 Silverstone Raven RV01 Review
TSianho
post Mar 12 2009, 12:53 PM, updated 17y ago
Cucimangkoklife
VIP
The Raven has finally landed! I’ve been looking forward to this case with great anticipation since the Silverstone people told me about it when it was in prototype stage. It was such agony to keep quiet about it even though I was so excited by this completely new concept that Silverstone had come out with. Before I start the review, I'd like to send out a big huge thanks to Silverstone Taiwan and Inter-Asia Technology Sdn Bhd for providing me with this case.
Introduction
I was really looking forward to the new layout of the motherboard placement which now has the I/O ports on the top of the case. I’ve always had a liking for non conforming layouts as I’ve always felt that the ATX standard is being left behind by PC components which are getting more powerful and much hotter by the day. In fact, a quad core + SLI rig is more like a nuclear reactor sitting in our homes. We enthusiasts need something better than ATX for sure. The new layout draws in cool, clean, filtered air from the bottom of the case and pushes it upwards through the motherboard and graphics cards and then exits straight out the top of the case. What better way to cool a PC than to follow one of the basic laws of physics in that hot air rises up.
Let’s get on to the case now. My first impression is how humongous this thing is. I had planned to go pick up the case from the Silverstone sole distributor in Malaysia(Inter-Asia Technology Sdn Bhd) using my MPV. However, on the day that Inter-Asia called me, the MPV was already in the service centre for its scheduled maintenance. So I had no choice but to go pick it up in my sedan. Would you believe it wouldn’t fit in my car? The only way I could do it was to remove the Raven from the box and put it in the boot.
The box had to be folded up and put in the back seat area.
I’ve always had a thing for opening up a big huge box filled with Silverstone goodness whenever a new one arrives at my house. I used to enjoy the whole process of making the very first cut on the box to the most exciting part where I lift the big bad wolf(Ooops! Sorry, it’s a Raven this time) out of the box. I’ve had no such joy this time as I had to do the whole thing out in the parking lot. sad.gif Oh well, no pictures of the box this time. I’ll just start off with an overall look at the case.
This post has been edited by ianho: Mar 12 2009, 04:03 PM
TSianho
post Mar 12 2009, 02:55 PM
Cucimangkoklife
VIP
The front panel
The front door opens by pushing it in and sliding down until it clicks into the locking position right at the bottom. To close it, just press down on the click lock and it will release the door to slide back up. It’s quite hard to explain this so I made a video of it.
Pretty cool huh? I sat there and played with the door for a few minutes. It’s so mesmerizing, the way it slides up and down.
The rear panel
Here’s how the rear panel looks like.
The I/O ports are on the top now, there’s nothing on the back. It’s just a plastic cover. There is a really cool feature behind the cover though. It’s very easy to remove by taking out one screw. This is how it looks like with the rear cover taken off.
Look closely and you will see that there are two holes in the back for water cooling hoses. It also comes with a mounting kit for a radiator. I don’t have a 3x120mm radiator on hand but it certainly looks like it will take a big huge 3x120mm radiator on the back there. A very nice feature indeed.
The PSU mount is located right at the very bottom of the back panel.
Below that is an air filter that slides out for easy maintenance and cleaning.
TSianho
Cucimangkoklife
VIP
The top panel
Here’s how the top panel looks like.
In order to gain access to the I/O ports and also to remove the side panel, these two knobs on the top need to be turned. Here’s a picture of the knobs in the locked position.
Turn it to the unlock position like this to release.
The rear piece covering the ports slides off after unlocking the knobs. This section of the top panel is generously vented as the heat from the graphics cards and 12cm fan exhaust through it. This is the main exhaust area.
TSianho
post Mar 12 2009, 03:00 PM
Cucimangkoklife
VIP
Top panel with cover removed.
With the top cover removed, we now have full access to the ports. The PCI slots are covered with Silverstone’s Aero slots. Kudos to Silverstone for including these really nice vented slots instead of making it optional equipment. The 12cm exhaust fan is located up here too. It’s a low noise fan rated to run at only 950rpm.
This is the front part of the top panel. The on/off and reset buttons are located here.
Flick open the flap and it reveals the extra USB, firewire and audio ports.
Inside the Raven
This is where the case really looks outstanding. If you thought the exterior looked awesome, wait till you see the insides. Immediately upon taking off the side panel, all I could say was “WOWeeeeeeee!!!!!!”. Look at how the motherboard tray is rotated 90 degrees to the right. That’s what makes this case so unique. The graphics cards and CPU cooler can now vent straight out the top of the case. Perfect solution in terms of thermo dynamics since hot air rises.
Here’s an overall look at the inside of the case.
The horizontal bar with the Silverstone logo embossed in it is the graphics card support bar. It has clips to hold the graphics cards securely so they don’t fall out of the PCIe slots. I suspect most people won’t be using this bar though. I certainly won’t be using it as I need all the space I can get to fit in a giant CPU heat sink. Besides, most modern graphics cards have pretty thick PCBs which are resistant to bending and shouldn’t have problems staying in the PCIe slots provided we lock the thumbscrews securely to the case.
