now everytime after a few minutes of playing, the game freeze..have to shut it down and on again..but no signs of red lights at all
Technical Need help, Xbox freeze frequently
Nov 16 2008, 12:51 AM, updated 18y ago
#1
247 posts Joined: Nov 2005 From: Somewhere~ |
i have experienced a few screen freeze either while playing game or when starting the dashboard today..at one point..there's a 3rod lights flash up..i was terrified..after i switch off and turn on again..it could load normally..i have read a few forums and they claim its something to do with the power supply..any comments or suggestions to fix the problem anyone? i still got lots of games to play with it..dun want it to die now..
now everytime after a few minutes of playing, the game freeze..have to shut it down and on again..but no signs of red lights at all |
Nov 16 2008, 01:05 AM
#2
1,167 posts Joined: Jan 2007 From: ..Tsukuba.. |
symptom of 3rod coming,gpu overheat get it fixed b4 it bcomes worst
Nov 16 2008, 01:11 AM
#3
Nov 16 2008, 02:34 AM
#4
5,691 posts Joined: Mar 2006 |
3rrod coming, welcome to the 3rrod club
Get ready to warranty claim your 360, lol. |
Nov 16 2008, 04:04 AM
#5
2,862 posts Joined: Jan 2003 From: アメリカ |
if let say power supply, move it to a single socket on the wall.. dont share it.
me once get that, but after move it to another socket, problem solved.. check ur error code to be sure. for power supply is 0001 This post has been edited by msn83235502: Nov 16 2008, 04:04 AM |
Nov 16 2008, 12:41 PM
#6
QUOTE(msn83235502 @ Nov 16 2008, 04:04 AM) if let say power supply, move it to a single socket on the wall.. dont share it. oh..ok..thx..i just want to find the solutions besides just handing over for warranty..cuz if can i prefer not to wait long..after all i still need to pay for the postage to singapore..might as well fix it hereme once get that, but after move it to another socket, problem solved.. check ur error code to be sure. for power supply is 0001 |
Nov 16 2008, 03:29 PM
#7
1,098 posts Joined: Nov 2006 |
Is playing in an air-conditioned room at 18 'C (in which the fan of the air cond is pointed 'towards' the console) and making sure there isn't a single dust on and around the console.... help 'reduce' (note the use of word) the chances of death ? Oh btw, being a neat freak, i cover the console after playing (after letting it cool down completely) with the plastic it came... |
Nov 16 2008, 03:48 PM
#8
QUOTE(steventanz @ Nov 16 2008, 12:41 PM) oh..ok..thx..i just want to find the solutions besides just handing over for warranty..cuz if can i prefer not to wait long..after all i still need to pay for the postage to singapore..might as well fix it here have u check the error code? it can be done less than a minute. |
Nov 16 2008, 03:50 PM
#9
Nov 16 2008, 04:17 PM
then i believe it's not power supply problem.. it may be ur console itself. welcome to rrod club.
Nov 16 2008, 05:17 PM
Nov 16 2008, 09:06 PM
2,782 posts Joined: Feb 2006 From: BANGSARian |
not all lights light up means its something else
dvd drive... hard disk.... power supply... |
Nov 16 2008, 09:19 PM
Recommended read by my teamxbox forum dudes...
http://ezinearticles.com/?X-Box-360---Caus...eath&id=1223724 "How To Try To Prevent It: -Ensure that your X-Box receives enough airflow around it and that it is never put on a carpet. -Keep your console far away from heat sources such as heaters. -Do not keep your power brick on the floor. -If you feel that it is getting very hot during use, try using additional fans or other cooling devices available on the market. " 'do not keep power brick on the floor'... > 'rumored' to be a bit of a magic solution... as usual, any solution is highly doubted... |
Nov 16 2008, 09:52 PM
if u are not keeping your power brick on the floor, where 2 keep it ?
