Xbox360 1080P problem on Panasonic THL42U38K, XBOX360 and LCD
Jul 4 2011, 08:47 PM, updated 15y ago
#1
214 posts Joined: Oct 2008 |
Hi, just get myself one 42inch panasonic Full HD LCD from SenQ, having raya promotion. I am looking forward for the Full HD experience on the XBOX 360, but strangely enough when i change the display to 1080p, the TV do detect the signal as 1080P/60 HZ but the screen start to flicker and have artifacts running thru the screen, the mode setting like 720P, 1080i was ok . Anyone encounter this type of problem? Is it i am bad luck to get an faulty panny on the first day ?
Jul 4 2011, 08:54 PM
#2
1,006 posts Joined: Jan 2007 |
What cable did you use to connect your console to TV?
Jul 4 2011, 09:01 PM
#3
3,761 posts Joined: Oct 2005 |
Your HDMI cable does not support 1080p signal. I've encountered the same situation before. Try swapping your HDMI cable to test.
This post has been edited by Thrust: Jul 4 2011, 09:04 PM |
Jul 4 2011, 10:09 PM
#4
QUOTE(Thrust @ Jul 4 2011, 09:01 PM) Your HDMI cable does not support 1080p signal. I've encountered the same situation before. Try swapping your HDMI cable to test. Hi, thanks for replying :-)..never though of problem is from the HDMI cable? i bought 2 HDMI cable from Carefour.. One long and one short, the long one is causing the problem, the short one works perfectly. The graphic is really kick ass, panny provide a superb tv :-)...U guys are great..good hellp :-) thank you very much |
Jul 5 2011, 01:17 AM
#5
502 posts Joined: Dec 2006 |
hmm. never had any problem even with a $10 hdmi cable. whats your dashboard version
Jul 5 2011, 08:47 AM
#6
1,844 posts Joined: Jan 2003 From: Kingdom of Sarawak |
if long one (>3meter) you need a better quality one, due to the risk of digital drop-outs
if less than 3m, any RM10 HDMI cable will do just nice btw... samsk, we are all still waiting for your review of your MONSTER HDMI cable, do show us the BIG difference between the cheapo cable and your expensive MONSTER HDMI cable |
Jul 5 2011, 09:45 AM
#7
1,374 posts Joined: Jun 2008 From: Red Comet |
I think i know wat happen, it seems happen same thing on my Sony LCD TV wen i plug in to my PC, having some weird issue of refresh rate.
I fix it with updating my TV firmware, via USB. Try google for your TV model firmware and update it. Mine was updating the HDMI version.. and it fix the problem. You may buying an old stock from senQ, so it may not be updated with latest firmware. Added on July 5, 2011, 9:46 am QUOTE(Rolland @ Jul 4 2011, 10:09 PM) Hi, thanks for replying :-)..never though of problem is from the HDMI cable? i bought 2 HDMI cable from Carefour.. One long and one short, the long one is causing the problem, the short one works perfectly. The graphic is really kick ass, panny provide a superb tv :-)...U guys are great..good hellp :-) thank you very much did u notice the HDMI cable was 1.3 or 1.2?the working fine ones was 1.2 or 1.3? This post has been edited by Edison83: Jul 5 2011, 09:46 AM |
Jul 5 2011, 10:14 AM
#8
3,390 posts Joined: Feb 2005 |
It's scary that we've come to a point where we need to update the TV's firmware!
