this is an incremental update and includes all changes since version 2.4 - unzip and then run MusicBee_Setup_2_5_5491.exe
- speed improvements when loading panels
- sorting Album, Artist, Album Artist and Title (improvements should be noticable for music collections > 30,000 tracks)
- Album and Tracks panel (probably only noticable for very large music collections)
- browsing using the Artwork Layout with Artist pictures
- improved starting and ending silence detection (option in the Player preferences), especially for MP3 files
- hotkey to Reset and active Column Browser, Thumbnail Browser, Library Explorer or text filter that is active ie. to show all files in the panel
- the main menu has been re-arranged
- a number of commands now in the File menu
- "Rescan/ Add Files" is now called "Scan Folders for New Files"
- new "Add Files to Library" to add files from a dialog
- new "Playlists/ Import Playlists" command to import external playlists
- the above items can still be acheived using drag/ drop - its more for new users
- right click/ Send To/ ... is now implemented for Playlists and Computer folders in the left navigator
- the library auto-organise function now checks the "dont reorganise files with missing tags" option when sending files to the library. You will be alterted when files have missing naming template tags and those files will not be auto-organised unless the option is disabled
- improvements to the Visualiser and Theater Mode plugins where you can specify a specific screen for Fullscreen mode and specific which mode the display will start (Normal, Desktop or Fullscreen)
- The "Unplayed Episodes" and new "Recent Updates" podcast auto-lists respect any podcast category filter that is active
- the comment field in the Tag Editor has been increased in size, and the Tag Editor should display much better with high DPI screens
- files in a panel can now be sorted by the "Highlight" field, but only by clicking the column header
- CD ripping can now be configured to rip directly into the music library (its the default for new users)
- the Tag Undo function now also includes changes to ratings
- the Tag Inspector now allows you to rearrange the order of multi-value tags
- the "expanded panel" in the artwork layout now supports pasting album pictures
- the "Output To" menu command has been enhanced to include any available UPnP devices (you need the UPnP plugin for that)
- a few bug fixes for the new device Synchronisation Settings and Preview panels
- various other bug fixes
- this is the last planned beta with functional changes for the 2.5 series, other than any bug fixes and some requested skinning enhancements
translator file - updated new.txt file (this file is only used by translators and not required for the MusicBee application update):
http://www.mediafire.com/download/s61c097pngneint/new2.5.txt