on another note, ive read that providing constant stable proper electric flow to the power brick is also another important item this i wouldnt deny, it applies to most hardwares out there |
Nov 16 2008, 11:19 PM
QUOTE(Jcsy @ Nov 16 2008, 09:52 PM) if u are not keeping your power brick on the floor, where 2 keep it ? lol...the way u ask so funni... on another note, ive read that providing constant stable proper electric flow to the power brick is also another important item this i wouldnt deny, it applies to most hardwares out there u keep the power brick on the same table as the console... i also heard 'ppl say' that yes, the wall socket u connect the power brick to is crucial - - too many appliances same socket, may cause voltage fluctuations... i believe it was gamespot forum or something |
Nov 17 2008, 12:01 AM
yup now im keeping it on the same table with the console, with a table fan blowing both of it
really hope that helps lol |
Nov 17 2008, 01:31 AM
i keep my powerbrick on the floor but i lapik wit book so that it does nt contact with the floor how is that will that help?
Nov 17 2008, 01:44 AM
actually i think its about heat on the power brick as well as power provided to it must be stable & constant
Nov 17 2008, 12:14 PM
today after attempting a few times..the 3rod came out again..but the dashboard load..so i try the error code..its 0102..check the topic..its unknown problem..maybe i should just bring it to be fixed..any recommendation from u guys who should i get fixed from?
This post has been edited by steventanz: Nov 17 2008, 01:19 PM |
Nov 17 2008, 10:35 PM
QUOTE(Jcsy @ Nov 17 2008, 01:44 AM) actually i think its about heat on the power brick as well as power provided to it must be stable & constant how to keep our power stable as i know our home current not so stable need to use UPS can huh can UPS stabilize voltage?QUOTE today after attempting a few times..the 3rod came out again..but the dashboard load..so i try the error code..its 0102..check the topic..its unknown problem..maybe i should just bring it to be fixed..any recommendation from u guys who should i get fixed from? try fixing at benard at gamers solution,fixed mine there so far already 1 month running strong without hickups. This post has been edited by S4PH: Nov 17 2008, 10:37 PM |
Dec 22 2008, 09:34 PM
3,065 posts Joined: Jan 2003 |
My xbox elite freeze , but restart then work fine, the freeze mean is the screen all is hang pixel dot. but after restart work fine again !
Dec 23 2008, 01:55 AM
QUOTE(fansoption @ Dec 22 2008, 09:34 PM) My xbox elite freeze , but restart then work fine, the freeze mean is the screen all is hang pixel dot. but after restart work fine again ! ... oh oh... Dude. Just try switching power outlets. I know this is a... err... controversial solution but just try. And make sure your power brick is well ventilated (not being blocked, good air flow around it). |
Dec 23 2008, 09:56 AM
16 posts Joined: Oct 2006 |
QUOTE(fansoption @ Dec 22 2008, 09:34 PM) My xbox elite freeze , but restart then work fine, the freeze mean is the screen all is hang pixel dot. but after restart work fine again ! I think i coz by the NXE if you updated to NXE, i also experience the hang, but after a minute, it back to normal, just wait. I read somewhere, due to memory not enough, don't know how to explainIf not, maybe other problem |
Dec 31 2008, 09:14 PM
375 posts Joined: Oct 2004 From: Desa Petaling, Kay El |
QUOTE(pakcikkantin @ Dec 23 2008, 09:56 AM) I think i coz by the NXE if you updated to NXE, i also experience the hang, but after a minute, it back to normal, just wait. I read somewhere, due to memory not enough, don't know how to explain an internet line congestion might also cause certain freeze-like-sensation. If not, maybe other problem |
Jan 18 2009, 12:13 PM
142 posts Joined: Dec 2005 |
im having this problem too, the xbox would constantly hang. is it a 3rod or sumting?
Jan 18 2009, 12:19 PM
UNCLE 3ROD coming for chinese new year
Jan 18 2009, 09:03 PM
Jan 18 2009, 11:22 PM
u guys need a jasper for chinese new year ,dispose the xenons and zyphers
Jan 19 2009, 06:55 AM
Jan 19 2009, 08:40 AM
falcon also ok but in time will 3rod also.