But anyway, yes.. there have been MULTIPLE versions of the HDMI cable, and I do believe the cheapo brands usually don't say what version they are. So it's likely you've gotten a mismatched version cable. Oh.. here's something that tries to explain it... half of it I dont understand though. http://en.wikipedia.org/wiki/HDMI_cable#Cables |
Jul 5 2011, 02:01 PM
#9
QUOTE(marauderz @ Jul 5 2011, 10:14 AM) It's scary that we've come to a point where we need to update the TV's firmware! Hi, thanks for all the opinion. I have check the box of the HDMI, nothing is written on the box which version of HDMI cable. My last update xbox firmware is the one which enable USB storage, i haven't bought any game since then. Hear of the new dash board which enable kinect function will cause some old game to cease function and need to replace xbox with microsoft, don't dare to update itBut anyway, yes.. there have been MULTIPLE versions of the HDMI cable, and I do believe the cheapo brands usually don't say what version they are. So it's likely you've gotten a mismatched version cable. Oh.. here's something that tries to explain it... half of it I dont understand though. http://en.wikipedia.org/wiki/HDMI_cable#Cables |
Jul 5 2011, 02:09 PM
1,141 posts Joined: Apr 2010 From: USJ |
QUOTE(Rolland @ Jul 5 2011, 02:01 PM) Hi, thanks for all the opinion. I have check the box of the HDMI, nothing is written on the box which version of HDMI cable. My last update xbox firmware is the one which enable USB storage, i haven't bought any game since then. Hear of the new dash board which enable kinect function will cause some old game to cease function and need to replace xbox with microsoft, don't dare to update it my one got no problem meh.. still can play all the games, both new & old |
Jul 5 2011, 02:28 PM
1,450 posts Joined: Jun 2008 From: KK |
Jul 5 2011, 04:15 PM
476 posts Joined: Apr 2010 |
lol use monster HDMI , i use it on 32'' aquos ,very gooding yo
Jul 5 2011, 05:16 PM
VIP
727 posts Joined: Nov 2006 |
Jul 5 2011, 05:46 PM
Jul 5 2011, 09:02 PM
986 posts Joined: Aug 2007 |
QUOTE(Luqman999 @ Jul 5 2011, 04:15 PM) wat?? monster cable on a 32"? wat a waste...reality check: human eye wont be able to detect differences between fullHD (1080) or HDready(720) tv on a small screen... its a fact.. unless u seat 1" from the screen la...but who does?? |
Jul 6 2011, 07:42 AM
QUOTE(abundai @ Jul 5 2011, 09:02 PM) wat?? monster cable on a 32"? wat a waste... thats just ureality check: human eye wont be able to detect differences between fullHD (1080) or HDready(720) tv on a small screen... its a fact.. unless u seat 1" from the screen la...but who does?? is true about 1080-720 no different in small in in term of movie but this is games section, i damm clear can see the big different 1080p games on my PC between xbox 720p games... |
Jul 6 2011, 05:56 PM
QUOTE(Edison83 @ Jul 6 2011, 07:42 AM) thats just u a game designed for 1080p of cos got big differences with games that are designed to support 720p only...is true about 1080-720 no different in small in in term of movie but this is games section, i damm clear can see the big different 1080p games on my PC between xbox 720p games... i'm talking bout the same source/game played on a 32" 1080 or 720 tv... the screen is too small to be noticeable.. i'm not saying there's no difference... i'm saying human eyes wont be able to detect it... unless u sit really, really, really close.. and again i ask, who would seat 'that' close? tak sayang mata ke? |
Jul 6 2011, 11:19 PM
Jul 6 2011, 11:25 PM
Jul 7 2011, 09:26 AM
223 posts Joined: Nov 2008 |
get the monster cable you wont regret it. I am also using it on my lg 32inch so called full hd. Between the cheapo cable and monster cable difference that i encounter is better framerate. Especially playing eternal sonata you know how gay are the graphic eveything do a big combo sure my xbox hang awhile but with monster its as smooth as tofu then. Color also enchance and much more detailed for graphic wise. You will also notice alot of glowing effect damn chun.
This post has been edited by mushashi87: Jul 7 2011, 09:29 AM |
Jul 7 2011, 11:15 AM
VIP
QUOTE(Edison83 @ Jul 6 2011, 07:42 AM) thats just u The difference is, when you play a pc game, you're stuck sitting upright or even hunched gripping a mouse with one hand and wasd in the other hand stretching to reach some uncomfortable weapon change key or something, maybe 60-90 cm from the screen. This is a very stressful situation. Of course you'll notice that the game you're playing has those awful jaggy lines.is true about 1080-720 no different in small in in term of movie but this is games section, i damm clear can see the big different 1080p games on my PC between xbox 720p games... Now gaming on a 50" 6-7 ft away, being at one with a comfortable sofa, hands on a controller with every button easy to reach, you're far more chllaxed. Sure you notice jaggies, maybe the textures are a bit low res - but you don't care because you're just too busy chilling on your sofa and enjoying the game you're playing. I mean the bigger the screen, the more obvious the jaggies and textures are supposed to be right? Wrong, because you're to busy chilling. Added on July 7, 2011, 11:16 am QUOTE(mushashi87 @ Jul 7 2011, 09:26 AM) get the monster cable you wont regret it. I am also using it on my lg 32inch so called full hd. Between the cheapo cable and monster cable difference that i encounter is better framerate. Especially playing eternal sonata you know how gay are the graphic eveything do a big combo sure my xbox hang awhile but with monster its as smooth as tofu then. Color also enchance and much more detailed for graphic wise. You will also notice alot of glowing effect damn chun. lol first time I've heard of HDMI cable improving framerates. Placebo much?This post has been edited by Kidicarus: Jul 7 2011, 11:16 AM |
