Packaging comes with this foam just to fill the empty space.
Slightly larger antenna and a couple of rare white sata cables.
There is a tiny fan in the vrm area.
This post has been edited by samftrmd: May 23 2024, 04:44 PM
Colorful motherboard
May 23 2024, 04:43 PM, updated 2y ago
#1
1,774 posts Joined: Nov 2007 From: Planet Earth |
Mod Pls don't move my thread to other sub. This is not a serious hardware topic. No traffic there. This is just something I keep as record and learn other people opinion on the build. Packaging comes with this foam just to fill the empty space. Slightly larger antenna and a couple of rare white sata cables. There is a tiny fan in the vrm area. This post has been edited by samftrmd: May 23 2024, 04:44 PM RT8081 and Slowpokeking liked this post
May 23 2024, 04:49 PM
#2
2,491 posts Joined: Dec 2004 From: initrd |
QUOTE(samftrmd @ May 23 2024, 04:43 PM) Mod Pls don't move my thread to other sub. This is not a serious hardware topic. No traffic there. This is just something I keep as record and learn other people opinion on the build. M-atx build?Packaging comes with this foam just to fill the empty space. Slightly larger antenna and a couple of rare white sata cables. There is a tiny fan in the vrm area. |
May 23 2024, 04:50 PM
#3
1,054 posts Joined: Jan 2003 |
May 23 2024, 04:53 PM
#4
27 posts Joined: Nov 2011 |
remember apply defensive installation mode
/k will share their opinion here for sure, i learnt alot form their defensive mode in my daily life to avoid many unwanted event So that your PC free from power trip, pilferage, getting older, overheated , non-performance, dropped to floor due to slippery hands, paint go off, viruses, etc |
#5
4,884 posts Joined: Jan 2003 From: Petaling Jaya |
the motherboard is not even colorful
May 23 2024, 04:55 PM
#6
191 posts Joined: Oct 2021 |
And you expect traffic here? Cannot reach 2nd page i bet.
May 23 2024, 05:04 PM
#7
198 posts Joined: Jan 2019 |
i think i am colorblind zero5177 and Rusty Nail liked this post
May 23 2024, 05:06 PM
#8
1,075 posts Joined: Oct 2022 |
I think I start to hate itx build
Too hard to upgrade Ram only 2 slot Pcie also 1 slot only And itx is not exactly small Matx is the way to go |
May 23 2024, 05:10 PM
#9
847 posts Joined: Nov 2010 |
no rgb
#10
12,062 posts Joined: Oct 2017 |
QUOTE(vapanel @ May 23 2024, 05:06 PM) I think I start to hate itx build Why need 4 slot? Not many ppl slot in 4 RAMToo hard to upgrade Ram only 2 slot Pcie also 1 slot only And itx is not exactly small Matx is the way to go smokey liked this post
QUOTE(vapanel @ May 23 2024, 05:06 PM) I think I start to hate itx build Lian li has a new matx casing that looks like an itx for those who want small casing but like you, dislike itx mb.Too hard to upgrade Ram only 2 slot Pcie also 1 slot only And itx is not exactly small Matx is the way to go I also think itx mb is unnecessary expensive given its limitations. https://lian-li.com/product/a3-matx/ vapanel liked this post
May 23 2024, 05:11 PM
May 23 2024, 05:12 PM
QUOTE(vapanel @ May 23 2024, 05:06 PM) I think I start to hate itx build My only gripe with ITX is that most of them only comes with 2 SATA ports, I'd much prefer 4 for my NAS buildsToo hard to upgrade Ram only 2 slot Pcie also 1 slot only And itx is not exactly small Matx is the way to go 2 RAM slots pretty ok for most uses, unless you're aiming for quad channel RT8081 liked this post
#14
6,035 posts Joined: Jan 2003 From: Penang |
im using colorful gpu..its ok
May 23 2024, 05:14 PM
#16
QUOTE(Rusty Nail @ May 23 2024, 05:12 PM) My only gripe with ITX is that most of them only comes with 2 SATA ports, I'd much prefer 4 for my NAS builds Normal midrange cpu not support quad channel right, even put 4 slot2 RAM slots pretty ok for most uses, unless you're aiming for quad channel Rusty Nail liked this post
May 23 2024, 05:15 PM
May 23 2024, 05:16 PM
709 posts Joined: Jun 2019 |
Looks nice compared to most vanilla mobos.