To remove the top panel just push on this lock next to the top exhaust fan to the open position and slide the panel off.
Panel on.
Panel off.
This is the other side of the case where we can see the motherboard tray’s wiring provisions.
The motherboard tray is awesome. Look at all those wire management holes and clips. It’s the perfect solution for wire management freaks like me who try to make the internals look like its wireless. This layout is going to make my life so much easier as everything is provided for. I don’t have to modify the tray in any way. Just route the cables through the back and hold them down using the provided clips. Wire management has become simple as 1,2,3. The most difficult part of wiring management for me has always been the wires at the bottom of the motherboard that connects to the power, reset, USB and audio ports. It’s now so simple to just push the wires through the holes at the back and route them to the top panel.
This post has been edited by ianho: Mar 12 2009, 03:01 PM
TSianho
post Mar 12 2009, 03:06 PM
Cucimangkoklife
VIP
The DVD ROM slots have a very nifty design. All it takes is a click and the mechanism releases the lock. Here’s a picture of the new ROM slot locks.
Another really impressive feature is the hard disk compartments. The quick release feature is elegant and it works a treat. Here’s how the HDD compartment looks like.
To open it, click and pull the lever down.
After that, pull the tray outwards and the HDD comes out easily like this.
HDD hot swap connector.
This first tray that I’ve chosen to show in the pictures comes with a hot swap SATA connection. If required, you can buy the optional hot swap modules called CP05 and make all the HDD trays hot swappable. With the CP05, the HDDs can be swapped between the Kublai, Fortress and Raven series cases easily.
TSianho
post Mar 12 2009, 03:08 PM
Cucimangkoklife
VIP
Let’s take a look under the case now.
The intakes are completely filtered. There are no unfiltered intakes in this case. The bottom has two intakes. The rear intake is for PSUs with a bottom fan. The front intake is for the rest of the case to intake cool, clean air from under the case. Look a little bit higher up in the picture and you will see the two intake fans. They don’t look extraordinary in this picture though.
Until you see this!
They’re 18cm fans! The picture above shows a 12cm fan next to it for size comparison. Makes the 12cm fan look like a puny little thing doesn’t it? That 18cm fan is hugeeeeeeee. They are specified to run at only 700rpm so it should be as quiet as a church mouse while moving lots of air with those big huge blades. The rear 18cm fan blows over the motherboard area while the front 18cm fan blows over the HDD compartment.
Here’s a closer look at the filtered intakes.
Bottom intake with the filter installed.
Bottom intake with the filter removed. It’s very easy to remove, just slide it off the mount and it comes out easily for cleaning purposes.
Side panel intake.
Both side panels have intakes too. Unfortunately, these side panel filters are not easy to remove like the PSU and bottom intake filter. They don’t just slide off. These side intakes need to be removed with a screw driver. They really should have made some quick release filters for the side panels as well.
I love this case! It looks absolutely fantabulously beautiful and has a revolutionary thermal system plus a superb wire management system. I’ve been waiting anxiously for this case for such a long time ever since I saw the prototype and I haven’t been disappointed in any way. The only gripe I have is the side intake filters that are not quick release.
Build quality and materials used are top notch. The plastics are of a really high quality and the metal parts are heavy gauge steel. It’s a nice solid case worthy of protecting high end components for a superb gaming rig. I wouldn’t recommend it for LAN parties though, this Raven is one heavy bird. In summary, I give it a full kick ass rating for having style and substance. This Raven is one mighty bird!
This post has been edited by ianho: Mar 12 2009, 03:44 PM
nidzamputra
post Mar 12 2009, 03:55 PM
newbie
very cun casing...i like the design..so cool...
Jinster
post Mar 12 2009, 04:12 PM
Saber <3 VioletEvergarden <3
sweet casing~! looking forward to see ur completed work
SharingBeat
PromiseAintEnough
WOW....
nice casing...
looks cool also...><
ZeneticX
post Mar 12 2009, 04:14 PM
stars for what
This post has been edited by ZeneticX: Mar 12 2009, 04:14 PM
mADmAN
post Mar 12 2009, 04:17 PM
10k Club
QUOTE(ZeneticX @ Mar 12 2009, 04:14 PM)
actually...the price is expensive yes...but not THAT expensive...especially when compared to the TJ07 or the higher end Lian Li models which are selling for above 1k... its selling for around 7xx in the garage sales section..i actually think its quite reasonable.
if i were to buy a case, id be torn between this and the CM ATCS840. both are around the same price....
