Bump TopicReply to this topicRSS feed Start new topic Start Poll
> Feel Cheated From This Tyre Shop., Heng Meng Auto Service Centre.
skyline34
post Jan 5 2008, 04:03 PM, updated 11y ago
Group: Junior Member
1st of all, i have posted that my behind tyre kena fender and i have receive all comment from here and my car ower forum. Overall i bring back told them i have this kind of problem and the guy ( claim to be pro in sports rim and tyre ) explain to me is not the tyre problem, is your car fender problem then i ask him what is your solution that you propose to me, and he said he will do the chamber thing some sort like changing screw and for that you have to paid for everything including changing the screw n do allingment and balancing. so i ask him did u said if i have any problem and you will settle for me once i install this set of rim and tyre from you, he told me that now is not the tyre problem is you car fender problem. i mean wtf total different thing from wat u saying b4. then fine i said i will be back if i wanna change.
so yesterday i went to hyundai service centre ( since im driving hyundai car ) told all the problem that im having for now after install the rim n tyre and they said they will do checking for the rim n tyre, after 30 minute the mechanic guy walk in and explain to me, for standard 195/??/15 shud use 195/50/15 is the best combination of the tyre, wtf that shop guy told me this is the best combiantion for my rims size, how come different ppl told me different story.
then fine with that, my car steering was shacking when i reach 140kmh-150kmh, so the mechanic guy ask me did i add those centre cone for the sports rim then the shop guy did intro me and install only 2 while shud 1 set coming in 4, walau, paying price for 4 cone then get 2 only. overall no responsible from the shop said will fix everything when have problem at last have to paid also, paying 4 centre cone price only get 2. @#$%^ mad.gif
Heng Meng Auto Service Centre In Danau Kota not recommended although the boss is quite good to dealing with but the workers sucks ...
This post has been edited by skyline34: Jan 5 2008, 04:50 PM
sharkteef
post Jan 5 2008, 04:22 PM
Not Godlike
Group: Senior Member
my eyes gonna pop out liao bradder. calm down and list your problems properly.
1 - in line 2 , paragraph 1 - mechanic say car fender problem not tyre problem.
in line 5 , paragraph 1 - mechanic still say fender problem not tyre problem.
so meaning he was right la
2 - there is no best combination for rim & tyres. there is threshold as in minimum limit and max limit. 195 refers to the width, the middle 50/60 refers to the height of the tyres from the edge of the rim and the rim size number behind.
people who prefer lower rides and better looks tend to go for lower profile tyres.
old man who likes comfort go for higher profiles like me. 70 series in which they call it, refers to 70mm from tip of rim to edge to tyre. so the higher the profile, the more comfort you obtain.
tyre's is all about what you like. u can have 45 series with 190 on a 15". doesnt matter. your money your call. but u need to know what suits u best.
however, i thank you for the advice u have provided. i will be wary if i ever pay heng meng auto a visit.
hope2see
post Jan 5 2008, 04:50 PM
yea man,....
it was really hard too read your story.
but many thanks for your heads up.
skyline34
post Jan 5 2008, 04:51 PM
haha ... sorry to everyone... already edited ... too angry when writing this problem ...
loonz85
post Jan 5 2008, 05:20 PM
~~loonatics~~
dude~~ try 2 cool down man~~
how much u spend for tis tyre & rims
sharkteef
post Jan 5 2008, 06:22 PM
Not Godlike
oi, u do camber must change screw wan meh ????
i did mine (not on my own coz i'm weak) at the shop took me 20 mins to adjust from -1.5 to -1. charges are bout 15 bucks i think. i remember less than 20 bucks to do camber.
the max i see ppl do alignment and balancing and paid for it is RM 70. that also is like kena "liok" liau.
scorgio
post Jan 5 2008, 07:14 PM
a classic example of tyre & rim combo doesn't suit the wheel house.
