 AM
QUOTE(E-J@1 @ Apr 2 2007, 04:17 AM)
Great!..I like the black plastic casing... Where did u get those and price pls.
As mention earlier.. i dun see major improvement on performance maybe 1-2% on IDE HDD but definitely ease cabling in my PC..
GuyverTM
post Apr 2 2007, 08:13 AM
wat is the price at ALL IT
sniper on the roof
post Apr 2 2007, 09:23 AM
20k VIP Club
VIP
There's 2 types... one plugs into the mobo's IDE port to turn it for sata output... the other is the one you guys discussing here... to turn IDE device into SATA.
TSintune
post Apr 2 2007, 10:10 AM
My next purchase.. see if i can find it locally first.
Product Features
* Connect up to 5 SATA or SATA II hard drives via 1 SATA port
* Up to 3Gbits/sec
* Compatible with Host Controllers using the SiI3124 and SiI3132 chipset. Click here for a list of Host Controllers using these chipsets.
* Drives can be configured as RAID 0, 1, 0+1, 5 or JBOD when connect to one of the Addonics RAID5 controllers with PM support
* Designed to be mounted onto any available standard or low profile add-in card bracket on a standard desktop case.
* Compliant with SATA II specification
* Support hot swap
* Supports SATA optical drives
* OS independent (setting of the Port Multiplier depends on the control software of the controller.
* Port Multiplier support under Linux
zeroglyph
post Apr 2 2007, 10:21 AM
where did you get this? after past experience, gigabyte seems like a better choice than a no brand one. didn't even know gigabyte made these.
sniper on the roof
post Apr 2 2007, 10:32 AM
20k VIP Club
VIP
QUOTE(intune @ Apr 2 2007, 10:10 AM)
Product Features
    * Up to 3Gbits/sec
    * Support hot swap
Bah... this one more geng
http://www.lycom.com.tw/ST126DA.htm
Haven't got chance to use it yet... but imagine the potential it has for cable management for separate HDD compartment casings like the Lian Li Vseries. Don't need to PCI slots tongue.gif
TSintune
post Apr 2 2007, 11:49 AM
QUOTE(sniper on the roof @ Apr 2 2007, 10:32 AM)
nice.. an external storage server driven by 5 SATA2 HDD.. 2.5TB easily .. best part connected by e-sata.. rclxm9.gif
Read reviews here:
http://www.amug.org/amug-web/html/amug/rev...s/addonics/5x1/
This post has been edited by intune: Apr 2 2007, 11:55 AM
E-J@1
post Apr 2 2007, 12:35 PM
Capital Eâ„¢
QUOTE(intune @ Apr 2 2007, 08:02 AM)
that's Abit Serillel 2(tm) [Link]
...Where did u get those and price pls...
got it from a bulk organize by a forumer here, long time ago, 2-3 years back hmm.gif can't remember when, but i do remember who organize it icon_idea.gif it's Silpheed
try PMing him/her to do it again, iirc, the bulk was so quick, it didn't last for a week
price = RM38 each (Gigabyte & Abit)
...As mention earlier.. i dun see major improvement on performance maybe 1-2% on IDE HDD but definitely ease cabling in my PC...
[Link][Link][Link]
QUOTE(zeroglyph @ Apr 2 2007, 10:21 AM)
got it from a bulk organize by Silpheed
this is a OEM Product by Gigabyte, meaning u can't easily get it by simply order the things like say from E-Bay or any other shops... nod.gif
TSintune
post Apr 2 2007, 12:51 PM
QUOTE(E-J@1 @ Apr 2 2007, 12:35 PM)
Weird.. i search for the user u mention..and u mention the bulk was 2-3years back..his profile show he joined July 2006?
E-J@1
post Apr 2 2007, 01:00 PM
Capital Eâ„¢
QUOTE(intune @ Apr 2 2007, 12:51 PM)
errr, my mistake, typo error there, gonna type 1-2 years??? nod.gif really can't remember, but since u just mentioned bout joining date, it was last year (i also joined in 06) laugh.gif whistling.gif
TSintune
post Apr 2 2007, 01:59 PM
OK.. im off to Lowyat c if i can get some tmrw. I can get it here (brunei) but rather expensive SGD$15 .
gengstapo
post Apr 2 2007, 02:07 PM
Retired enthusiast
same here, end up just put it in the shelve collecting dust vmad.gif mad.gif
nowadays, i just get those hdd with sata interface
pr0b solve
zeroglyph
post Apr 2 2007, 04:42 PM
QUOTE(gengstapo @ Apr 2 2007, 02:07 PM)
pr0b solve
yeah, i bought mine at rm55. since the shop techs also can't prove the thing works, i get to change it with a DVD rom plus top up.
nevertheless, it's pretty cool if i could use converters to convert both my pata hds. right now casing is a mess with 3 IDE cable.
hui_ping
post Apr 2 2007, 07:22 PM
I'm using the same Abit too, use it on my old Maxtor 80GB for storage. The HDD perform slightly better than using IDE.
[Link][Link][Link]
Not 2-3 years la, only last year bought it form Silpheed.