This post has been edited by mADmAN: Mar 12 2009, 04:17 PM
ZeneticX
post Mar 12 2009, 04:28 PM
stars for what
saw a lian li armoursuit selling for rm1.2k in garage sales.the design not tht attractive as this
This post has been edited by ZeneticX: Mar 12 2009, 04:30 PM
LittleLinnet
post Mar 12 2009, 04:32 PM
Iophobia
not going to put some hardware into that beauty ?
dan137
post Mar 12 2009, 04:36 PM
I don't need a parachute
beauty case. look fantastic. like stealth fighter jet.
the most genius is, all black interior just like spedo. but this is more beauty.
tjay_tj
post Mar 12 2009, 06:13 PM
retire
nice .
but the cable management will be darn hard.
and i like it if it is not a made in plastic.
brush aluminium would be great, but than the price will goes up.
nidzamputra
post Mar 12 2009, 06:23 PM
newbie
what the advantages if their design position like that arr?a bit weird la design...
xhacker
post Mar 12 2009, 06:27 PM
omg,dream case.. really-really-really love the front panel.. the way on how to open it.. so nice! not like open door like other case..
hmm,RM7xx eh? im saving my money for this hot bird!
boyz
post Mar 12 2009, 06:33 PM
Your Humble Vaudevillian
Thank you uncle Ian for completing thie review.. This will give me a better reason for purchasing this hot mama or not.. biggrin.gif rclxms.gif
KenDiriwan
post Mar 12 2009, 07:01 PM
this is more worth that than temjin07 i think lol. look at that bottom fan big buttt buddy..i like the pwr/rst button much smile.gif
the mobo tray is not removable right
kazairol
post Mar 12 2009, 07:09 PM
@ianho, why dont u put some screenie about cable management inside brows.gif
this is reventon version case. i personally will take ft01 over raven, didnt really like the futuristic design. tongue.gif
omara86
post Mar 12 2009, 08:53 PM
0mg nicotine juice
wat a great opportunity u hav there uncle ianho... really jeles at you, can be said the 1st person in LYN to touch the very nice casing... any update together with i7 installed inside?
This post has been edited by omara86: Mar 12 2009, 08:54 PM
KenDiriwan
post Mar 12 2009, 09:17 PM
QUOTE(omara86 @ Mar 12 2009, 08:53 PM)
nop, the first guy touched raven was cstkl1
aBc!!
post Mar 12 2009, 09:35 PM
Feel Good~
This post has been edited by aBc!!: Mar 18 2009, 02:12 AM
xelrix
post Mar 12 2009, 09:45 PM
too bad not for lanparty-goers.
im imagining it to become shrinked in size, with some bays cutoff....
cant do.
besides, can the thermal system in the raven even works in a small sff?
but the design is so cool....
rosihan
post Mar 12 2009, 10:02 PM
*\(-_-)/*
mean lookin case
rsangel
post Mar 12 2009, 10:29 PM
No Smoking pls @_@
finally uncle Ianho come out with his part 1 review....
good effort bro~
Virgle
post Mar 13 2009, 12:06 AM
►死神 Shinigami◄
How i wish that the light is not blue but red...
TSianho
post Mar 13 2009, 02:14 AM
Cucimangkoklife
VIP
QUOTE(LittleLinnet @ Mar 12 2009, 04:32 PM)
Hardware will go in soon. I've been too bz of late so I just do a review of the case 1st. Will update with the hardware install later.
QUOTE(tjay_tj @ Mar 12 2009, 06:13 PM)
nice .
Actually cable management should be very easy.
QUOTE(nidzamputra @ Mar 12 2009, 06:23 PM)
Advantage is that the hot air goes straight up instead of S flow here n there.
QUOTE(KenDiriwan @ Mar 12 2009, 07:01 PM)
I wouldn't say it's anywhere near the TJ07's quality n prestige. TJ07 is in a whole different class. TJ07 is like the Porsche Turbo n Raven is like the Porsche Boxter(built to sell in big volumes).
QUOTE(kazairol @ Mar 12 2009, 07:09 PM)
I will show the cable management once I get my hardware inside.
Even waaaaaaay back during prototype stage, the Silverstone engineer was telling me about this case while we were having dinner, I was oredi rubbing my hands n waiting impatiently for it to launch. It was torture not being able to share with u guys earlier due to my obligation to keep quiet before official product launch.
QUOTE(KenDiriwan @ Mar 12 2009, 09:17 PM)
LOL, being 1st to post pics doesnt mean 1st to touch. There r many things that the reviewers n sponsored people know n touch that the normal people dont even know exists. We keep quiet about it only because of NDA.
QUOTE(Virgle @ Mar 13 2009, 12:06 AM)
Howzabout some modding? This is a modding forum after all. brows.gif brows.gif brows.gif
rosihan
post Mar 13 2009, 08:33 AM
*\(-_-)/*
waa tis case sure sejuk 1
dude cant wait 2 see da Hw inside.....
soundaddict
post Mar 13 2009, 03:56 PM
uiks,where is cstkl1 post about cons of this case??
rsangel
post Mar 13 2009, 04:32 PM
No Smoking pls @_@
The con of the case i think is the cable management, abit hard
KenDiriwan
post Mar 13 2009, 06:08 PM
QUOTE(ianho @ Mar 13 2009, 02:14 AM)
TSianho
post Mar 13 2009, 08:06 PM
Cucimangkoklife
VIP
QUOTE(soundaddict @ Mar 13 2009, 03:56 PM)
Moved to Silverstone League. There is no point to a review within a review. It would be more useful for his views to be heard in the League thread as all people interested in everything Silverstone will naturally go there n read up about Silverstone users POV in there. Also, the local distributor reads up on users POVs in there n will be updated accordingly n will improve on service or any grouses ppl have with the brand or products.