K3nnYkl82
post Jan 5 2008, 07:20 PM
NewBie
QUOTE(sharkteef @ Jan 5 2008, 04:22 PM)
Just to clear things up for u ... xxx/70/Rxx .. the 70 doesnt means 70mm .. instead it means 70% of the width of the tyre..
example .. 195/50/R15 .... 195mm width of the tyre... the high of the tyre is .. 195mm x 50% = 97.5mm and the R15 means it fits on 15" rims
ADVAN
post Jan 5 2008, 07:31 PM
Live Learn Work Play
If not mistaken i still remember u r driving a Hyunday Accent right? Actually it suit the 195/50/15 tyre only... Unless u change to a harder spring if u wan to use 195/55/15 so that it wont kena fender..
memekfalui
post Jan 5 2008, 07:48 PM
actually the problem is call rim "OFFSET". your new rim offset does not match the original lateral position of the rim and tire. so in your case your tire is place further outside of its normal position. then when you drive fast on uneven road/ bump, your tire will scratch your fender. next time find a suitable offset when you buy a new spanking sport rim.
rcracer
post Jan 5 2008, 08:11 PM
My friend the 70 is not the heigt in mm, it's called the aspect ratio which is expressed as a percentage of the tyre width. 70 means the height of the tyre is 70% the width of the tyre. 195 / 55 means tyre width is 195 mm and tyre height is 195 x 55% = 105.25 mm.
alxand
post Jan 6 2008, 09:30 AM
hmmm it's not a fender problem, if this consider fender problem, then all car got this problem, my waja cannot fir 22" sport rim, so it's fender problem? rim n tyre should fit accodring to the housing... tat shop guy ... speeechless... fender problem...
then my current lancer gt cannot put 15" so mean disc brake problem? that shop siao one smile.gif
This post has been edited by alxand: Jan 6 2008, 09:31 AM
skyline34
post Jan 6 2008, 11:41 AM
QUOTE(alxand @ Jan 6 2008, 09:30 AM)
bro, canot get what you trying to tell here?
Aeon_Clock
post Jan 6 2008, 11:59 AM
Caped Crusader
all of you should go to english class...
both questions and answers are so difficult to understand =.=
skyline34
post Jan 6 2008, 12:38 PM
QUOTE(Aeon_Clock @ Jan 6 2008, 11:59 AM)
haha .... need mou ??
chrisoys
post Jan 6 2008, 10:08 PM
QUOTE(skyline34 @ Jan 5 2008, 04:03 PM)
First of all who idea on selecting the rim & tyre type. You or the mechanic? If the mechanic choose it than he should be responsible on this problem. If not then you can't blame the mechanic explanation to you like that. I don't see any problem with the mechanic told you about your car.
Usually when you paid & change the rim & tyre. The workshop will to balancing & alignment for you FOC. They only fix/responsible on the problem of the rim & tyre if you feel anything are not right. You can go back and ask for a change.
If the tyres kena fender the problem is not on your tyre & rim is on your car fender not wide enough or poor selection choice of tyre size. Since you already fix the rim & tyre the mechanic have no choice but need to adjust the chamber in order your tyre & rim tilt inward just to make the tyre not to hit the fender. In order to adjust the chamber their need to change an adjustable pin cause our car come out from factory the pin can't be adjust. Changing the pin we need to paid & it is not cheap for 1 pin.
As for your wheel shaking driving high speed. You need to ask the mechanic do the high speed balancing. High speed balancing changes different rate compare to normal balancing. You also need to paid for that.
soulfly
post Jan 6 2008, 10:13 PM
revving towards 10,000 rpm
Overclockers United
Group: VIP
The main culprit to this whole issue is the wheel. The wheel offset is causing the wheel to "extend" outside more, hence hitting the fender when bumping or cornering.
skyline34
post Jan 7 2008, 12:24 AM
QUOTE(chrisoys @ Jan 6 2008, 10:08 PM)
for the rim is i choose myself and i also ask the boss is this rim will fit to my car? he said no problem, then fine for me, when going to the tyre i choose the eagle f1 tyre and the boss n staff over there recommended me to go for 195/55/15, i do read some topics in my car forum saying that after changing rim will kena fender wan, so i ask him will this thing will kena my fender after the installation? all answer that i get is it wont and having problem just come back to us.
