QUOTE(SCy2j @ Nov 18 2014, 10:10 PM)
Hi all, I bought a Z250 in July and I'm thinking of adding on an aftermarket exhaust.
I went to a big and famous motorcycle shop and they told me I should upgrade whole exhaust system (Yoshimura slip-on and linkage) for almost RM4,000.
They said that would add about 5hp more as they did a dyno test before.
However, when I went to another shop, that one told me there's no need to upgrade linkage, and that full upgraded system doesn't add more than 2-3hp.
This shop also told me that instead of buying expensive, well-known brand slip-on exhaust, I could just pay under RM1,000 for a good Thai exhaust and still get the same 1-hp boost that more expensive slip-on gives.
My question is a full upgraded exhaust system really would give you more power?
If not, and since all slip-on exhausts only add 1hp, should I just go for a quality Thai exhaust and not bother with well-known brands?
I'm not looking for just upgrading the sound of my bike, I'm actually interested in upping the engine output a bit more.
Ok here is my honest feedback. based on my years of experience in this field.
1. Muffler only adds a rough amount 0.5-5 hp to a bike based on the CC of the bike. (ciplak muffler only makes sounds and also maybe decrease in hp)
2. Full system adds roughly 1-15hp again depending on the cc of the bike. (forget about ciplak)
now... here's the cold hard fact. apologies if this sounds harsh a bit, but note that no pun is intended.
250cc can only go up to a certain level of HP, you can feel the small and subtle differences when you upgrade this and that, but the amount of money you need to fork out, is simply kerja bodo. further more when you sell the bike later, the price effect is not much of a difference. so best to leave it as is.
I would rather recommend that you look for a higher HP bikes, you get the best "bang" for your dollar.
but if there is a possibility that a modified 250cc bike can beat the shit out of a 1000cc bike without costing almost or near the price of the 1000cc bike, then your investment is surely worth it. but then again ada ke?
Not to discourage your intent for NFS (need for speed) feeling, i've been riding for way too long and seen too many unnecessary problems caused by aftermarket parts that only helps a bit. running the bike as is, is more cost effective as all items are design for efficiency. again 4k for a full system? might as well sell the 250cc+4k is almost half the downpayment for a 1000cc bike or even pehaps a cash buy for an older model 600cc-1000cc.
my humble thoughts.