This review thread will naturally fall back to the back pages n no1 will read it after a while when a newer case comes along. In the Silverstone League as with all the other leagues, all POVs whether good or bad, will be in there for a long time to come(usually up to a year) n will always stay around the 1st few pages for easy reference by all.
happy4ever
post Mar 14 2009, 10:26 AM
(✿◠‿◠) Queen of Love ⎝⏠⏝⏠⎠
This thread is still alive?
1 casing = 1 thread?
hypermax
post Mar 14 2009, 11:01 AM
QUOTE(happy4ever @ Mar 14 2009, 10:26 AM)
Seriously if you have any grudge against ian, pls file a complaint in "Main Site/Forum Feedback and Helpdesk" sub forum instead of whining here. This is a review, and let's keep it that way. doh.gif
OC4/3
post Mar 14 2009, 03:49 PM
Elite
@ianho,i won't call this a review without hardware fitted inside and some cooling result comparison with the TJ07 of your own icon_rolleyes.gif
This post has been edited by OC4/3: Mar 17 2009, 02:00 AM
kerryking
post Mar 17 2009, 10:52 AM
@Gd Stuff...slack part is no mobo tray removable
ianho faster finish the review hehe..wanna see the cooling result..
geroro
post Mar 17 2009, 11:47 AM
ლ(゚д゚ლ)
teamloks
post Mar 17 2009, 05:40 PM
aBc!!
post Mar 18 2009, 02:13 AM
Feel Good~
this will by more mahal abit . ^^ But still nice.
verdict
post Mar 18 2009, 03:44 AM
Time is Flying By
aBc!!
post Mar 18 2009, 01:13 PM
Feel Good~
i_love_japan
post Mar 18 2009, 03:43 PM
a very good casing i would say for the price of RM700+.
kaiser_falco
post Mar 19 2009, 10:41 PM
the world wanderer
at first i find this casing quite interesting,but there are a few flaw the way they oriented the motherboard,and the most important part is the cable management kindda horrible on this casing,which doesnt even give you that clean look feature,and for that price i suggested an alternative casing such as thermaltake spedo advance package which is superior in cable management and massive air flow which retailing around rm7xx..
i make a decision buying my thermaltake spedo advance system after a long considering side by side with raven with my hardware on hand...there is too much incompatibility that come with that mobo orientation,as a consumer my self i really suggest people to do a side by side comparison at your local shop to see what im talking about,anyway for anyone who interested there are small review written by me a month ago,just check it out,and im not sure the stock available or not for the time being as i grab this unit when it first arrived in malaysia and there are only 2 unit available at that time... check your local distro for more information.
the review might not be that good as im not a professional writer or from any shop,im just a normal user like the rest of you guys who just started to review some worthy stuff.
neway here is a link.
THERMALTAKE SPEDO ADVANCE REVIEW.
lesign2007
post Mar 21 2009, 08:46 PM
QUOTE(kaiser_falco @ Mar 19 2009, 10:41 PM)
Bro, if Cooler Master ATCS 840 vs CM HAF vs thermaltake spedo advance package, who will be outstanding in term of air cooling part?
thiamlun
post Mar 22 2009, 10:05 AM
very cool casing must be more expensive..hehe
sATA port
post Apr 16 2009, 09:29 AM
will it fit huge coolers like Cooler Master V10..... and some other huge giant cooler?? ths case is bigger then HAF92 and Antec 1200....... but the interior.... =.=
ZenoxV23
post Apr 17 2009, 11:40 AM
the inside looks like 3 storey house... got partitions... kewl...really aggressive looking casing...
Maxieos
post Apr 17 2009, 01:09 PM
Just wanted to ask , is this case silent ? where is the power button ? nice to click ?
tjay_tj
post Apr 17 2009, 01:17 PM
retire
frostmourne
post Apr 17 2009, 01:46 PM
this casing make me crazy..
nice design.
Maxieos
post Apr 17 2009, 02:43 PM
Anymore review on this casing ? silent ?
Any picture on cable management for this casing ?
TSianho
post Apr 17 2009, 03:41 PM
Cucimangkoklife
VIP
Hang on for the 2nd part with hardware installed. I had to wait till after PC Fair coz my King Kong rig needed to be at the Silverstone booth. Now I can take everything out n install into the Raven.
tjay_tj
post Apr 17 2009, 03:47 PM
retire
wow... 2nd part
sATA port
post Apr 17 2009, 05:44 PM
give url if got 2nd part!!!
Maxieos
post Apr 17 2009, 06:49 PM
QUOTE(ianho @ Apr 17 2009, 03:41 PM)
What king kong ring at Silverstone booth ? mind share with us the ring at Silverstone booth ? smile.gif
mADmAN
post Apr 17 2009, 07:00 PM
10k Club
King Kong is the name he gave for his current TJ07 casing and rig (not ring)
go to the worklogs section and search for king kong and ull find a more detailed answer.