since im not so good in all this, what i have to do is just to believe on what they recommend and do according to what they said, facing problem then go back to them and when at there different story coming out. sienz la. and 1 more thing they only do the balancing and no alingment has been done, when i ask no need do alingment? the mechanic said no need i already been test driving and no problem with that.
chrisoys
post Jan 7 2008, 09:06 AM
QUOTE(skyline34 @ Jan 7 2008, 12:24 AM)
If that the case. I think the boss should solve your problem by changing the tyre for you.
So, did the boss change the tyre for you? Since is the tyre choice the boss recommend are not right.
eddyann
post Jan 7 2008, 11:01 AM
Gold Miner
for vibrating at high speed >140km/h do you install those cone at front wheel? mine works after install 2 cone only and >150km/h now is no problemo on my myvi. it used to be shaking real bad reaching 120-130km/h. mine doesnt looks like a real cone. its more like a ring shape thing
This post has been edited by eddyann: Jan 7 2008, 11:01 AM
skyline34
post Jan 7 2008, 11:09 AM
QUOTE(chrisoys @ Jan 7 2008, 09:06 AM)
nop, cuz went there for 2 time also didnt see the boss. sienz ..
Added on January 7, 2008, 11:10 am
QUOTE(eddyann @ Jan 7 2008, 11:01 AM)
yup, only 2 they install this to my rim.
This post has been edited by skyline34: Jan 7 2008, 11:10 AM
chrisoys
post Jan 7 2008, 11:19 AM
QUOTE(skyline34 @ Jan 7 2008, 11:09 AM)
Maybe you need to check on the inner rim to check whether the cone got stuck there are not.
pillage2001
post Jan 7 2008, 11:40 AM
Can someone rephrase his words again?? :S
rcracer
post Jan 7 2008, 11:45 AM
The cone/ring you guys mentioned is it a thin aluminium ring that is installed between the centre hub and the centre of the rim? If yes i think that is the biggest con job because that ring does nothing useful at all. I didn't install that and i have no problems at all.
Steering vibration just means the tyre balancing is not done properly. How they mount the tyres also affects it's balance, if you notice on new tyres there is always two paint dots, one red and one yellow, these dots are actually marking the heavy and light portion of the tyre. Which is which i can't remember but i know when they mount the tyre to the rim they must line up one of those dots to the tyre valve. Then comes the balancing part which is static and dynamic. Static balances the up down bounce and dynamic balances the right and left swing. Both needs to be done to get the best results.
zeist
post Jan 7 2008, 11:46 AM
Toyota Liteace KM36
Everyone will kena the first time, learn from there.
TS: Spacing and caps please, my eyes are freaking pain while looking at it. sweat.gif
skyline34
post Jan 7 2008, 11:53 AM
so is there any solution for the fender problem other than went back to that shop?
cheeann
post Jan 7 2008, 12:03 PM
I love my suggie~
QUOTE(skyline34 @ Jan 7 2008, 12:53 PM)
can,try find a tire shop skim ur offset thinner by 5mm then ur prom will all done~
chrisoys
post Jan 7 2008, 12:19 PM
QUOTE(rcracer @ Jan 7 2008, 11:45 AM)
That aluminium cone help stable your car during high speed driving.
Here is the link for more info about tyres : - http://www.carbibles.com/tyre_bible.html
Hope this help
Added on January 7, 2008, 12:22 pm
QUOTE(skyline34 @ Jan 7 2008, 11:53 AM)
Where is the tyre hitting on your fender?
Added on January 7, 2008, 12:23 pm
QUOTE(cheeann @ Jan 7 2008, 12:03 PM)
No offence. Its not a good idea to skim the rim. You might cause the rim become weaker or unbalance.