This post has been edited by S4PH: Jan 19 2009, 08:40 AM |
Jan 19 2009, 11:15 AM
falcon also got some RROD
jasper its just about time |
Jan 19 2009, 04:34 PM
Jan 19 2009, 08:13 PM
16 posts Joined: Dec 2008 |
JASPER better than FALCON better than XENON/ZYPHERS
Conclusion :- everyone should buy Jasper & enjoy your games . RROD is near dying...left the last breath..LOL |
Jan 19 2009, 08:17 PM
1,605 posts Joined: Feb 2006 |
MS seriously damn smart...wan to fix the rrod problem...then FIX IT ONE GO LA!!!!!!....keep releasing new 1...like forcing ppl to buy multiple xboxs...
Jan 19 2009, 08:24 PM
QUOTE(wilsonjay @ Jan 19 2009, 08:17 PM) MS seriously damn smart...wan to fix the rrod problem...then FIX IT ONE GO LA!!!!!!....keep releasing new 1...like forcing ppl to buy multiple xboxs... exactly. I find it really odd... dun tell me the geniuses behind the new designs couldn't think of it years ago ? imagine, Jasper released - - - wohoo ! Must get it ! I heard it is anti-RRoD ! ... and the sales of Xbox 360 shoots up again. Microsoft's problem = customer's money in their pockets I'd say those who fall for it... well, you are doing yourself and Microsoft a favor. |
Jan 19 2009, 08:32 PM
ya...its like when they found out that their xbox have the RROD problem..their trying to abuse it by slowly fixing it...so ppl would keep coming b to buy a better xbox..and what else? profit for them...no wonder xbox sales r better...
This post has been edited by wilsonjay: Jan 19 2009, 08:32 PM |
Jan 19 2009, 08:34 PM
The problem has been a success, ladies and gentleman. - Microsoft Xbox Team
Jan 19 2009, 08:38 PM
VIP
7,071 posts Joined: Jan 2003 From: London :: Mutiara Damansara :: Xbox Live Network |
QUOTE(defaultname365 @ Jan 19 2009, 04:34 PM) I think by the time jasper gets 'enough' RRoD complaints, Xbox 3 already released (predict end 2010 / early 2011). Somehow I believe jasper's RRoD rate has significantly reduced but not completely out. Any soy sauce for that? It's like very quiet on all the Jasper news lately....QUOTE(wilsonjay @ Jan 19 2009, 08:17 PM) MS seriously damn smart...wan to fix the rrod problem...then FIX IT ONE GO LA!!!!!!....keep releasing new 1...like forcing ppl to buy multiple xboxs... Don't you think the ratio of customer NOT buying 360 due to RROD is higher than the return customer? Repair cost ain't cheap and they goto take care of all the courier fee. (supported region) |
Jan 19 2009, 08:42 PM
QUOTE(PrivateJohn @ Jan 19 2009, 08:38 PM) Any soy sauce for that? It's like very quiet on all the Jasper news lately.... lol...than whats the difference...if microsoft fix it 1 go...they wont see much customers with their RRoded xboxs returningDon't you think the ratio of customer NOT buying 360 due to RROD is higher than the return customer? Repair cost ain't cheap and they goto take care of all the courier fee. (supported region) Added on January 19, 2009, 8:43 pm QUOTE(defaultname365 @ Jan 19 2009, 08:34 PM) *Microsoft Staffs claps...*This post has been edited by wilsonjay: Jan 19 2009, 08:44 PM |
Jan 19 2009, 09:04 PM
VIP
lol that I don't know, goto ask the Microsoft management Team.