Blood_Seeker28
post Apr 18 2009, 03:33 PM
damn macho this casing....
hmm...cant wait to play with this casing..
SUSPoorMe
post Apr 19 2009, 12:50 AM
It is gud looking casing but too bad it is not allu case at this kind of price should get lian li full allu case. =.=
tjay_tj
post Apr 19 2009, 12:58 AM
retire
maybe u are rite
i did state it at 1st page
but...
this is the 1st type of it own...
the 1st one to have the design like that....
for the price, it should be good... from the review, the quality are not bad also...
maybe i will regret saying this but... here goes...
this case pawn lian li for the price and the design
SUSPoorMe
post Apr 19 2009, 04:01 PM
My opinion is, this case only can pawn lian li with its design, price is about the same as for a tower, n 4 material lian li sure pawn it back. This is what i think. Mayb u guys think in the other way is up to u. I m here to listen n accept. ^^
sATA port
post Apr 20 2009, 08:55 PM
ive bought the case and used it already... its a nice case... satisfying..
JazzDazzle
post Apr 21 2009, 11:04 AM
Where and how much you bought ? =D
SUSPoorMe
post Apr 21 2009, 11:10 AM
From inter asia? RM699?
sATA port
post Apr 21 2009, 06:21 PM
i bought 670... at lowyat..!!
SUSPoorMe
post Apr 21 2009, 07:59 PM
Au, the best price at PC fair was 699. Then what the fair for sucking extra RM20 more from customer?
hkh_88
post Apr 21 2009, 10:15 PM
QUOTE(PoorMe @ Apr 21 2009, 07:59 PM)
SUSPoorMe
post Apr 22 2009, 12:43 AM
QUOTE(hkh_88 @ Apr 21 2009, 10:15 PM)
Get it, will go for the fair for the display unit. will not buy there. SAD
destfull
post Apr 29 2009, 03:59 PM
Brain for Creativity
I bought one.
Noise are so low for me.
But the fans are crappy.
two big 180mm 700rpm are just crappy if you guys live in Malaysia and don't have aircond like me at home. I just can't even feel anything
Same goes to its 120mm fans. I've changed it to higher speed fans.
I don't really care much about fans noise as it will be nothing when I opened mp3s via my woofer.
Other than that, I have a very nice looking casing to cover my hardware. Everyone drooling on it when they came to my house
Any recommendation on high speed 180mm fans please?
BuLaNaR
post May 1 2009, 01:05 AM
penyair sepi
so big,i dun think can fit the kancil...sigh...
chanws8
post May 1 2009, 08:17 PM
ИΞШB!Ξ
QUOTE(destfull @ Apr 29 2009, 03:59 PM)
So far, i dont see any 180mm case fan selling here...Coz not many casing can fit 180mm fan...
peinsama
post May 1 2009, 09:15 PM
Au fait
Wow. That's a humongous machine.
sheenho
post May 2 2009, 03:20 PM
On mah way! :D
wow.. what a nice casing...
yojimbo512
post May 3 2009, 02:09 PM
damn nice de design. got the stealth fighter vibe goin on ther...
TSianho
post May 3 2009, 08:31 PM
Cucimangkoklife
VIP
Wokeh........... finally installed everything after working on it for 4 days trying out all kinds of cooling possibilities. Will sort out pics n update soon.
yoonyin
post May 4 2009, 01:13 PM
@ianho
wait for you updating this thread long time ago....wanna get more review about rv01 and the cable management..
This post has been edited by yoonyin: May 4 2009, 01:13 PM
Virgle
post May 6 2009, 10:54 PM
►死神 Shinigami◄
Btw, can you give me a shot of the front LED? I wanna see if it can be mod from blue to red..
super_evil_alien
post May 8 2009, 05:48 PM
Slumber Mode
A picture for your imagination.Taken from CEX thread- http://forum.lowyat.net/index.php?showtopic=928856&hl=Raven
http://i287.photobucket.com/albums/ll142/cstkl1/IMG_0080.jpg
This post has been edited by super_evil_alien: May 8 2009, 05:49 PM
kilowatt
post May 8 2009, 11:56 PM
AysNdj
i owned this case & seriously wut destfull is true! +1 for u bro...
that big 2 fans really crap...but i still dunno wut fan match for that size..
do you have any suggestion destfull?....wut fan u change to?...
btw i really love this case even though the fan craps laugh.gif lol....
yeahh go Raven laugh.gif !
SUSmukahantu
post May 10 2009, 03:59 AM
Feel free to view my worklog people...
rsangel
post May 10 2009, 04:19 AM
No Smoking pls @_@
chanws8
post May 10 2009, 07:12 PM
ИΞШB!Ξ
QUOTE(rsangel @ May 10 2009, 04:19 AM)
kilowatt
post May 10 2009, 11:54 PM
AysNdj
wuttaa Raven in RED!!..
go support him!...
destfull
post May 11 2009, 01:11 AM
QUOTE(kilowatt @ May 8 2009, 11:56 PM)
just change to the normal 120mm fans... but higher speed la...