Skylinestar
post Apr 2 2007, 08:05 PM
Mega Duck
so, this is the one sold in AllIT? did u set the jumper correctly?
zeroglyph
post Apr 2 2007, 08:51 PM
QUOTE(Skylinestar @ Apr 2 2007, 08:05 PM)
nope. i bought it at the mines IT city. tried everything. like i said, even the techs at the shop can't get it to work.
E-J@1
post Apr 2 2007, 10:23 PM
Capital Eâ„¢
QUOTE(hui_ping @ Apr 2 2007, 07:22 PM)
ya, remembered that, just forgotten how much time pass by doh.gif registered Sep06 with a thousand post, really forgotten about it, dat's why laugh.gif
Mooneyes
post Apr 2 2007, 10:27 PM
Time heals
looks ugly to me...should have covered those pin n solder with plastic or sumthing tongue.gif
hui_ping
post Apr 2 2007, 11:56 PM
QUOTE(E-J@1 @ Apr 2 2007, 10:23 PM)
How is your Abit? Mine can not be use with my NEC DVDRW, windows won't detect. But it is working fine with HDD.
cre8tif
post Apr 3 2007, 07:21 PM
WoW
there's one draw back, these converters either way have to take away one floppy type power connector.
so it means the more old IDE devices you have, the bigger the PSU u have to get to get so many floppy power splitters.
TSintune
post Apr 4 2007, 09:21 AM
Found the IDE to SATA at Cabletron Lowyat.. selling it for RM55 and 50 after discount .. doh.gif
I think goona find other sources for supply..
Linkcraft
post May 2 2007, 11:41 AM
Hey,
Our company do selling SATE to IDE convertor,
Pls click below link for complete info,
http://www.sunix.com.tw/it/en/Product_Deta...a_id=34&sid=498
Interested ? Kindly PM me for pricing.
nickky_becks
post May 9 2007, 04:20 AM
i oso will go low yat to look for 1 tomolo...
coz onli have 1 IDE slot...make me feel so sad coz got 2 Rom but onli can use 1...haizzzzzzzzzz
TSintune
post May 10 2007, 01:04 AM
QUOTE(nickky_becks @ May 9 2007, 04:20 AM)
Great..been using it for 2 months now.. all a-ok.
jaya_pc87
post May 10 2007, 02:22 AM
Workaholic Mode on
can find them all over lowyat ? Range from RM45-55 here in melaka also got ady
that thing is on market for over 1 1/2 year and now only ppl start noticing it ...
super macgyver
post May 11 2007, 12:07 AM
★~13k Spam Club~★
QUOTE(Linkcraft @ May 2 2007, 11:41 AM)
Hey,
How much actually?
PowerSlide
post May 11 2007, 09:04 AM
i found one on my local pc shop..comes with jmicron chipset on the converter..cost me rm45
it works but works in a rather unusual way..plug in everything start pc it cant be detected. Weird huh..den jus restart n b4 the mobo get to the point showing the mobo name press del to enter bios thing faster remove the power source to the converter n faster plug in back..den it can be detected
hav to do this all the time wen pc starts..not a very convenient way at all coz once shutdown kenot detect itself again
i no idea wat cause it..mebb the converter doesnt work tat well on sata2?
linkinstreet
post May 11 2007, 09:28 AM
Red Bull Addict
Moderator
nickky_becks
post May 12 2007, 02:23 AM
guys...good news i get...
i just bought 1 in The Mines here...
is a red small adapter and it just cost me RM 28...
and once i plug it...then everything work out great...btw...i was a bit frighten from the shop there...the next shop selling at RM 80 for same things,but once i ask next door then it sell onli RM 28...
PowerSlide
post May 12 2007, 06:15 PM
QUOTE(nickky_becks @ May 12 2007, 02:23 AM)
ur mobo sata2 or sata1?
nickky_becks
post May 12 2007, 06:20 PM
suppose is sata 1...coz is a old mobo...
mine still using intel 915 chipset...so suppose is sata 1 mobo...
bryanyeo87
post May 23 2007, 03:27 PM
Below the Belt
guys i got a supplier for this product, but he willing to supply for rm33 @5units bulk
i can do bulk, my price will be rm35, rm2 for yam cha money only...
will post a pic up when i get the sample.
edit:better news, u can use it as a host or device plug, that means can plug into mainbaord OR drive
This post has been edited by bryanyeo87: May 23 2007, 03:28 PM
joshuatly
post May 23 2007, 03:32 PM
hey, this one is interesting.
but too bad.
i cant found it at lowyat.
maiself
post May 26 2007, 01:53 PM
Pro Surfer
i oso looking for this 1, lastime mobo got 2 ide port so no problem, now only 1 ide... i still got 2 PATA HDD & IDE DVD rom so need a converter...
any1, PM me the kedai that selling those..
t3chn0m4nc3r
post May 27 2007, 12:41 PM
Teh Necron Lord
jolipoli81
post May 27 2007, 07:04 PM
Look at all my blinks
must be really careful of these things, u may burn your hdd IC...
i burnt mine before, using USB to SATA cable, somehow i manage to turn things back to normal...
ongbs
post May 31 2007, 04:34 AM
Who am I ?
QUOTE(intune @ Apr 4 2007, 09:21 AM)
I am selling 2 units of Abit brand here:
Abit SATA to IDE converters
0.0329sec    0.93    6 queries    GZIP Disabled
Time is now: 23rd December 2025 - 11:00 AM
