But I am newbie in this, can anyone roughly guide me through this process?
Thanks.
*mod if you find this topic irrelevant or posted wrong sect pls move it. Thanks.
Web Applications How to install a forum?, I.e. SMF
Jun 13 2006, 02:32 PM, updated 20y ago
#1
9,257 posts Joined: Aug 2005 From: Not so sure myself Status: 1+3+3=7 |
I found a free webhosting and I want to try to install SMF.
But I am newbie in this, can anyone roughly guide me through this process? Thanks. *mod if you find this topic irrelevant or posted wrong sect pls move it. Thanks. |
Jun 13 2006, 02:45 PM
#2
52 posts Joined: May 2006 |
Jun 13 2006, 02:49 PM
#3
QUOTE(abraham.P @ Jun 13 2006, 03:45 PM) Emm... i'm not using those. I wanna try those PHP forum codes... Is it just upload the whole thing into the webserver and install it?? Thanks in advance. |
Jun 13 2006, 02:55 PM
#4
Jun 13 2006, 03:01 PM
#5
QUOTE(abraham.P @ Jun 13 2006, 03:55 PM) Thanks a lot |
Jun 13 2006, 03:05 PM
#6
6,238 posts Joined: Sep 2005 From: Kuala Lumpur |
just upload the forums file into your webserver, then do some CHMOD settings on the files, then you will be instructed to create a MySQL database and after that, run the forum installer file
Jun 13 2006, 03:06 PM
#7
QUOTE(karhoe @ Jun 13 2006, 04:05 PM) just upload the forums file into your webserver, then do some CHMOD settings on the files, then you will be instructed to create a MySQL database and after that, run the forum installer file Is it the same for free CMS? Just upload and install and config?As my Uni comp cannot access to folder[restriction], I haven't tried it out... So dunno... Thanks. |
Jun 15 2006, 09:42 AM
#8
310 posts Joined: Jan 2006 |
yes, simply upload the files into your site and chmod the relevant directories. Do not anyhow chmod as it might leave a backdoor to hackers.
If you're looking for a good CMS, try joomla or mambo. Feel free to pm me if you got any questions. |
Jun 15 2006, 10:41 AM
#9
QUOTE(johntxy @ Jun 15 2006, 10:42 AM) yes, simply upload the files into your site and chmod the relevant directories. Do not anyhow chmod as it might leave a backdoor to hackers. What is chmod??? If you're looking for a good CMS, try joomla or mambo. Feel free to pm me if you got any questions. Ok, I'll pm you if I face probs, thanks in adv. |
Jun 15 2006, 03:10 PM
1,168 posts Joined: Jun 2006 |
Jun 15 2006, 03:27 PM
427 posts Joined: Jun 2005 |
QUOTE(eXPeri3nc3 @ Jun 13 2006, 02:49 PM) Emm... i'm not using those. I wanna try those PHP forum codes... for php forum try phpBB2, just upload all the files into your hosting and create a blank database.Is it just upload the whole thing into the webserver and install it?? Thanks in advance. then just run a setup file to create your personal forum. i just did one and its very easy. http://forum.picrobot.com |
Jun 15 2006, 03:28 PM
1,399 posts Joined: Jan 2003 From: Destiny Island |
does ur free webhosting gives u any database?
This post has been edited by Christopher_LKL: Jun 15 2006, 03:29 PM |
Jun 15 2006, 04:12 PM
VIP
1,889 posts Joined: Jan 2003 |
QUOTE(eXPeri3nc3 @ Jun 13 2006, 04:32 PM) I found a free webhosting and I want to try to install SMF. Check the guide here: http://docs.simplemachines.org/index.php?b....0;sort=subjectBut I am newbie in this, can anyone roughly guide me through this process? Thanks. *mod if you find this topic irrelevant or posted wrong sect pls move it. Thanks. QUOTE(shiroikun @ Jun 15 2006, 05:10 PM) It is to change permissions of files or directories on *nix based machines. Commands and explanation: http://en.wikipedia.org/wiki/Chmod |
Jun 15 2006, 09:58 PM
QUOTE(shiroikun @ Jun 15 2006, 04:10 PM) Hmmm....QUOTE(Christopher_LKL @ Jun 15 2006, 04:28 PM) Yea, I can create one...![]() But dunno how to set it... QUOTE(shockw@ve @ Jun 15 2006, 05:12 PM) Check the guide here: http://docs.simplemachines.org/index.php?b....0;sort=subject shockw@ve, can those files be putted into a folder e.g. Forum?It is to change permissions of files or directories on *nix based machines. Commands and explanation: http://en.wikipedia.org/wiki/Chmod From the guide it says yes, but how about the install.php? Should it be in the Forum folder or just upload it? I got an error that day... |
Jun 15 2006, 10:16 PM
Moderator
10,308 posts Joined: Jan 2003 From: Kuala Lumpur |
QUOTE(eXPeri3nc3 @ Jun 15 2006, 09:58 PM) Hmmm.... just make sure that you keep the forum structure (directory and stuff) intact without changing anything while uploading the files to the server.Yea, I can create one... ![]() But dunno how to set it... shockw@ve, can those files be putted into a folder e.g. Forum? From the guide it says yes, but how about the install.php? Should it be in the Forum folder or just upload it? I got an error that day... |
Jun 16 2006, 07:58 PM
Edit - Problem Solved. Thanks.
This post has been edited by eXPeri3nc3: Jun 16 2006, 08:03 PM |
| Change to: | 0.0146sec
0.49
5 queries
GZIP Disabled
Time is now: 25th November 2025 - 05:31 AM |
