 [Solved] No sound through HDMI, Win 10 Pro x64
TSnill
post Jul 5 2016, 12:01 PM, updated 10y ago
Did a fresh install on a new hard disk.
The GPU was never tested if there is sound through HDMI.
Win 10 Pro x64
XFX RX 480
TV don't have sound. Headphone jack (motherboard) got sound.
Already performed windows update.
Running Crimson 16.6.2
TV is assigned as play back device.
Kindly advise on what to do.
QUOTE(nill @ Jul 5 2016, 05:17 PM)
can close thread. solved after disable all audio devices and enable all back in sound settings.
note that it's the only thing i tried.
This post has been edited by nill: Jul 6 2016, 08:34 AM
GKSComp
post Jul 5 2016, 12:06 PM
Driver updated?
TSnill
post Jul 5 2016, 12:07 PM
QUOTE(GKSComp @ Jul 5 2016, 12:06 PM)
Driver updated?
Using Rampage IV Gene. I got run the 2 available audio drivers in Asus support page. GPU driver is the latest.
This post has been edited by nill: Jul 5 2016, 12:09 PM
lmkeng83
post Jul 5 2016, 12:08 PM
QUOTE(nill @ Jul 5 2016, 12:01 PM)
Win 10 Pro x64
XFX RX 480
Switch your tv channels back and forth. It works for me.
TSnill
post Jul 5 2016, 12:11 PM
QUOTE(lmkeng83 @ Jul 5 2016, 12:08 PM)
noted. i will try that. i also haven't test the other 2 HDMI port.
alanshore
post Jul 5 2016, 12:14 PM
go change default output device in sound settings
GKSComp
post Jul 5 2016, 12:16 PM
This sound silly
- Have you switch up your volume?
- Have you plugin properly to your device?
- Have you tested your HDMI with other device?
- Try to run a driver updater
TSnill
QUOTE(alanshore @ Jul 5 2016, 12:14 PM)
If not mistaken, that option is grayed out. Already disabled and enabled back TV in sound settings.
TSnill
post Jul 5 2016, 12:18 PM
QUOTE(GKSComp @ Jul 5 2016, 12:16 PM)
This sound silly
- Have you switch up your volume? done
- Try to run a driver updater done
The rest i will do tonight.
DouchebegTan
post Jul 5 2016, 04:36 PM
did you check if you were using the HDMI oputput as your default??? right click the sound icon on the bottom right>playback devices> and right click your hdmi output as your default device.... holla
TSnill
post Jul 5 2016, 05:17 PM
junclj
post Aug 22 2016, 05:44 PM
You need to switch your playback sound to HDMI. Windows will not set your HDMI sound output as default. Right click on the speaker icon at the tray. Go into playback to change your default sound output to HDMI.
0.0182sec    0.59    5 queries    GZIP Disabled
Time is now: 12th December 2025 - 01:20 AM