This post has been edited by chrisoys: Jan 7 2008, 12:23 PM
cheeann
post Jan 7 2008, 12:26 PM
I love my suggie~
no offence??
dude do u know actually where i ask him 2 skimmed??
if he dun skimmed d offset slightly thinner then his car prob will stay till he change ad rims off or smaller tire which will cost him a bomb~
btw ts ur stock tire size is 185/60-14??
chrisoys
post Jan 7 2008, 12:36 PM
QUOTE(cheeann @ Jan 7 2008, 12:26 PM)
no offence??
I don't care where you going to skim the rim. Once the rim being disturbed from the original state it will not be prefect anymore.
If the rim can be skim why the manufacturer provided different offset for their consumer to choose from. That why when you choosing rim must choose the correct rim for your car. Skimming the rim is not the right option to solve his problem.
This post has been edited by chrisoys: Jan 7 2008, 12:41 PM
cheeann
post Jan 7 2008, 01:09 PM
I love my suggie~
QUOTE(chrisoys @ Jan 7 2008, 01:36 PM)
well,it's so sad tat u dunno anything tecnical about skimming~
go consult ur own mechanic b4 u start posting here~ shakehead.gif shakehead.gif
i've done tis b4 n there's no prob skimming d offset slightly thinner 2 avoid kena fender~
chrisoys
post Jan 7 2008, 02:20 PM
QUOTE(cheeann @ Jan 7 2008, 01:09 PM)
I am speechless. Maybe you can tell us more about skimming in technical. It will help us to understand more about skimming.
I think Wheel manufacturer can come out only one offset wheel type. Since mechanic can skim the wheel offset. rclxms.gif This is the mentality of a Malaysian anything also BOLEH notworthy.gif
skyline34
post Jan 7 2008, 05:58 PM
one of my friend suggest me to install the "suspension bush" ( dunno my spelling is correct or not ), does anyone install or know this item. what is the outcome results?
the place that my tyre kena fender is the outside wall, what i think is izzit my tyre too wide thats y become like this? my original rim is 185/60/14.
cheeann
post Jan 7 2008, 07:08 PM
I love my suggie~
QUOTE(chrisoys @ Jan 7 2008, 03:20 PM)
fuiyoh
u very keng~
only 1 offset wor~ rclxms.gif rclxms.gif rclxms.gif rclxms.gif rclxms.gif rclxms.gif
QUOTE(skyline34 @ Jan 7 2008, 06:58 PM)
yes i know kena outside wall tat's y i ask u go skim ur offset a bit then ur prob solve~
even if u put bush also useless as wen ur car fully loaded it'll touch d fender again~
chrisoys
post Jan 7 2008, 09:05 PM
QUOTE(cheeann @ Jan 7 2008, 07:08 PM)
fuiyoh
u very keng~
You not yet tell us (newbie) more about technical skimming cool2.gif Don't try to run away my question to you leh unsure.gif Since you are expert in this area don't be so selfish la. cool2.gif
This post has been edited by chrisoys: Jan 7 2008, 09:40 PM
cheeann
post Jan 8 2008, 01:22 AM
I love my suggie~
QUOTE(chrisoys @ Jan 7 2008, 10:05 PM)
no need 2 answer ur questions liao as u're a pro wit only 1 offset tat manufacturer only manufacture~ rclxms.gif rclxms.gif
i'm jus a noob tat din't know tat only~
cuz i know every single set of rim got diff of offsets~
This post has been edited by cheeann: Jan 8 2008, 01:22 AM
chrisoys
post Jan 8 2008, 10:02 AM
QUOTE(cheeann @ Jan 8 2008, 01:22 AM)
HUH??? Please read ppl reply carfully. My reply to you mean if you can do skimming the offset than the manufacturer no need come out so many different offset then better come out one offset. Now u say I told ppl manufacturer got one offset wheel. LOL rclxms.gif
Ask any wheel manufacturers. Let us know which wheel manufacturers recommend can skim their wheel.