Added some pics to this thread
yuktsi14
post May 14 2009, 01:18 AM
Gloomy Sunday
how much is this casing?
yoonyin
post May 14 2009, 05:43 AM
RM699 before nego
destfull
post May 14 2009, 01:51 PM
RM 630 at kinkin
kilowatt
post May 14 2009, 09:21 PM
AysNdj
yup kinkin lowest price i think...i bought at him too last time biggrin.gif..
btw destfull cant see lo ur 120 fans sweat.gif...
peinsama
post Jul 10 2009, 03:24 PM
Au fait
Im thinking either this Raven RV01 or Cosmos S
clawhammer
post Jul 10 2009, 06:13 PM
///M
VIP
onnjeyyon
post Jul 12 2009, 02:10 PM
smoking is bad for health
yuktsi14
post Jul 12 2009, 02:15 PM
Gloomy Sunday
QUOTE(onnjeyyon @ Jul 12 2009, 02:10 PM)
yes
Godek
post Jul 12 2009, 03:17 PM
In crossroad to decide between this case (raven) and CM ATCS 840. Any thought guy ?
tjay_tj
post Jul 12 2009, 06:26 PM
retire
840 for the classic looks, quality and aluminium...
raven fot the concept and the price
Omnia
post Aug 8 2009, 10:47 AM
QUOTE(destfull @ May 11 2009, 01:11 AM)
saw u pic..
i feel my shame my RV01..
but do you encounter the front slide door have slip up problem??
kilowatt
post Aug 8 2009, 02:55 PM
AysNdj
hahaha tongue.gif ...relax bro...u will upgrade soon! nod.gif ....
u oredi owned "gagak hitam" case maa icon_rolleyes.gif ...
TSianho
post Aug 8 2009, 03:35 PM
Cucimangkoklife
VIP
QUOTE(Omnia @ Aug 8 2009, 10:47 AM)
saw u pic..
eh? how come u use MATX mobo? The front door sliding mechanism is like that for the 1st batch. it's very simple to fix. Just put some white grease in the sliding rails. It's called lithium grease. if u happen to have Vaseline oso can use that. My Raven 1 oso like that but after I put the grease, it can even tahan thousands of up down repetitions at the KL PC Fair. thumbup.gif
kilowatt
post Aug 9 2009, 02:44 PM
AysNdj
QUOTE(ianho @ Aug 8 2009, 03:35 PM)
owh blink.gif ....just use grease ka?....lol...wokey will try on my sliding.. rclxub.gif
where can i put this grease?..along the drain there ka?...
This post has been edited by kilowatt: Aug 9 2009, 02:47 PM
TSianho
post Aug 9 2009, 04:12 PM
Cucimangkoklife
VIP
QUOTE(kilowatt @ Aug 9 2009, 02:44 PM)
Oredi said in my post above mar. It's white in color n called Lithium grease. If u cant find it, u can oso use Vaseline. Put it inside the sliding longkang.
LilRazor
post Aug 9 2009, 11:34 PM
lol i slide the door of ur casing few times hahahahahahah no wonder so smooth xD
very shyok
This post has been edited by LilRazor: Aug 9 2009, 11:35 PM
kilowatt
post Aug 10 2009, 12:53 AM
AysNdj
QUOTE(ianho @ Aug 9 2009, 04:12 PM)
QUOTE(LilRazor @ Aug 9 2009, 11:34 PM)
very shyok
lol laugh.gif ...
Omnia
post Aug 11 2009, 10:13 AM
QUOTE(kilowatt @ Aug 8 2009, 02:55 PM)
ha~
oh... coz still im thinking which Processor to change.. AMD or Intel rclxub.gif
cool~ im not sure the "W4D" is a grease?
and hor.. do need to tear out RV01 front slide door??
Added on August 11, 2009, 10:22 amianho .... I saw your blog to mod the IFX14, I just wonder that paint will not affect the IFX14 cooling effect? shocking.gif
This post has been edited by Omnia: Aug 11 2009, 10:22 AM
TSianho
post Aug 11 2009, 11:00 AM
Cucimangkoklife
VIP
QUOTE(Omnia @ Aug 11 2009, 10:13 AM)
ha~
U go look inside ur car engine bay. Y u think they paint the radiator black? wink.gif
Omnia
post Aug 11 2009, 11:10 AM
QUOTE(ianho @ Aug 11 2009, 11:00 AM)
that black oil cream?
TSianho
post Aug 16 2009, 01:09 PM
Cucimangkoklife
VIP
Here's some pics of my Raven before I strip it down n move everything over to the Raven 2. I only have the pics of the IFX14 set up in my Mac right now. The pics of the water cooled set up with Swiftech H20 kit is in the HDD of my PC. Will post that up as soon as my Raven 2 is up n running, probably by tonight.
Close up view.