Perhaps someone with better insight could shed some light on this subject. |
Jan 20 2009, 05:15 PM
QUOTE(PrivateJohn @ Jan 19 2009, 09:04 PM) lol that I don't know, goto ask the Microsoft management Team. If Microsoft really was a smart company (and I'm not saying they aren't), the worldwide scale of the RRoD issue should have already caused every person in the Xbox team to sweat... Perhaps someone with better insight could shed some light on this subject. In some ways Microsoft is taking 'advantage' of the RRoD situation. The fact that 360 sales still pwns PS3 sales is just... amazing. |
Jan 20 2009, 05:34 PM
VIP
If they don't repair for free, nobody gona buy 360 already
In supported region, if the 360 kaput you go exchange (what's the point of warranty then?)....not necessary must buy a new one, perhaps the hardcore but definitely not the mass market or core/casual (whatever terms) gamer. Imagine if there were no 3rod, couldn't the sales be higher? Also what makes the gamer wana buy 360 again? They <3 Microsoft or they <3 games? If making a product faulty = increase sales, why don't la every company do that since the customer all gona buy it over & over again? |
Jan 20 2009, 08:07 PM
So what's the magic of Xbox 360 sales?... what's the reason people keep buying this console in the light of the RRoD phenomenon ? Do they one day finally discover the issue and then go get a different console entirely or This post has been edited by defaultname365: Jan 20 2009, 08:10 PM |
Jan 20 2009, 08:22 PM
VIP
QUOTE(defaultname365 @ Jan 20 2009, 08:07 PM) So what's the magic of Xbox 360 sales?... what's the reason people keep buying this console in the light of the RRoD phenomenon ? Do they one day finally discover the issue and then go get a different console entirely or QUOTE Also what makes the gamer wana buy 360 again? They <3 Microsoft or they <3 games? Also with warranty, why would they keep buying a new 360? I didn't know xbox 360 owner are as rich as Microsoft Ya, I bought 360 at launch (still alive) So the gamerscore sure liddat la... |
Jan 20 2009, 08:25 PM
wow...since laucnh..rrod how many times already???
Jan 20 2009, 08:29 PM
VIP
Jan 20 2009, 08:32 PM
lol..so total how many years?...very rare to find a sole survivor...
This post has been edited by wilsonjay: Jan 20 2009, 08:33 PM |
Jan 20 2009, 08:35 PM
QUOTE(PrivateJohn @ Jan 20 2009, 08:22 PM) Look into this you must. Also with warranty, why would they keep buying a new 360? I didn't know xbox 360 owner are as rich as Microsoft Ya, I bought 360 at launch (still alive) So the gamerscore sure liddat la... » Click to show Spoiler - click again to hide... « ... as a conclusion, the major reason for strong Xbox 360 sales are the games? That is Xbox 360 games that (while also available for PS3) takes advantage of Xbox Live... perhaps. My theory/logic is that -> Hot new title announced -> Xbox 360 gamers anxious -> Long time waiting, gamers keep on gaming, perhaps some get RRoD -> However, they are still resilient and persist on getting that 360 title... -> Game sells well -> Game garners great 360 support from fans and critics alike -> More people enticed to get Xbox 360 -> 'Some' current 360 gamers eyeing Jasper, newcomers told to get Jasper etc. etc. -> Cycle repeats as long as there is 360 QUOTE(PrivateJohn @ Jan 20 2009, 08:29 PM) Not yet but my PAL unit over here RROD once when my house electricity went on a bumper ride, RROD instantly... Since 2005 the console is still alive ?? Unbelievable... OMG This post has been edited by defaultname365: Jan 20 2009, 08:39 PM |
Jan 20 2009, 08:36 PM
VIP
wow...more than 2 years!!!...good job..any tips to prolong the xbox
Jan 20 2009, 08:45 PM
VIP
QUOTE(defaultname365 @ Jan 20 2009, 08:35 PM) ... as a conclusion, the major reason for strong Xbox 360 sales are the games? That is Xbox 360 games that (while also available for PS3) takes advantage of Xbox Live... perhaps. Why you wana worry so much on why or how it sells more? Are you ninja-baiting, why must keep bringing up the ps3. My theory/logic is that -> Hot new title announced -> Xbox 360 gamers anxious -> Long time waiting, gamers keep on gaming, perhaps some get RRoD -> However, they are still resilient and persist on getting that 360 title... -> Game sells well -> Game garners great 360 support from fans and critics alike -> More people enticed to get Xbox 360 Since 2005 the console is still alive ?? Unbelievable... OMG That console only my brother play it now...we don't really take care of it. Sometimes leave it overnight...playing 1 hour a day just so it doesn's RROD is really stupid...who says that? There is no way you can stop it. I don't think I am the only survivor, look around. There are quite a few left... |
Jan 20 2009, 09:19 PM
QUOTE(PrivateJohn @ Jan 20 2009, 08:45 PM) That console only my brother play it now...we don't really take care of it. Sometimes leave it overnight...playing 1 hour a day just so it doesn's RROD is really stupid...who says that? There is no way you can stop it. I don't think I am the only survivor, look around. There are quite a few left... |
Jan 20 2009, 09:21 PM
no matter how bad the hardware is xbox360 is still the best console to date in terms of titles.
