 MODA Sportster S
TSblek
post Jan 5 2025, 05:56 PM, updated 11 months ago
QUOTE
Engine: 244 cc, liquid-cooled, single-cylinder, Euro-4 compliant
Power: 24.8 hp at 8,500 rpm
Torque: 22.5 Nm at 6,500 rpm
Wheels: 15-inch front wheel with 120/70 tire, 145-inch rear wheel with 140-60 tire
Brakes: Twin 260 mm diameter hydraulic discs in front, single 240 mm disc in the back
ABS: Two-channel ABS
Forks: Upside-down forks in front
Shocks: Preload-adjustable shock absorbers in the rear
Fuel tank: 13 liters
Weight: 186 kg
Storage: 10-liter storage compartment under the seat, storage compartments inside the front cowl
Display: 6.3-inch TFT-LCD display
Connectivity: Bluetooth connectivity to a rider's smartphone
Lighting: LED lighting throughout, front turn signals integrated into the wing mirrors
The Moda Sporter-S also has keyless start, traction control, and tire pressure monitoring.
This new scooter origin from where? or they wholly Malaysia bike
V3000
post Jan 5 2025, 06:31 PM
CLICK REPORT LAH!
Negara yg Alim dan Suci!
kelvinfixx
post Jan 5 2025, 06:51 PM
Amoda
ajaibman
post Jan 6 2025, 02:35 PM
SR300 T12 Huracan (Taro) OEM dari Zhejiang Leqi Vehicle Co.,Ltd
https://taro999.en.made-in-china.com/produc...Taro-Motor.html
Engine probably another clone of ex Vespa GTS 250 Quasar engine which already open IP similar with WMoto ES250 and Lambretta X250.
This post has been edited by ajaibman: Jan 6 2025, 02:36 PM
lowpro
post Jan 7 2025, 07:51 AM
QUOTE(ajaibman @ Jan 6 2025, 02:35 PM)
Wah, finally you reappear biggrin.gif Thanks for the info! Can post in the riding group too thumbsup.gif
TSblek
post Jan 7 2025, 09:33 PM
QUOTE(lowpro @ Jan 7 2025, 07:51 AM)
what riding group?
lowpro
post Jan 8 2025, 07:42 AM
QUOTE(blek @ Jan 7 2025, 09:33 PM)
what riding group?
We have a small riding group that started from here.
TSblek
post Jan 8 2025, 12:20 PM
QUOTE(lowpro @ Jan 8 2025, 07:42 AM)
Is the group active? Any convoy I can join?
lowpro
post Jan 13 2025, 07:45 AM
QUOTE(blek @ Jan 8 2025, 12:20 PM)
MrWrath
post Jan 13 2025, 07:55 AM
It is not a sportster, it is a sporter. I don't even know if it is a legit word.
but that is a good thing right, 6-7 bikes sharing the same engine type? example Vespa GTS, Aprilia SR Max, Wmoto ES250i, XDV250, Royal Alloy 250, Keeway Sixties 250 and Aveta Vanguard.
This post has been edited by MrWrath: Jan 13 2025, 08:01 AM
0.0140sec    0.29    5 queries    GZIP Disabled
Time is now: 26th November 2025 - 06:24 AM
