QUOTE(SportyHandling @ Aug 5 2025, 10:44 AM)
Thanks for the information. Nothing beats first-hand experience having compared both tyres on the same car. Surely useful and appreciated.
It looks like there is no substitute or short cut to good tyres as the more expensive Michelin Primacy 5 appears to have the upper hand when compared to the cheaper Hankook Ventus Prime 4. It is useful to note that the P5 is noticeably quieter than the VP4 since noise levels is one of the most important criteria for me when it comes to selection of tyres. I don't expect significant difference as it's all diminishing returns. As long as it's noticeable, it would be good enough.
Primacy 5's strength or main selling point is low noise and it is good to note that it delivers in this aspect. As for handling, as long as it's not too shabby it would be fine. My last experience with the old Primacy 3ST(if my memory didn't fail me) on the Ford Focus, the handling of the car on this tyre is already above average to me, largely due to the excellent chassis and tuning of the Ford Focus. I would expect the current Primacy 5 to be a significant improvement to the very old Primacy 3 or 4, so it would be an upgrade already.
The only issue with Michelin tyres is the higher price.
Will decide when the time comes. Thanks.
1 very important factor when considering the bibendum brand is its infamy of thread rubber chipping off. I did put this into consideration when deliberating between reusing VP4 or try new P5. Was having this thread rubber chip off problem across models I have used previously starting after circa 3yrs, on both low mileage and slightly higher than normal mileage cars; XM2, Primacy LC and P3ST. The only bibendum I had that didn't display this problem was Certis of 20+yrs ago.
My advise is evaluate your use pattern 1st before paying premium for this brand. If you're doing high mileage like my car; around 35-45k /year, then maybe you will most probably wear out the tyres b4 they start throwing tantrums.
If silence aka minimum road noise is of utmost importance to you, then maybe you may have to live with the "character" of bibendum brand.
If you can live with slightly higher road noise level, VP4's value can't be beaten.
***Added.... Do you notice the new P5 seems to be recycling the thread pattern of Primacy LC (PLC)? I love the PLC last time as they were dead quiet which contributed significantly in improving NVH of my Honda, which is known to have poorer sound isolation than its peers.
This post has been edited by speedy3210: Aug 5 2025, 01:04 PM