May 23 2024, 05:17 PM
May 23 2024, 05:20 PM
May 23 2024, 05:21 PM
May 23 2024, 05:23 PM
May 23 2024, 05:24 PM
#25
May 23 2024, 05:41 PM
Evolv shift 2
Instead of metal side panel, it's fabric covering a plastic frame. The fabric is glued on, not readily removable for cleaning. Top panel is also has a filter, not readily removable as well. The panel is push-release spring loaded. Only 2*usb3.0 Gen 3 cable only. Only power button, the other 2 are for argb. Comes with 1 fan. |
May 23 2024, 05:44 PM
#27
1,294 posts Joined: Feb 2012 From: Taman Rasa Sayang, Cheras |
How's the bios, easy to use?
#28
QUOTE(PJng @ May 23 2024, 05:10 PM) Just for upgrade ability in case ram gets even cheaper QUOTE(samftrmd @ May 23 2024, 05:10 PM) Lian li has a new matx casing that looks like an itx for those who want small casing but like you, dislike itx mb. I think it's still big right? Problem is GPU too big I also think itx mb is unnecessary expensive given its limitations. https://lian-li.com/product/a3-matx/ 4060 LP is great invention Itx should pair with 4060lp QUOTE(Rusty Nail @ May 23 2024, 05:12 PM) My only gripe with ITX is that most of them only comes with 2 SATA ports, I'd much prefer 4 for my NAS builds You remind me that I hate itx because it only have 2 NVME slot2 RAM slots pretty ok for most uses, unless you're aiming for quad channel QUOTE(samftrmd @ May 23 2024, 05:41 PM) I always think this type of installation reduce GPU performanceThis post has been edited by vapanel: May 23 2024, 05:46 PM |
May 23 2024, 05:54 PM
May 23 2024, 05:55 PM
May 23 2024, 05:58 PM
#31
55 posts Joined: Jul 2013 |
May 23 2024, 06:03 PM
QUOTE(knazlee @ May 23 2024, 05:58 PM) Nice. The 16gb a770. Although its a bit overpriced for our market https://www.msi.com/Motherboard/MAG-B650M-MORTAR-WIFIWhat MB would you suggest for a b650m bulld? Somewhat decent for a budget build I like the chipset and vrm heatsink. Also, a slightly better audio chip. I just bought it's B760m variant. Remember to check ram qvl before you buy. alfiejr liked this post
May 23 2024, 06:04 PM
May 23 2024, 11:26 PM
#34
QUOTE(samftrmd @ May 23 2024, 06:03 PM) https://www.msi.com/Motherboard/MAG-B650M-MORTAR-WIFI Ahh the mag mortar. I was actually looking at asrock b650m pro rs wifi with predator pallas II 16x2 cl30 6000. Now that i checked its not on QVL list. Thanks for the reminder broI like the chipset and vrm heatsink. Also, a slightly better audio chip. I just bought it's B760m variant. Remember to check ram qvl before you buy. This post has been edited by knazlee: May 23 2024, 11:28 PM samftrmd liked this post
May 23 2024, 11:36 PM
4,254 posts Joined: Nov 2011 |
QUOTE(vapanel @ May 23 2024, 05:06 PM) I think I start to hate itx build the issue with mITX is as usual the pricingToo hard to upgrade Ram only 2 slot Pcie also 1 slot only And itx is not exactly small Matx is the way to go youre paying more for less ive gone thru mITX also, it was great until you realised more shortcomings than good ones vapanel liked this post
May 24 2024, 12:48 AM
#36
May 24 2024, 11:10 AM
8,387 posts Joined: Feb 2014 |
QUOTE(samftrmd @ May 23 2024, 04:43 PM) Mod Pls don't move my thread to other sub. This is not a serious hardware topic. No traffic there. This is just something I keep as record and learn other people opinion on the build. Too late. » Click to show Spoiler - click again to hide... « QUOTE(pureawesomeness @ May 23 2024, 04:55 PM) |
May 24 2024, 11:39 AM
I actually don't feel like continue in this thread anymore, but I just want to comment on the casing. I think it's previous design is much better. Material used are more premium. This casing design seems to not account for the tubes and cables. The 2*2.5" is too close together and the opening is also too close the the tray. The SATA cable will need to be bent on the near plug, which is very damaging. As shown in the picture, the tubes need to be twisted to fit in. Various fan cables are too close to the fan. Almost no consideration in the design for the psu cables... I will avoid this casing for my own computer. RT8081 liked this post