Jul 7 2011, 11:19 AM
Monster cable, it does everything without you knowing
QUOTE(Kidicarus @ Jul 7 2011, 11:15 AM) The difference is, when you play a pc game, you're stuck sitting upright or even hunched gripping a mouse with one hand and wasd in the other hand stretching to reach some uncomfortable weapon change key or something, maybe 60-90 cm from the screen. This is a very stressful situation. Of course you'll notice that the game you're playing has those awful jaggy lines. Well when playing with cheapo cable i feel like the game not smooth but after changing gaming is so smooth i think that should have something to do with framerate rite??tNow gaming on a 50" 6-7 ft away, being at one with a comfortable sofa, hands on a controller with every button easy to reach, you're far more chllaxed. Sure you notice jaggies, maybe the textures are a bit low res - but you don't care because you're just too busy chilling on your sofa and enjoying the game you're playing. I mean the bigger the screen, the more obvious the jaggies and textures are supposed to be right? Wrong, because you're to busy chilling. Added on July 7, 2011, 11:16 am lol first time I've heard of HDMI cable improving framerates. Placebo much? monster cables are truely good cables Added on July 7, 2011, 11:33 am QUOTE(gundamalpha @ Jul 7 2011, 11:19 AM) very true that why its call monster!! This post has been edited by mushashi87: Jul 7 2011, 11:34 AM |
Jul 7 2011, 11:35 AM
VIP
Jul 7 2011, 11:46 AM
Jul 7 2011, 11:59 AM
LOL
not again... another one thinking expensive HDMI cable will improve framerate placebo effect: you think you're ill, but doc didn't think so, so doc just prescribe you a normal vitamin pill tricking you it's medication you feel better after taking the "medication" while in actual fact it has nothing to do with the illness, it's just all psychology. |
Jul 7 2011, 12:11 PM
QUOTE(greyshadow @ Jul 7 2011, 11:59 AM) LOL i see so that a placebonot again... another one thinking expensive HDMI cable will improve framerate placebo effect: you think you're ill, but doc didn't think so, so doc just prescribe you a normal vitamin pill tricking you it's medication you feel better after taking the "medication" while in actual fact it has nothing to do with the illness, it's just all psychology. Before that have you tried monster cable in the first place?? if yes then ok I have a PLACEBO |
Jul 7 2011, 12:19 PM
yes, I have tried my fren's monster cable and my cheapo RM15 cable
i curi-curi swap my friend's monster cable with my RM15 cable, and he's still bragging his monster cable gave him superior, better graphic you should see his face when I show him what cable it is behind the TV I lost count how many times I've repeat this, HDMI is digital, consist of 1s and 0s, either it work or doesn't work, that all. There's no middle ground like better or worst. Period |
Jul 7 2011, 12:34 PM
QUOTE(greyshadow @ Jul 7 2011, 12:19 PM) yes, I have tried my fren's monster cable and my cheapo RM15 cable Ohhh SHIT I have a PLACEBO i curi-curi swap my friend's monster cable with my RM15 cable, and he's still bragging his monster cable gave him superior, better graphic you should see his face when I show him what cable it is behind the TV I lost count how many times I've repeat this, HDMI is digital, consist of 1s and 0s, either it work or doesn't work, that all. There's no middle ground like better or worst. Period This post has been edited by mushashi87: Jul 7 2011, 12:36 PM |
Jul 7 2011, 12:56 PM
VIP
user review from amazon:
QUOTE "I'd thought my 74" Pioneer Kuro and Sony ES Blu-Ray player were impressive enough, but this cable gave me a whole new swagger. I let it flop on the TV stand so everyone can comment on how long and thick it is. It's great, too - all the extra bandwidth Monster designed into it allows it to extract the best image from all your blu-rays. It extracts so much information it will even pull extra movies from discs that aren't supposed to be there. It is so cash. " |
Jul 7 2011, 01:07 PM
5,761 posts Joined: Jun 2007 From: J the great |
Jul 7 2011, 01:20 PM
Jul 7 2011, 05:01 PM
QUOTE(greyshadow @ Jul 7 2011, 12:19 PM) yes, I have tried my fren's monster cable and my cheapo RM15 cable true.. but dont forget, this 0's and 1's might get dropped along the way due to some factors... i curi-curi swap my friend's monster cable with my RM15 cable, and he's still bragging his monster cable gave him superior, better graphic you should see his face when I show him what cable it is behind the TV I lost count how many times I've repeat this, HDMI is digital, consist of 1s and 0s, either it work or doesn't work, that all. There's no middle ground like better or worst. Period with monster cables, they claim that their cables can send these signals with minimum loss.... true to some extend, but can our eyes really detects the small differences, let alone on a small 32" screen? that is the real question here... which is why, IMHO a monster cables is always a waste of money to spend on, unless you have a really 2X big screen .. and if u can afford a rm30K-50K 3D TV, would you still use a rm15 HDMI cables?? i know I wont..... |
Jul 7 2011, 05:05 PM
Actually it's not minimal signal loss, either you loss all or nothing. Signal loss normally only applicable to analog signals.
