Outline ·
[ Standard ] ·
Linear+
how to get fluffier thicker hair?
TSdeleted
Apr 10 2008, 05:46 PM, updated 18y ago
hey girls.. ermm i'm a guy with shoulder length hair (female tag for kopitiam purposes) anyway i have naturally straight hair, very straight, and sometimes its really flat short of perming it and tedious product + blow drying from below (?) is there any shampoos or whatever that can make my hair not so flat?
Invince_Z
Apr 11 2008, 09:17 AM
i would like to know too...
Cas
Apr 11 2008, 06:51 PM
Volumizing shampoo and hair mousse. But in order to get thicker hair or create the illusion of thicker hair, it's best to get it layered or highlighted as it creates a thicker illusion.
TSdeleted
Apr 12 2008, 01:13 PM
i'm not into dyeing hair, so i think i'll go with the shampoo what brand of shampoo should i go with for the volumizing one?
Invince_Z
Apr 12 2008, 02:27 PM
Volumizing shampoo and hair mousse....care to explain? usually what bran is good?
rida.b
Apr 13 2008, 12:11 AM
layered hair cut will do trick as well,...
