 Iphone cannot get Wifi :(, baseband corrupted???
TSrlyp
post Apr 22 2008, 10:31 PM, updated 18y ago
hi ,
i'm using an iphone but out of sudden my iphone hangs everytime i boot up, so i've decided to getit back to restore mode n restore again to 1.1.4 than use Ziphone to unlock it.
but i could not get detech any wifi access point anymore sad.gif...
any1 know wut is happening here?...
i head from some forums that Zipohne will cause wifi prolbem, is that true? and what is the best way to upgrade to 1.1.4? (from OTB 1.1.2)...
really need help here, i'm lost sad.gif....
nghoongen
post Apr 22 2008, 10:34 PM
haha same problem with me but i can detect network and connect..
but cant use only xD i need the same help too !!!!
This post has been edited by nghoongen: Apr 22 2008, 10:40 PM
TSrlyp
post Apr 22 2008, 10:35 PM
after restoring back to 1.1.4 n J A U with Ziphone...i still can call out n receive in coming calls...problem is with the wifi now >_____<
nghoongen
post Apr 22 2008, 10:37 PM
your wifi can detect ur network mah ??
Choongster
post Apr 22 2008, 10:45 PM
Banned From Lowyat.net
http://www.anyiphone.com/2007/06/30/iphone-wifi-tips/
TSrlyp
post Apr 22 2008, 10:48 PM
i'm sorry i think my sentence was a lil bit confusing...
my iphone cannot detect any network access point (my own wireless router) and i'm suspecting bcos i unlock with ziphone. and i had a corrupted baseband sad.gif...
i'm trying to unlcok with iliberty now hope it works...please provide any feedback is any pros here had the same issue >____<
nghoongen
post Apr 22 2008, 10:51 PM
anggana
post Apr 22 2008, 11:24 PM
QUOTE(rlyp @ Apr 22 2008, 10:48 PM)
TSrlyp
post Apr 22 2008, 11:32 PM
yea i went DFU n tried to restore back to 1.1.1...
how how how how sad.gif...
anggana
post Apr 22 2008, 11:34 PM
QUOTE(rlyp @ Apr 22 2008, 11:32 PM)
Bro, if you restore to previous version (after upgrade), your baseband will not get downgraded (I think so), so you need to do a full restore the firmware version in which you encounter the problem in the first place or newer firmware
nokia2003
post Apr 22 2008, 11:58 PM
which week is your iphone?
LaskarCinta
post Apr 23 2008, 12:18 AM
mmm...dunno got this prob, but heard bout this bug before. i've read on ziphone.org and it says that greyed out wifi is solved in latest ZiPhone software.
TSrlyp
post Apr 23 2008, 12:50 AM
Week 47 iphone >_< OTB 1.1.2...
currently in 1.1.4 F/W ...
hmm i'll try ziphone 3.0 n c
frozzbyte
post Apr 23 2008, 01:32 AM
Feeling butthurt lately? Like I care
DON'T USE ZIPHONE ANYMORE.
ZiPhone will make your phone more unstable. ZiPhone will hardcode your WiFi MAC Address to a fixed one and not with your original MAC Address. This is what ZiPhone WiFi fix will do.
Go for the Dev team WiFi fix since u said your WiFi is grey out. Look in iphone-dev.org for the WiFi fix.
scripted
post Apr 23 2008, 01:56 AM
i've been having some weird issues with my wifi too, i don't think its related but here goes, i've notice that when i was running my wifi on channels 12 - 14 the iphone's wifi range is almost reduced to LOS baru can connect but after i changed it back to 11 its ok.. so far >_>
ziphone user here too
TSrlyp
post Apr 23 2008, 02:07 AM
i'm not quite sure how the wifi fix works :S...now, my wifi is not grey anymore...
but it doesnt make any diff...cos when i turn on my wifi basically i cant get to detect any network/access point...
and if i attempt to turn it on n off...my phone will hang and reboot...
zzzz...
any solution?
Added on April 23, 2008, 2:11 amand basically now my iphone cannot go internet via wifi, how can i download it inside my iphone to run the pwn tool thingy :S..
This post has been edited by rlyp: Apr 23 2008, 02:11 AM
scripted
post Apr 23 2008, 05:37 AM
link to iliberty tutorial
http://www.iclarified.com/entry/index.php?enid=849
was lurking the net, seems that alot of people don't really like ziphone
palmforest
post Apr 23 2008, 12:16 PM
there is some problem with your wifi calibration tables. If your wifi is greyed, try to use swifi. If it is not greyed, try Settings→General→Reset→Reset Network Settings.