This post has been edited by chrisoys: Jan 8 2008, 10:05 AM
cheeann
post Jan 8 2008, 01:26 PM
I love my suggie~
QUOTE(chrisoys @ Jan 8 2008, 11:02 AM)
i will said LOLZ~
tis is wat u've post on ur ownself n asking ppl 2 read properly???
u must b on pills or really sick till u dun even know wat did u type~ shakehead.gif shakehead.gif shakehead.gif
anyway no point talking 2 a ppl like u who dun even know wat u did/write previous post~
jus LOLZ~
chrisoys
post Jan 8 2008, 08:24 PM
QUOTE(cheeann @ Jan 8 2008, 01:26 PM)
i will said LOLZ~
jus  LOLZ~
Again & again you try to avoid my question to you about skimming rim you trying to recommend ppls to do. Stop talking crap & start talk some sense here.
Ppls in the forum want share & learn. But for you just recommend ppls to skimming rim without supporting proof that skimming will do no harm on the wheel or maybe you can show us about some write up about skimming rim also will do. This is very simple question I asking from you not like I scold you & step down on you. Why you will so offended?
All you need is just proof me wrong. That it. Like that you also cannot do?
This post has been edited by chrisoys: Jan 8 2008, 08:27 PM
cheeann
post Jan 8 2008, 08:52 PM
I love my suggie~
QUOTE(chrisoys @ Jan 8 2008, 09:24 PM)
well as i said b4~
skim a lil bit on da rim's offset will do but from ur reply terus already shoot me like a pro in tire line~
tat's y i ask u go back n consult ur own mechanic if u dunno wat am i talking about~
if u go 2 pro shop n tell them ur car's prob i'm very very sure they'll tell u straight wat 2 do~
skimming d offset ard 2-3mm will not do any harm 2 da rim but u shoot me cannot n bla bla bla~
i'll dare 2 bet wit u 2 my last penny skimming offset won't do any harm at all if u dare take d challenge~ whistling.gif whistling.gif whistling.gif
so i think u urself need 2 re-read back my post~ shakehead.gif shakehead.gif
chrisoys
post Jan 8 2008, 08:58 PM
QUOTE(cheeann @ Jan 8 2008, 08:52 PM)
well as i said b4~
Did I shoot you? Is just my opinion that skimming rim is not recommended that it I didn't say anything bad about you & bla bla bla. Please go back and read my first post to you carefully. That why I say please don't get offended about my comment.
So are you tyre & rim expert here?
Skimming rim will do no harm is based on your experience or technically?
This post has been edited by chrisoys: Jan 8 2008, 09:00 PM
cheeann
post Jan 8 2008, 11:39 PM
I love my suggie~
QUOTE(chrisoys @ Jan 8 2008, 09:58 PM)
yes as i'm working in tire line longer than u own or drive ur car~
it's thru my experience other wise i won't ask ppl 1 skim d rim's offset
chrisoys
post Jan 9 2008, 09:16 AM
QUOTE(cheeann @ Jan 8 2008, 11:39 PM)
OK. Thru experience from try & error. Thank you so much. It already answer my question.
For your info I work in automotive manufacturer basically we have alot of engineers that can gave me the answer.
This post has been edited by chrisoys: Jan 9 2008, 09:18 AM
cheeann
post Jan 9 2008, 10:34 AM
I love my suggie~
QUOTE(chrisoys @ Jan 9 2008, 10:16 AM)
basically working in manufacturer only produce but do they ever even try modified sum thing which is alreadt produce?? hmm.gif hmm.gif
chrisoys
post Jan 9 2008, 10:36 AM
QUOTE(cheeann @ Jan 9 2008, 10:34 AM)
cheeann
post Jan 9 2008, 11:03 AM
I love my suggie~
QUOTE(chrisoys @ Jan 9 2008, 11:36 AM)
then how come outside mechanic shop got do tis small things but u din't know anything about it n come said cannot do it at da 1st place wen u said got R&D dept??
chrisoys
post Jan 9 2008, 11:23 AM
QUOTE(cheeann @ Jan 9 2008, 11:03 AM)
You already feel so offended about my disagreement on your suggestion. So, I must act dumb dumb and ask the PRO here. Maybe there are something new I can learn from the PRO here mah. We are never be to old to learn new thing right?