May 24 2024, 03:07 PM
1,596 posts Joined: Mar 2014 From: 75°26'11.6"S, 136°16'16.0"E |
it seems /k mods dislike u in some ways
May 24 2024, 04:17 PM
976 posts Joined: Nov 2014 From: Sandakan, Sabah |
QUOTE(Rusty Nail @ May 23 2024, 05:21 PM) nope. x79 and x99 also can do quad. x58 only do triple channel. Rusty Nail liked this post
May 24 2024, 07:24 PM
356 posts Joined: May 2022 |
QUOTE(samftrmd @ May 23 2024, 04:43 PM) Mod Pls don't move my thread to other sub. This is not a serious hardware topic. No traffic there. This is just something I keep as record and learn other people opinion on the build. how much is this board ? is this matx ?Packaging comes with this foam just to fill the empty space. Slightly larger antenna and a couple of rare white sata cables. There is a tiny fan in the vrm area. |
May 24 2024, 07:28 PM
#42
QUOTE(RT8081 @ May 24 2024, 07:24 PM) Don't know price. Itx.Itx is conventionally unnecessary expensive compared to matx. For this kind of money, recommend to get something more reputable. RT8081 liked this post
May 24 2024, 07:40 PM
May 25 2024, 12:16 PM
2,711 posts Joined: Apr 2017 |
May 25 2024, 12:24 PM
QUOTE(RT8081 @ May 24 2024, 07:40 PM) MATX offers a good compromise of being smallish yet similar/cheaper price than equivalent full ATX. They also have compact cases that are nearly as small as ITX XL cases without the thermal penaltyhttps://www.funkykit.com/reviews/chassis/co...chassis-review/ https://basic-tutorials.de/tests/pc-hardwar...li-dan-a3-matx/ The downside is their VRM might not be as plentiful as its ATX brother so you shouldnt fit like an i9 or R9 CPU but then so too is much of ITX mobos. |
May 25 2024, 12:27 PM
#46
QUOTE(babylon52281 @ May 25 2024, 12:24 PM) MATX offers a good compromise of being smallish yet similar/cheaper price than equivalent full ATX. They also have compact cases that are nearly as small as ITX XL cases without the thermal penalty thanks! am looking for medium built like amd ryzen 5 or i5 equivalent so i guess matx will be ok for mehttps://www.funkykit.com/reviews/chassis/co...chassis-review/ https://basic-tutorials.de/tests/pc-hardwar...li-dan-a3-matx/ The downside is their VRM might not be as plentiful as its ATX brother so you shouldnt fit like an i9 or R9 CPU but then so too is much of ITX mobos. |
Aug 9 2024, 02:03 PM
Aug 9 2024, 06:57 PM
#48
Elite
15,694 posts Joined: Mar 2008 |
QUOTE(RT8081 @ May 25 2024, 12:27 PM) thanks! am looking for medium built like amd ryzen 5 or i5 equivalent so i guess matx will be ok for me M-ATX is fine.Just check the TDP then you will get an idea. All boards should be able to run 65W, with potential limited boost clock. If the it is 105W/120W then middle-high models will be ok. You will need to the get flagship board (i.e. MSI Mortar) for those higher. HardwareUnboxed has plenty of videos specific to the power delivery of the boards, and you check where it see fits (He stress-tested the boards with the highest end processor). This post has been edited by kingkingyyk: Aug 9 2024, 06:57 PM RT8081 liked this post
Aug 9 2024, 09:27 PM
#49
QUOTE(kingkingyyk @ Aug 9 2024, 06:57 PM) M-ATX is fine. thanks!Just check the TDP then you will get an idea. All boards should be able to run 65W, with potential limited boost clock. If the it is 105W/120W then middle-high models will be ok. You will need to the get flagship board (i.e. MSI Mortar) for those higher. HardwareUnboxed has plenty of videos specific to the power delivery of the boards, and you check where it see fits (He stress-tested the boards with the highest end processor). |
| Change to: | 0.0249sec
2.09
6 queries
GZIP Disabled
Time is now: 23rd December 2025 - 07:58 PM |