Jan 20 2009, 09:31 PM
VIP
Jan 20 2009, 09:35 PM
QUOTE(PrivateJohn @ Jan 20 2009, 09:31 PM) the other guy with the speks... I only find about GH when I really, really wanted to buy an Xbox 360... I wonder why GH is not advertised like... in TV / radio ? That would be freakin awesome... imagine the dudes on a TV commercial... |
Jan 21 2009, 01:27 AM
43 posts Joined: Oct 2007 |
Jan 21 2009, 06:33 AM
QUOTE(wilsonjay @ Jan 19 2009, 08:17 PM) MS seriously damn smart...wan to fix the rrod problem...then FIX IT ONE GO LA!!!!!!....keep releasing new 1...like forcing ppl to buy multiple xboxs... You have like 3 years warranty for 3RRoD, why buy new box? so important that you can't rest for that 7 days of warranty period? Uh, From what I know some ppl buy 2 consoles. I for mod + 1 for LIVE.... For me I would go for alternative console than the modded one. Some ppl also really buy 2 consoles for spare if 1 is out.... But....How many percent of xbox360 users did that? I don't think it's more than 1% out of total sold consoles.... I send to SG for RMA purpose if it fails....no one will crack my box until warranty expired. But before it expired...I think valhalla is out. This song really nice to share. This post has been edited by navigator: Jan 21 2009, 07:11 AM |
Jan 21 2009, 10:26 AM
Jan 21 2009, 08:30 PM
Jan 21 2009, 08:36 PM
Jan 21 2009, 11:41 PM
Jan 22 2009, 12:26 AM
lol...then if i give u falcon and a jasper? which 1 would u take?
Jan 22 2009, 01:15 AM
jasper is really cool bro very less heat compared to my zypher.i guess wont 3rod but still have to wait n c.
Jan 22 2009, 09:43 AM
QUOTE(navigator @ Jan 21 2009, 11:41 PM) If Xenon to Falcon I see the diff, if Zephyr to Jasper I see the diff. First of all, we need to see what's the changes from Falcon to Jasper inside the box?But Falcon to Jasper not worth the cost of only one revision leap. Yes, the star is here, the 65nm GPU in Jasper as compared to 90nm GPU in Falcon. No doubt the 65nm GPU draws less current thus produces less heat. As we all should know, heat is the main cause to RROD. |
Jan 22 2009, 10:38 AM
6 posts Joined: Apr 2008 |
sorry off topic,but i dont want to create a new thread for this 1 question.
Can i use keyboard and mouse to play FPS game on the Xbox360? im sux when playing fps using controller This post has been edited by rid88: Jan 22 2009, 10:38 AM |
Jan 22 2009, 10:52 AM
QUOTE(rid88 @ Jan 22 2009, 10:38 AM) sorry off topic,but i dont want to create a new thread for this 1 question. I ever seen 3rd party company selling keyboard and mouse exclusively for Xbox360. You may check it out in online store such as play-asia etc.Can i use keyboard and mouse to play FPS game on the Xbox360? im sux when playing fps using controller |
Jan 22 2009, 10:57 AM
so,i cant use the usb keyboard/mouse from my pc?