Outside mechanics anything also can do. You don't know meh? MALAYSIA BOLEH MAH rclxms.gif
Hmmm......... I think I can fit in those Nice & Big design wheel on my small car. Some good design don't have the right offset on my car. Just skim abit the offset can already rclxm9.gif am I right?
Did you do skimming rim? Can recommend me good skimming workshop? I stay KL & PJ area.
cheeann
post Jan 9 2008, 11:29 AM
I love my suggie~
QUOTE(chrisoys @ Jan 9 2008, 12:23 PM)
sum more only 1 offset tat manufacturer produce rclxms.gif rclxms.gif rclxms.gif
chrisoys
post Jan 9 2008, 11:40 AM
Hmmm......... I think I can fit in those Nice & Big design wheel on my small car. Some good design don't have the right offset on my car. Just skim abit the offset can already am I right?
Added on January 9, 2008, 11:42 amAny specific tyre shop selling cheap quality tyre & good in fixing alignment & balancing. Require your advice here. Thanks. Still waiting for reply? I thought you work in tyre line hmm.gif No need take so long to reply me right.
Refer link below.
http://forum.lowyat.net/topic/607156
This post has been edited by chrisoys: Jan 9 2008, 11:42 AM
cheeann
post Jan 9 2008, 11:45 AM
I love my suggie~
u working in automotive manufacturer factory wor~
need look 4 me cap kaki ayam for help meh? ? LOLZ~
if cannot fix then u remake ur new design wheel for ur car till fit fit lo~
hahahahaa~
u're pro ma
i'm cons ma~
chrisoys
post Jan 9 2008, 11:48 AM
QUOTE(cheeann @ Jan 9 2008, 11:45 AM)
hahahahaa~
u're pro ma
i'm cons ma~
Don't say like that lah. Maybe I learn something new from you or even for my technical ppls also.
Any specific tyre shop selling cheap quality tyre & good in fixing alignment & balancing?
cheeann
post Jan 9 2008, 12:08 PM
I love my suggie~
QUOTE(chrisoys @ Jan 9 2008, 12:48 PM)
u got same prob wit ts meh? ?
or ur pcd cannot fit? ?
chrisoys
post Jan 9 2008, 12:14 PM
QUOTE(cheeann @ Jan 9 2008, 12:08 PM)
No problem on my ride. I just asking for recommendation where can do skimming for my friend. Cause his wheel kena his car fender. Same problem like the bro started this thread.
Do you do skimming rim? or do you know which workshop do this skimming rim?
Any specific tyre shop selling cheap quality tyre & good in fixing alignment & balancing? This is for my car.
This post has been edited by chrisoys: Jan 9 2008, 12:16 PM
cheeann
post Jan 9 2008, 03:05 PM
I love my suggie~
QUOTE(chrisoys @ Jan 9 2008, 01:14 PM)
jus go 2 any tyre shop n ask them if they can do or not as i stay very far from u~
those rims i send 2 balakong there do any repair n skimming~
wat car r u driving n wat's ur tire size~
chrisoys
post Jan 9 2008, 08:31 PM
QUOTE(cheeann @ Jan 9 2008, 03:05 PM)
Then I ask my friend go Balakong to find him self lah.
My tyre size 205/45/17
cheeann
post Jan 10 2008, 02:18 AM
I love my suggie~
QUOTE(chrisoys @ Jan 9 2008, 09:31 PM)
ok,i'll let u know wat is da shop name later ba~
but he need 2 put day car ard few hrs~
u're driving suzuki? ?
Bump TopicReply to this topicTopic OptionsStart new topic
Switch to:
0.1403sec    3.34    5 queries    GZIP Disabled
Time is now: 19th February 2018 - 11:37 AM
