QUOTE(low yat 82 @ Dec 3 2012, 02:16 PM)
buy from owner lo. 25-30k is fair value of d car.
year 05-06
hows s spare part for kango?
btw, a rough google in mudah, shows most 2nd hand r from company car. guess d condition r pretty bad since its company car.
n also issit 3 row car or 2 row? coz i see d pic, its 2 row.. d back like for storage?
There are a few petrol 1.4 auto that are non commercial. I bought one that was used as a family car, great condition, 5 years old, 25k. Always serviced at the SC, always on time.
The manual 1.5 diesel has better performance and is very economic, but was only sold commercially
Spare parts are ok IF you can get them from Singapore. Then you can chose between original and non-original, and prices are much better than in Malaysia. Also almost everything got stock. If you have to get through TCEAS you may have to wait, to be honest. So ideally you have contacts in SG or can travel there. Otherwise an Avanza may be a wiser choice, not sure.
2 row, with an optional 3rd row bench. Some cars have it, some not. You can remove the bench to make more space, but reinstalling can be difficult if the screw drops (I asked the SC to weld them to the car...
The car can lean a bit in corners (if you drive fast), and there is oversteering if you really push it (I do have Michelin XM2, which are rather rubbish for fast driving). But I find the handling to be rather unterrifying and comfortable, even at 140-150. The gearbox is of the "what on earth is it thinking" sort (Renault claims it is intelligent and learns... must be a mentally challenged one), and being a 4 speed performance is... well, it's not a sports car. I drive it pretty hard and get around 10-11l/100km, but I often accelerate full throttle (and usually I'm the fastest). The Kangoo has 75 hp. Don't expect it to be fast... top speed probably 140-150. But it won't scare you at those speeds.
The Alza is quieter, but less comfortable.
It was also designed to be easy to maintain and repair, changing the wing mirror can be done in a minute, with only one screwdriver. Plastics are robust, but feel a bit cheap.
I have heard many positive comments by passengers, and all the critical comments by family uncles and aunties died down once they have been passenger. Even people who drive VW or BMW. Girls also seem to like it... the design. It's cute.
(Well, Australian girls anyway). Some passengers consider buying one.
In any case all I am suggesting is finding one and test driving it. Also do the same with the Avanza and whatever other options there are (Fiat Multipla? Well, if you are blind anyway). The Kangoo is very popular in Europe, not just with companies. If you prefer the Avanza, by all means get one. Just don't think the Avanza is the only option on the market.
Hm. I can list what I have changed. Owned it for 2 years now, bought when it was 5 years old (with 80k on the clock, now 105k).
At 80k catalytic converter was replaced by a not so good, not original one. More like a silencer
. Original ones are damn expensive. Around 7k
Paid way less than that (didn't know I could go to SG back then, maybe otherwise it would have been more affordable.) Auto gearbox btw. around 6k, but I haven't had to change it. The pump for the front windscreen washer was already broken when I bought it, replaced it. Only part I ever bought from the SC (previous owner agreed to pay). At 90k the motor for the central locking in the boot failed, got one for like 30 SGD from a Singaporean chop shop. Also some rubber parts to keep the steering and suspension system clean were replaced. At 100k rear brake cylinder and the thing that presses against the drum were replaced, front brake pads also. Engine mounting and gearbox mounting. Absorbers changed (I think... small parts? Rubber IIRC? Not the big shock absorbers). Power steering switch changed (raises the idle when full lock... not really necessary to change). All changes except for the catalytic converter were done at the SC, they give me the parts number so I can look for parts elsewhere. Sometimes original, sometimes not, they don't mind (and non original can be much cheaper). I also have the private phone number of the service advisor, so whenever there is something I can contact him directly.
I think these things are all rather reasonable, especially since I do make use of the decent suspension. I don't go like a snail over speed bumps for example. There is no need to. In the Rusa I take off at 10 km/h, in my car 20 km/h not even uncomfortable. Up and down, that's all.
Btw. when new the Kangoo was around 70+k, so a bit more than the Avanza at the same time. There are some with a rather nice looking leather. If possible also look for a unit with the 2nd row aircon blower. You'll want it. Really. I do.
Added on December 3, 2012, 10:25 pmQUOTE(kenny79 @ Dec 3 2012, 12:00 PM)
I'm just shop a used avanza 1.3 m 2007....used for week already quit ok with it.
What do you mean? You drove an Avanza for a week, and are already fed up with it?
This post has been edited by kadajawi: Dec 3 2012, 10:25 PM