Jan 22 2009, 11:40 AM
QUOTE(rid88 @ Jan 22 2009, 10:38 AM) sorry off topic,but i dont want to create a new thread for this 1 question. xbox 360 controller is the best controller to play FPS games on the console its my opinion la. Can i use keyboard and mouse to play FPS game on the Xbox360? im sux when playing fps using controller This post has been edited by S4PH: Jan 22 2009, 11:40 AM |
Jan 22 2009, 11:51 AM
QUOTE(rid88 @ Jan 22 2009, 10:57 AM) cannot.. u can only use keyboard/mouse specially designed for x360Added on January 22, 2009, 11:52 am QUOTE(S4PH @ Jan 22 2009, 11:40 AM) xbox 360 controller is the best controller to play FPS games on the console its my opinion la. i agreeThis post has been edited by kmeng: Jan 22 2009, 11:52 AM |
Jan 22 2009, 02:33 PM
Jan 22 2009, 03:08 PM
QUOTE(kmeng @ Jan 22 2009, 09:43 AM) First of all, we need to see what's the changes from Falcon to Jasper inside the box? I know the main cause is heat...but hiding GPU under DVD drive....i still not convince...maybe next year then we'll know.Yes, the star is here, the 65nm GPU in Jasper as compared to 90nm GPU in Falcon. No doubt the 65nm GPU draws less current thus produces less heat. As we all should know, heat is the main cause to RROD. Previously ppl also said falcon less chance of RRoD. a Lian-Li case for xbox360 seems like more promising if you modded your console.....Google for detail. QUOTE(defaultname365 @ Jan 22 2009, 02:33 PM) There is keyboard + mouse for Xbox 360 ? Play-asia ada jual mah.....Is this real ? MaxShooter or something -> » Click to show Spoiler - click again to hide... « Wow... if it is... that's awesome... |
Jan 22 2009, 03:38 PM
wow din know got such device for 360,like dat 360 is already a pc huhuhuhu
Jan 22 2009, 04:32 PM
neh...even if they have keyboard and mouse...i wont be using it...will be using my controller since xbox is mean to play using controller..y bother buying a keyboard and a mouse?like that better play ur pc...
Jan 22 2009, 04:43 PM
QUOTE(wilsonjay @ Jan 22 2009, 04:32 PM) neh...even if they have keyboard and mouse...i wont be using it...will be using my controller since xbox is mean to play using controller..y bother buying a keyboard and a mouse?like that better play ur pc... but some games on the xbox360 not available on the pc and hardware requirements for pc games will break ur pocket as graphic cards are xpensive. |
Jan 22 2009, 04:49 PM
Jan 22 2009, 11:37 PM
1,298 posts Joined: Jan 2003 From: utopia |
anyone playing GRID freeze?
does this game need to patch? |
Jan 23 2009, 12:42 AM
why so many game freezing nowadays?
Jan 23 2009, 01:03 AM
ya i also wonder
this is what i found using google http://xbox360.qj.net/GRID-Xbox-360-has-is...g/49/aid/120737 it say something a bout the HDD freeze i did install the game to my 160WD flashed HDD will try to uninstall game,play from dvd disc and see what game will freeze? |
Jan 30 2009, 12:10 AM
hi any1 know where i can fix my xbox 3rod for <RM150 with at least a month warranty?..thanks in advance
Jan 30 2009, 07:52 PM
QUOTE(S4PH @ Jan 23 2009, 12:42 AM) Prince of Persia and Far Cry 2 for me seem to be freezing. Other games, no problemo... haven't connect to Live yet, maybe got patch or something. Maybe need to clear my hard drive cache. Just checked my 'Active downloads' yesterday and found 1 exclamation mark on a download. |
| Change to: | 0.0434sec
0.71
5 queries
GZIP Disabled
Time is now: 16th December 2025 - 06:12 PM |