If it it still cannot, u need to wait for few months time. MuscleNerd is looking on this matter.
for your reference... http://www.hackint0sh.org/forum/showthread...&highlight=wifi
This post has been edited by palmforest: Apr 23 2008, 12:16 PM
TSrlyp
post Apr 23 2008, 02:20 PM
switching between 3.9_m3s2 and 4.6_m3s2
also, flashing between baseband is not helping either ...
sigh...i guess i've use all my resources here...
i dont hav grey out wifi, just that my wifi is not detecting any network, if it does...its not connecting into it...and sometime it hangs and reboot by itself..
palmforest
post Apr 23 2008, 02:37 PM
Try to reflash your Baseband and going to 3.9 BootLoader FakeBlank
Try using Bootneuter
If those with wifi stability issues could visit the fakeblank wiki page, download that "dosyslog" zip file, then transfer the 5 files in it to the iPhone. Then from Term-VT100.app or Terminal.app go to the directory you put them in and do
sh enable.sh
It should ask you to reboot. Please reboot then go to Settings->WiFi and turn your WiFi off and on a few times. Wait about 30 seconds after turning off, then turn it on again, wait 30 seconds, then repeat one more time.
Then please email me or muscle nerd on your /var/log/syslog file
After that, feel free to go back to that directory and do "sh disable.sh" so that you don't fill up your filesystem with syslog output.
This post has been edited by palmforest: Apr 23 2008, 02:45 PM
johnny82
post Apr 23 2008, 03:30 PM
http://andrewescobar.com/archive/2007/07/0...o-the-internet/
try and see if this helps
at times i love this phone..and at times this phone can be such a retard
i would kill myself if i have to change the dns settings manually everytime since iphone cant get it right
palmforest
post Apr 23 2008, 03:35 PM
oh ya... change the dns to 202.188.0.133 might solve the problem if u r using tmnet...
TSrlyp
post Apr 24 2008, 12:21 AM
n now,
my iphone wifi is in grey mode =.= but bluebooth n other is fine...
try to run the iliberty payload thingy to resolved this grey wifi issue but fail :S...
this is getting worst T______________T!!!
Added on April 24, 2008, 12:27 amits not bout the DNS >_<...
at 1st, i got grey wifi bluebooth unaailable...i run the iLiberty, it resolved the grey out problem...but wifi still cannot detect any network/access point. after 10 minutes of try..finally it detect ...but i was unable to connect into it. tried to use static ip n force it in but failed. then my iphone will hang everytime i tried to enable my wifi search for access point....once it hang, it'll reboot and stuck at the main screen (hang again) then i havto do a force reboot (normally 5-8 times only it works)
n now, bluetooth is fine edge is fine..but wifi grey out...zzzzzz...
i wonder revirginize the ihpone is going to resolved my problem
This post has been edited by rlyp: Apr 24 2008, 12:27 AM
Choongster
post Apr 24 2008, 09:25 AM
QUOTE(rlyp @ Apr 24 2008, 12:21 AM)
n now,
are you trying with public wi-fi or your home wi-fi?
i have read some articles that some wi-fi signal/channel from modem are out of iphone's detection..
if you are using from home, try changing the wifi channel ..
palmforest
post Apr 24 2008, 09:58 AM
Your wifi greayed out. U can see NO WIFI this 2 words in Setting-Wifi.
U really need swifi bro!
Added on April 24, 2008, 10:00 amhis wifi is not related to wifi connection or channel. His iphone cant even see the mac address.. u r confusing him.
This post has been edited by palmforest: Apr 24 2008, 10:00 AM
Choongster
post Apr 24 2008, 10:07 AM
QUOTE(palmforest @ Apr 24 2008, 09:58 AM)
somehow he said he solved the greyed out wifi problem ... so assume that it might be a signal problem due to .. he got to "scanned" it after 10 mins trying ..i'm not trying to confuse him , just giving possibility of the problems here..
i guess the best thing is to start from fresh again .. revirginise the phone and re-jailbreak ..
jasonlau
post Apr 24 2008, 02:50 PM
use itunes and reflash 1.1.4.
after full restore, use iplus and you're done.
there are some fixes that you need to apply manually such as AppSupport.
heard that iliberty is good but i never tested it before.