Jul 8 2011, 11:21 AM
68 posts Joined: Jan 2011 From: Island Of Jack Sparrow |
QUOTE(mushashi87 @ Jul 7 2011, 01:34 PM) Ohhh SHIT I have a PLACEBO Added on July 8, 2011, 11:22 am QUOTE(abundai @ Jul 7 2011, 06:01 PM) true.. but dont forget, this 0's and 1's might get dropped along the way due to some factors... Yes... Few thousand ringgit TV,original games but use cheapskate HDMI cable...with monster cables, they claim that their cables can send these signals with minimum loss.... true to some extend, but can our eyes really detects the small differences, let alone on a small 32" screen? that is the real question here... which is why, IMHO a monster cables is always a waste of money to spend on, unless you have a really 2X big screen .. and if u can afford a rm30K-50K 3D TV, would you still use a rm15 HDMI cables?? i know I wont..... Cakap keluar pun malu la dei... Added on July 8, 2011, 11:27 am QUOTE(greyshadow @ Jul 7 2011, 12:59 PM) placebo effect: you think you're ill, but doc didn't think so, so doc just prescribe you a normal vitamin pill tricking you it's medication you feel better after taking the "medication" while in actual fact it has nothing to do with the illness, it's just all psychology. You are not bleeding to death.. Just your imagination.. Take vitamin and your wound will recover itself. This post has been edited by samsk: Jul 8 2011, 11:27 AM |
Jul 8 2011, 11:32 AM
QUOTE(samsk @ Jul 8 2011, 11:21 AM) Added on July 8, 2011, 11:22 am Yes... Few thousand ringgit TV,original games but use cheapskate HDMI cable... Cakap keluar pun malu la dei... Added on July 8, 2011, 11:27 am Then doctor will said to the dying wounding people : You are not bleeding to death.. Just your imagination.. Take vitamin and your wound will recover itself. |
Jul 8 2011, 11:45 AM
QUOTE(greyshadow @ Jul 8 2011, 12:32 PM) Told you already.. My TV is HD Ready.. Different a bit only... If FHD, can see the different a lot.. My friend are using the same cable that we purchase from www.cable4hd.com.. His TV is FHD and mine is only HDR... So cant review on that cable much... Just the framerate are smoother than RM 25.00 cable.. Thats all.Graphic and TV dots,still need to use FHD only can notice the differents.. Wait for get Smart TV... Getting it few more months... Then review to you.. Dont worry.. If you are eager to get one, you may try it yourself.. I believe that you do have FHD TV.. Then you will notice the different. |
Jul 8 2011, 12:52 PM
QUOTE(samsk @ Jul 8 2011, 11:45 AM) Told you already.. My TV is HD Ready.. Different a bit only... so that why i notice the difference because i am in the FHD.If FHD, can see the different a lot.. My friend are using the same cable that we purchase from www.cable4hd.com.. His TV is FHD and mine is only HDR... So cant review on that cable much... Just the framerate are smoother than RM 25.00 cable.. Thats all.Graphic and TV dots,still need to use FHD only can notice the differents.. Wait for get Smart TV... Getting it few more months... Then review to you.. Dont worry.. If you are eager to get one, you may try it yourself.. I believe that you do have FHD TV.. Then you will notice the different. |
Jul 8 2011, 02:27 PM
QUOTE(Kidicarus @ Jul 7 2011, 11:15 AM) The difference is, when you play a pc game, you're stuck sitting upright or even hunched gripping a mouse with one hand and wasd in the other hand stretching to reach some uncomfortable weapon change key or something, maybe 60-90 cm from the screen. This is a very stressful situation. Of course you'll notice that the game you're playing has those awful jaggy lines. are we talking about the game reso or how comfortable sofa is??? Now gaming on a 50" 6-7 ft away, being at one with a comfortable sofa, hands on a controller with every button easy to reach, you're far more chllaxed. Sure you notice jaggies, maybe the textures are a bit low res - but you don't care because you're just too busy chilling on your sofa and enjoying the game you're playing. I mean the bigger the screen, the more obvious the jaggies and textures are