See how clean the wire management is? I didn't even have to cut anything on the case to achieve that clean look. The Raven is a wire management dream come true. So many holes n slots to put the wires through the mobo tray. I really don't understand y so many ppl are complaining about the Raven being a wire management nightmare. rclxub.gif rclxub.gif rclxub.gif
The thermal performance of this case is pretty good too, considering the silence it provides. If it can air cool my rig adequately then I'm pretty sure it will be enough for just about anyone's rig too. I'll post up the temperatures achieved with the IFX14 set up together with the water cooled pics later on.
onnjeyyon
post Aug 16 2009, 01:23 PM
Tonight? wow~ reli cant wait 4 it ady..faster faster..hehe
Yalo uncle, y the car radiator is black ar?
OlgaC4
post Aug 25 2009, 08:24 PM
If the casing using spring sure can rosak later.
kilowatt
post Sep 9 2009, 10:02 PM
AysNdj
how can la rosak...the owner maybe dunno how to take care well laugh.gif..
lingloong
post Sep 10 2009, 02:31 PM
# Noob In Trading #
QUOTE(ianho @ Aug 16 2009, 01:09 PM)
Close up view.
This is one "WICKED SICK" Rig you got there laugh.gif Hopefully can see the pros and cons between this two bros, RV01 vs RV02 nod.gif
LilRazor
post Sep 10 2009, 03:50 PM
O.o THE CABLE MANAGEMENT IS SOOOO NICE! Im still wondering how u ppl fit the 24 pin mobo connector into that hole =.=
can show behind ka?
nice !
This post has been edited by LilRazor: Sep 10 2009, 03:50 PM
TSianho
post Sep 12 2009, 09:44 AM
Cucimangkoklife
VIP
Oh maaaaan. I'm so sry guys. My PC is still in pieces. I've removed everything from the RV01 but still haven't moved the hardware into the RV02 due to unforeseen circumstances. I've been pretty bz of late. Been surviving on the Mac for so many weeks d. Will hafta get my PC up n running soon. I really cant tahan editing 21megapixel pictures on the Mac anymore. Really need my Quad core, 8gb ram, beast to do it.
QUOTE(LilRazor @ Sep 10 2009, 03:50 PM)
can show behind ka?
nice !
That's y I don't understand y so many ppl complain that RV01 is a cable management nightmare. It's perfect for cable management actually.
LilRazor
post Sep 12 2009, 10:11 PM
lol heh my cable managements is fine but its just only the 24 mobo pin xD
also got to agree with u the cable management on raven rv01 is perfect accept for the bottom xD
Pis
post Sep 15 2009, 06:21 AM
Be careful ya RV01 user, one of the customer feedback:
"Cons: There are too many plastic parts. While working on the build, I use a high intensity light which generates a lot of heat, and I did not notice that the light was so close to the case that it actually started melting away the plastic on top of the case."
I want to installed Cooler Master Ultra Aurora CCFL into my case, but since I red this statement, I afraid to put it in my case. Is there any rv01 owner here face the same problem like that customer?
Takutlah...
rosihan
post Sep 15 2009, 10:10 AM
*\(-_-)/*
kewl black theme
TSianho
post Sep 15 2009, 07:00 PM
Cucimangkoklife
VIP
QUOTE(Pis @ Sep 15 2009, 06:21 AM)
Takutlah...
CCFL is COLD CATHODE mar. Apa takut? That silly fella use high intensity light of course melt ler.
Pis
post Sep 15 2009, 10:47 PM
QUOTE(ianho @ Sep 15 2009, 07:00 PM)
Oh, I see, I though the the CCFL and high intensity generated heat about the same, hmm...ok2, thanks...
Anyway, new rv01 owner report in...
Cable management quite difficult for me...
One of my hdd is ide so, I just put my ide hdd without the secure cage...
kilowatt
post Sep 15 2009, 11:15 PM
AysNdj
lol like this also can ka sweat.gif ...
kyzson69
post Sep 16 2009, 01:04 AM
Psychiatric Patient
HOLLY cow... i think I know what is my next choice for casing upgrade!!! shocking.gif
Pis
post Sep 16 2009, 05:50 AM
QUOTE(kyzson69 @ Sep 16 2009, 01:04 AM)
Don't worry, high intensity light is different because, for one of example, one type of high intensity light bulb is uses 115-volt and 60-hertz input power...
Silverstone RV01 will not melt if you want to put lots of cathode of CCFL type, for example, Cooler Master Ultra Aurora CCFL...
LilRazor
post Sep 17 2009, 09:22 PM
melt =.= now u make me scared ...... zzzzz and also very easily get scratch ......
Pis
post Sep 17 2009, 09:38 PM
Apa nak takut, easily to scratch? Semua case pun lebih kurang macam tu laa...
Kind of funny, everybody scared to choose rv01, ha...ha...
LilRazor
post Sep 21 2009, 06:47 PM
lol dont know ahah maybe my raven still new and the most expansive casing ive ever bought so i sakit hati la got 1 scratch lol got 1 time my friend scratch it ... i got shock until nosebleed...
lingloong
post Oct 2 2009, 12:50 PM
# Noob In Trading #
QUOTE(LilRazor @ Sep 21 2009, 06:47 PM)
asamkipas
post Oct 4 2009, 08:58 PM
Tom Tom Tom Ketom !!!
