3 Pages  1 2 3 >Bottom
 Bad Breath, when i eat, my bb go away
TSsosostupid
post May 4 2011, 02:02 AM, updated 15y ago
anyone having bad breath problem?
im having real bad bad breath quite long already, cant seem to cure it, even after spamming tons of water.
i notice tat when im eating, my bad breath goes away, but after awhile it creeps back.
+ i also went to dentist, the smell is not coming from my teeth or gums.
hope to get some help here.
thankyou
post May 4 2011, 02:07 AM
Do you smoke?
Schampoo
post May 4 2011, 02:46 AM
how bout drink more water and listerine?
corrosion
post May 4 2011, 09:14 AM
did u brush ur tooth and tongue before u sleep?
DrBarbarian
post May 4 2011, 09:20 AM
Darren's Daddy
QUOTE(Schampoo @ May 4 2011, 02:46 AM)
drink listerine?? ewwww...........
corrosion
post May 4 2011, 09:28 AM
^ he meant gargled..
to TS, try chekcing up wiki:
http://en.wikipedia.org/wiki/Halitosis
nigelhanzo
post May 4 2011, 09:39 AM
The bad breath probably come from you stomach..
it does not go away so you gotta either eat mint or buy those breath sprays.
svage98
post May 4 2011, 10:25 AM
Dental Health and Bad Breath
Bad breath, medically called halitosis, can result from poor dental health habits and may be a sign of other health problems. Bad breath can also be made worse by the types of foods you eat and other unhealthy lifestyle habits.
How Does What You Eat Affect Breath?
Basically, all the food you eat begins to be broken down in your mouth. As foods are digested and absorbed into your bloodstream, they are eventually carried to your lungs and given off in your breath. If you eat foods with strong odors (such as garlic or onions), brushing and flossing -- even mouthwash -- merely covers up the odor temporarily. The odor will not go away completely until the foods have passed through your body.
Why Do Poor Habits Cause Bad Breath?
If you don't brush and floss your teeth daily, food particles can remain in your mouth, which promotes bacterial growth between teeth, around the gums, and on the tongue. This causes bad breath. In addition, odor-causing bacteria and food particles can cause bad breath if dentures are not properly cleaned.
Smoking or chewing tobacco-based products can also cause bad breath, stain teeth, reduce your ability to taste foods, and irritate the gums.
What Health Problems Are Associated With Bad Breath?
Persistent bad breath or a bad taste in your mouth may be warning signs of gum (periodontal) disease. Gum disease is caused by the buildup of plaque on teeth. The bacteria cause toxins to form in the mouth, which irritate the gums. If gum disease continues untreated, it can damage the gums and jawbone.
Other dental causes of bad breath include poorly fitting dental appliances, yeast infections of the mouth, and dental caries.
The medical condition dry mouth (also called xerostomia) can also cause bad breath. Saliva is necessary to moisten and cleanse the mouth by neutralizing acids produced by plaque and washing away dead cells that accumulate on the tongue, gums, and cheeks. If not removed, these cells decompose and can cause bad breath. Dry mouth may be caused by the side effects of various medications, salivary gland problems, or continuous breathing through the mouth.
Many other diseases and illnesses may cause bad breath. Here are some to be aware of: respiratory tract infections such as pneumonia or bronchitis, chronic sinus infections, postnasal drip, diabetes, chronic acid reflux, and liver or kidney problems.
rocket_jet
post May 4 2011, 10:34 AM
Videogame connosieur
Try using this product. very effective
http://www.amway2u.com/mall_proddet.jsp
cheekybum127
post May 4 2011, 02:39 PM
QUOTE(rocket_jet @ May 4 2011, 10:34 AM)
the link is unvalid quest.
anyway, i having the bad breath too. Dentist said, its due to gum decease and I need to floss every time after meal~
so troublesome...
In your case, will it be stomach odor?
Try to consume the Vitagen or Yakult as it is a good bacteria for stomach.
DrBarbarian
post May 4 2011, 02:56 PM
Darren's Daddy
99% is due to poor oral hygiene... rarely it's due to stomach and lung.....
k-bkeat
post May 4 2011, 05:57 PM
ts is not even replying. most probably a smoker
night
post May 4 2011, 06:20 PM
What doesn't kill you, makes you stronger.
This is what I do to ensure proper hygiene in my mouth. Brush twice a day. And whenever I had a meal in between, I'll wash my mouth and gargled them with plain water.
cee
post May 4 2011, 06:25 PM
There is a similar topic.
Do check out. Thanks.
http://forum.lowyat.net/topic/1459608
TSsosostupid
post May 4 2011, 07:05 PM
ps for late reply, was busy
im not a smoker le.
+ i do brush my teeth and my tongue and use mouth wash.
but it is not helping me.
any medicine or anything way?
QUOTE(cheekybum127 @ May 4 2011, 02:39 PM)
so troublesome...
i do have some swollen gums back then, it was serious, but now i jaga and take alot vitamin C, its back to normal.
did the dentist say anything abt stomach?
btw in my case, i dun think the bad breath comes from my mouth, i can feel the bad breath at the end of my mouth the throat part.
will it be anything to do with my throat? i do have sinus problem and using nasal spray.
This post has been edited by sosostupid: May 4 2011, 07:12 PM
rocket_jet
post May 4 2011, 07:14 PM
Have you tried Listerine?
TSsosostupid
post May 4 2011, 09:03 PM
QUOTE(rocket_jet @ May 4 2011, 07:14 PM)
nop haven tried listerine but other brand ._.
should i try listerine?
stephie_hype
post May 4 2011, 10:18 PM
Usually it comes from rotten teeth and tongue.
Angela Lee
post May 5 2011, 01:19 AM
Professional Human
Factors: tongue, stomach and foods consumed!
Doesn't eating garlic make you not wanting to smile?
It even gives off scent through your skin.
Make sure you brush your tongue (like 80% of the germs live there) blink.gif
TSsosostupid
post May 5 2011, 01:56 AM
QUOTE(Angela Lee @ May 5 2011, 01:19 AM)
thx for advise..will brush them crazily see if it change
3 Pages  1 2 3 >Top
0.0247sec    0.91    5 queries    GZIP Disabled
Time is now: 20th December 2025 - 11:34 PM
