 Asking about water jet
TSTheBladeRunner
post Aug 25 2025, 09:53 PM, updated 3 months ago
Anyone have the Tsunami HPC 6120? Can this unit be used with the 3rd party turbo nozzle? Main focus is to clean parking area algae/molds so I was wondering of this model have enough power to do it. Interest in HPC 7140 but that unit is brushless motor and worry about longevity but it does come with turbo nozzle. I probably use water jet maybe once a month just to do house cleaning. Thoughts?
kevinc
post Aug 26 2025, 07:34 AM
HPC 7140 is more suitable with higher pressure rate
mini orchard
post Aug 26 2025, 10:14 AM
10k Club
When pressure is too strong, it will break the cement plaster or the tiles grout.
marvinben
post Aug 26 2025, 01:26 PM
I use a normal carwash pressure washer with 25degree nozzle. Strip away algae and molds just fine. I think rotating turbo nozzle too strong, will strip away your paint too.
TSTheBladeRunner
post Aug 26 2025, 04:43 PM
QUOTE(marvinben @ Aug 26 2025, 01:26 PM)
I want rotating turbo nozzle so the job can be done faster and if can strip paint it would be nice since I have plan to paint outside wall.
GamersFamilia
post Aug 29 2025, 08:25 PM
Proud to be Malaysian
Whats the cheapest for water jet, reputable brand, budget rm500 to rm1000
netmatrix
post Aug 29 2025, 09:17 PM
From what i remember, a turbo nozzle would NOT work on anything less than 3600PSI @ 240 BAR.
All the models TS states is only 100-140 BAR. (HOME USE)
So a turbo nozzle becomes a sprinkler only. 🤭
Just a nozzle will not turn every pressure washer into an industrial strength machine. No freaking way.
All the common pressure washer only supports fan or direct jet nozzle. Or aerator for detergent foam delivery.
If you really want power and the ability to use a turbo nozzle, you need to get an industrial strength pressure washer.
Else do a little research on pre treating surfaces before power washing if you want to get rid of wall & floor algae with lower power washers.
KitZhai
post Aug 29 2025, 11:16 PM
I bought one china brand from shoppee forget 120-140 like that. Strong enough to clean every dirt. But I also rarely use it.
Dunno wanna sell it back or not coz really rare use
Jayi
post Sep 1 2025, 10:01 AM
Regular Lurker
QUOTE(TheBladeRunner @ Aug 25 2025, 09:53 PM)
I recently bought a HPC 7160. It can clean the parking area algae using the multi power nozzle but need do it slowly. Im puzzled why Tsunami didn't provide turbo / rotary nozzle for supposedly a better model.
I did asked Tsunami if we can use turbo nozzle from HPC 7140 But they say not compatible wor. So far i didn't explore with 3rd party nozzle yet
This post has been edited by Jayi: Sep 1 2025, 10:02 AM
TSTheBladeRunner
post Sep 8 2025, 04:48 PM
QUOTE(Jayi @ Sep 1 2025, 10:01 AM)
I thought hpc7160 would come with turbo nozzle since its more powerful unit given its price. Now its make me question if hpc7160 really as powerful as hpc7140 because that unit does come with turbo nozzle. Disappointing to hear because I lean towards getting hpc7160 for its induction motor.
TSTheBladeRunner
post Sep 8 2025, 04:58 PM
QUOTE(netmatrix @ Aug 29 2025, 09:17 PM)
But they demonstrate using turbo nozzle at 1:05 minutes in this video.
Even Bosch 110 have its own turbo nozzle as shown at 11:00.
bismaximus
post Sep 8 2025, 05:02 PM
I bought a Keelat Handheld one. For RM 90+ actually does the job just fine to pressure wash small sections of walls and floor at a time. Best part is small and easy storage. Cons is battery life, but hey, just buy a spare and swap that.
This post has been edited by bismaximus: Sep 8 2025, 05:03 PM
netmatrix
post Sep 8 2025, 05:59 PM
QUOTE(TheBladeRunner @ Sep 8 2025, 04:58 PM)
Then maybe the tech improved already? Before pandemic i wanted to get such nozzle for a basic 100 bar karcher but all of it shows very high PSI. The bosch one is 110 bar. So there is a limitation on how much pressure needed to use one. Even Karcher K2 is a 110 bar model that could support turbo nozzle. When i bought my unit, turbo nozzle only existed for industrial machines. So its an updated info for me then.
TSTheBladeRunner
post Sep 8 2025, 08:58 PM
QUOTE(bismaximus @ Sep 8 2025, 05:02 PM)
I don't think that type is strong enough to remove algae on floor.
TSTheBladeRunner
post Sep 8 2025, 09:10 PM
QUOTE(netmatrix @ Sep 8 2025, 05:59 PM)
Karcher calls it dirt blaster.
According to website its compatible with
K 2
K 2 Battery Set
K 2 Classic
K 2 Classic Home
K 2 Power Control
K 2 Power Control Home
K 2 Premium
K 2 Premium FJ
K 2 Premium FJ Home
K 2 Premium Home
K 2 Premium Power Control
K 2 Premium Power Control Home
K 2 Universal Edition
K 2 Universal Edition Home
K 2 Universal Edition OJ
But karcher assesories are too expensive. Hose too short and dirt blaster alone is around rm130. cry.gif
netmatrix
post Sep 8 2025, 09:58 PM
QUOTE(TheBladeRunner @ Sep 8 2025, 09:10 PM)
K 2
K 2 Battery Set
K 2 Classic
K 2 Classic Home
K 2 Power Control
K 2 Premium
K 2 Premium FJ
K 2 Premium FJ Home
K 2 Premium Home
Yeah. Thats why i was looking for compatible nozzle waayy back then.
TSTheBladeRunner
post Sep 8 2025, 10:14 PM
Found this comment on their webpage
On reason why 7160 can't use turbo nozzle
GamersFamilia
post Sep 9 2025, 12:42 PM
QUOTE(KitZhai @ Aug 29 2025, 11:16 PM)
previously bought one from tesco , rarely use it too , then my neighbour used to borrow to wash his car then he said sell it off to him , then i said okey since i dont use it much
KitZhai
post Sep 9 2025, 12:46 PM
QUOTE(GamersFamilia @ Sep 9 2025, 01:42 PM)
It's nice to wash car with that. No need soap. Just shoottttt
GamersFamilia
post Sep 9 2025, 02:51 PM
QUOTE(KitZhai @ Sep 9 2025, 12:46 PM)
Exactly, but already sold mine, but might get the portable one thru tiktok shop, battery operated
2 Pages  1 2 >Top
0.0328sec    1.19    5 queries    GZIP Disabled
Time is now: 27th November 2025 - 12:24 AM