Pemilik gagak 01 mendaftarkan diri !
Anyone here wana sell their GC holding bar ? huhu wana complete my Raven huhu..i noe its use is not needed,but I still wana buy hhuhu
Pis
post Oct 4 2009, 09:29 PM
QUOTE(asamkipas @ Oct 4 2009, 08:58 PM)
Macam mana boleh xdapat pulak?
kilowatt
post Oct 12 2009, 07:08 PM
AysNdj
hahaha izit ka till nosebleed ar laugh.gif laugh.gif ..relax2...to bro asamkipas change ur avatar la bro..come join us using ur actual Raven-01 pica brows.gif rclxm9.gif
This post has been edited by kilowatt: Oct 12 2009, 07:09 PM
LilRazor
post Oct 14 2009, 12:24 AM
ya nosebleed until alot =\ my friend was there he went omg...
anyway how long have we been waiting for this review WITH TEMPS ..... where u ianho... T.T
intelp
post Oct 23 2009, 09:11 AM
sorry to steal pic,
i got a question, where to buy a long sata cable for raven?
need how many cm for that? My normal sata cable even cant reach to the first or second hdd slot shocking.gif
This post has been edited by intelp: Oct 23 2009, 09:12 AM
mfcm
post Oct 23 2009, 01:43 PM
50cm sata cable shud b nice..not too long not to short..can ask moderno or niclasteoh
Q80
post Oct 23 2009, 01:57 PM
wowwwww, nice case ianho:D
zoslan
post Oct 23 2009, 02:27 PM
bro asamkipas, poison mu dah terlarut ...ahahhaha
intelp
post Oct 24 2009, 10:05 AM
QUOTE(mfcm @ Oct 23 2009, 01:43 PM)
mfcm
post Oct 24 2009, 12:54 PM
QUOTE(intelp @ Oct 24 2009, 10:05 AM)
if u think not enuf theres longer lenght such 75cm and 100cm wink.gif both forumer from here..got sum1 oso selling acryan product..forgot his name..he's oso got it iinm
TSianho
post Oct 24 2009, 05:14 PM
Cucimangkoklife
VIP
I used meter long SATA cables so no problem.
kumanosuke
post Oct 25 2009, 06:03 PM
ianho sold off his Raven RV01 ady ?
http://forum.lowyat.net/index.php?showtopic=1183408&hl=raven
This post has been edited by kumanosuke: Oct 25 2009, 06:06 PM
intelp
post Oct 27 2009, 03:23 PM
QUOTE(mfcm @ Oct 24 2009, 12:54 PM)
hmm
but the problem is even 75CM n 100CM length sata cable also harder to find in my area, what is acryan product??
.. grrrr.. still got any idea?
what are the market price for 75 n 100 CM length sata cable?
Added on October 27, 2009, 3:33 pm
QUOTE(ianho @ Oct 24 2009, 05:14 PM)
do you sell ian?
This post has been edited by intelp: Oct 27 2009, 03:33 PM
TSianho
post Oct 31 2009, 07:00 PM
Cucimangkoklife
VIP
I bought the meter long SATA at pc fair.
kumanosuke
post Nov 1 2009, 03:34 AM
Anyone interested in bulking Silverstone's 180mm high performance fan ? the model is FM181 comes with fan controller... i think gonna get this directly from Inter-Asia
intelp
post Nov 12 2009, 09:27 AM
QUOTE(ianho @ Oct 31 2009, 07:00 PM)
POOR JB
andythung
post Nov 12 2009, 12:40 PM
------= Genuine Trader =------ ---= Enthusiast User =---
go KL PC fair next time ~~
kumanosuke
post Nov 15 2009, 01:38 AM
sry wrong post
This post has been edited by kumanosuke: Nov 16 2009, 06:18 PM
TSianho
post Nov 18 2009, 09:44 PM
Cucimangkoklife
VIP
QUOTE(intelp @ Nov 12 2009, 09:27 AM)
POOR JB
Since ur in JB then go to Sg n buy lor. SLS sure got.
valtai30
post Nov 23 2009, 12:24 PM
which shop got selling this cable leh heh??? i oso want some.......
monkey5525
post Nov 25 2009, 09:55 PM
Ianho or someone else who use RV-01, i wanna know is it this casing without the speaker cable for front panel? cry.gif Need to buy a lot longer cable for the cable management, can use original cable make it very "cun" but scare spoilt the original cable cry.gif Beside that, does anyone know is there brand got 180mm fan with 2000RPM speed and green LED?
This post has been edited by monkey5525: Nov 25 2009, 09:59 PM
zero07
post Jan 18 2010, 02:56 PM
asamkipas. ni aku shah uni**. haha aku pun ingat nk beli casing ni
cy-yang
post Jan 19 2010, 10:48 AM
nice casing..
but damn heavy for this babe..
Unleashed
post Jan 13 2011, 09:38 AM
0.0665sec    0.71    5 queries    GZIP Disabled
Time is now: 18th December 2025 - 08:24 AM