QUOTE(rlyp @ Apr 22 2008, 10:31 PM)
hi ,
nkymark
post Apr 24 2008, 02:59 PM
No dont use ZiPhone. Yes, certain version of ZiPhone (the old one i think) will cause the WiFi problem. Even though the new version is already out (v3.0), but i'll say don try it. Just follow the guide to unlock on hackthatphone. The site has few methods to unlock, you could choose which one that you like. If you read the news on that website, it says that ZiPhone did cause problems to certain phones.
I upgraded to 1.1.4 using the guide there (i followed the iPlus one by the way) and I didnt need to install all those AppSupport and stuff. All were done internally during the unlock process.
Cheers
This post has been edited by nkymark: Apr 24 2008, 03:00 PM
jasonlau
post Apr 24 2008, 03:05 PM
AppSupport is for country code matching problem if you have problem matching with phone book.
If you don't have, then just skip it. I have the problem and i need to fix it manually.
QUOTE(nkymark @ Apr 24 2008, 02:59 PM)
Cheers
nkymark
post Apr 24 2008, 03:08 PM
QUOTE(jasonlau @ Apr 24 2008, 03:05 PM)
Yeah...depend on whether you are lucky or not. Maybe i was being lucky. Let's hope our frens here could heal their iPhones man....that is more important....
Just dont use ZiPhone again....
Cheers
Savlon
post Apr 24 2008, 04:56 PM
Aiks I have unlocked 3 phones using ZiPhone 3.0...upgraded to 1.1.4 and then do it all with ZiPhone...no problems with WIFI...
What's the difference??
maiself
post Apr 24 2008, 08:03 PM
Pro Surfer
QUOTE(Savlon @ Apr 24 2008, 04:56 PM)
same with me.. Do it All with Ziphone 3.0 rclxms.gif - flawless process
frozzbyte
post Apr 24 2008, 08:09 PM
Coz it was your lucky day. ZiPhone use the unstable RAMdisk method. It will load everything in memory. Loading big chunks of data in memory is a NO NO coz it can degrade and get corrupted. So our unlucky friend just got pawned by ZiPhone.
Moonflown
post Apr 25 2008, 11:43 AM
DayDreamer
So pwnage tool is always the best method to unlock the phone.
palmforest
post Apr 25 2008, 11:45 AM
iplus2.0b still the best.
Moonflown
post Apr 25 2008, 11:49 AM
DayDreamer
Nah. None of that can allow user to custom ipsw other than pwnage tool
TSrlyp
post Apr 26 2008, 01:18 PM
iplus = iLiberty?
hmm yea i reflash to 1.1.4 a few times n unlcok using iLiberty, none works sad.gif
i'm really worried this is a hardware problem...public or home wifi, none i can get connected into it, i'm not getting any IP at all...(btw i resolved my grey out problem)
again, everytime i tried to turn my wifi on -off trying tyo detect signal netowrk...sometime my phones get hang n reboot itself sad.gif..
is this really a hardware problem? or software? >_<
palmforest
post Apr 26 2008, 01:44 PM
hi rlyp,
try manually set the ipaddress, netmask, gateway n dns...
or u getting 169.254.x.x ip address?
TSrlyp
post Apr 26 2008, 02:37 PM
QUOTE(palmforest @ Apr 26 2008, 01:44 PM)
hi rlyp,
its not 169.xxx... (APIPA)
just cannot even get connected into it. tried static IP force in, failed as well...
chocobee
post Apr 28 2008, 01:43 PM
QUOTE(palmforest @ Apr 26 2008, 02:44 PM)
hi rlyp,
i try at my office, manage to get Public Wifi, but cant surf
ip address L 169.254.215.254'
subnet mask 255.255.0.0
Last time try near streamyx hotspot, manage to view streamyx page, but asking me to key in top up serial number, thats the max i can get using wifi sad.gif
i think my ignorance related to this
This post has been edited by chocobee: Apr 28 2008, 01:53 PM
nghoongen
post Apr 28 2008, 04:04 PM
hey my wifi ip address is 169.254.xxx.xxx and the subnet mask is the same.. wat happen to my iphone ?
Added on April 28, 2008, 10:12 pmfinally fix my iphone... my father help me change the ip address !!! yeah.
This post has been edited by nghoongen: Apr 28 2008, 10:12 PM
TSrlyp
post May 3 2008, 08:45 AM
sigh, still no luck on my iphone wifi sad.gif anyone here know any shop out there knows how to fix? willing to pay sad.gif...
0.0234sec    0.91    5 queries    GZIP Disabled
Time is now: 7th December 2025 - 12:37 AM