supposed to be right? Wrong, because you're to busy chilling. Added on July 7, 2011, 11:16 am lol first time I've heard of HDMI cable improving framerates. Placebo much? btw the post u quote actually missing a TV word instead of "in" word i was refering to small TV like 32" or lower Added on July 8, 2011, 2:31 pm QUOTE(greyshadow @ Jul 7 2011, 11:59 AM) LOL u didnt read the 1st page arent you?not again... another one thinking expensive HDMI cable will improve framerate placebo effect: you think you're ill, but doc didn't think so, so doc just prescribe you a normal vitamin pill tricking you it's medication you feel better after taking the "medication" while in actual fact it has nothing to do with the illness, it's just all psychology. the ts was asking about the problem on his tv which almost similar case on mine the tv was just updated until support HDMI 1.2 only, my cable was HDMI 1.3 memang la ada view but getting weird refresh rate over many different games Added on July 8, 2011, 2:38 pm QUOTE(abundai @ Jul 6 2011, 05:56 PM) a game designed for 1080p of cos got big differences with games that are designed to support 720p only... yeah, i`m using 32" tv as my PC monitor and console use. Sit far far make me fell like i missing something in the gamei'm talking bout the same source/game played on a 32" 1080 or 720 tv... the screen is too small to be noticeable.. i'm not saying there's no difference... i'm saying human eyes wont be able to detect it... unless u sit really, really, really close.. and again i ask, who would seat 'that' close? tak sayang mata ke? so i sit close, memang i will notice the HUGE diferent between my PC game which runnign on 1080p and xbox on 720p... i just hate those jagged line, well, i know that all xbox game are mostly 720p so memang wont see any different on 720p and 1080p on same size tv. arent that common knowledge? also i said mostly xbox games are 720p, i didnt mean all, so what about those game really runnign on 1080p? This post has been edited by Edison83: Jul 8 2011, 02:38 PM |
Jul 8 2011, 02:57 PM
1,477 posts Joined: Jan 2003 |
I use some cheap locally made HDMI cable on my small screen. Ok only.
Jul 8 2011, 02:58 PM
128 posts Joined: Dec 2006 From: KL |
You guys argue like kids.
Remember, this is not a PS3 section. |
Jul 8 2011, 03:02 PM
Jul 8 2011, 03:35 PM
Haiyo... Just play the game... Dont care what other people said...
As long our eyes and our pocket is comfortable, thats fine.... |
Jul 8 2011, 03:55 PM
Jul 8 2011, 04:08 PM
Jul 8 2011, 04:11 PM
QUOTE(Edison83 @ Jul 8 2011, 02:27 PM) u didnt read the 1st page arent you? you didn't read the previous post arent you? the ts was asking about the problem on his tv which almost similar case on mine the tv was just updated until support HDMI 1.2 only, my cable was HDMI 1.3 memang la ada view but getting weird refresh rate over many different games my comments arent for TS QUOTE(Edison83 @ Jul 8 2011, 02:27 PM) Added on July 8, 2011, 2:38 pm yeah, i`m using 32" tv as my PC monitor and console use. Sit far far make me fell like i missing something in the game so i sit close, memang i will notice the HUGE diferent between my PC game which runnign on 1080p and xbox on 720p... i just hate those jagged line, well, i know that all xbox game are mostly 720p so memang wont see any different on 720p and 1080p on same size tv. arent that common knowledge? also i said mostly xbox games are 720p, i didnt mean all, so what about those game really runnign on 1080p? of cos you'll see major diff between them as PC is definitely superior, even if it's the same game for PC and Xbox Added on July 8, 2011, 4:14 pmanyway... i've lost count how many times I've shared this link already for those who haven't read and still think expensive HDMI cable does make a difference in graphic/frame rate quality, read it here: http://www.eurogamer.net/articles/digitalfoundry-vs-hdmi This post has been edited by greyshadow: Jul 8 2011, 04:14 PM |
| Change to: | 0.0321sec
2.37
5 queries
GZIP Disabled
Time is now: 23rd December 2025 - 09:08 PM |
