so how much does a wireless cabel cost?
wat brand do u recommend?
and how is the quality??
Questions bout wireless cabel for electric guitar
Oct 31 2007, 09:55 PM, updated 19y ago
#1
170 posts Joined: Sep 2007 |
im planing to get a wireless cabel for my electric guitar cause when i perform on stage in school,i want to jump and spin on stage but the stupid cabel limit my stunts
so how much does a wireless cabel cost? wat brand do u recommend? and how is the quality?? |
Oct 31 2007, 10:16 PM
#2
2,650 posts Joined: May 2005 |
jumping on stage? performing for looks eh
you can jump with a cable no problems. even herman li did it when he came here few months back just be very sure of what you're doing and dont trip over when you jump. you can try hooking your cable to your strap so that its abit higher and you wont trip over it that easily. other than that should be fine. if you still insist on a wireless cable, i can't help you there |
#3
VIP
13,063 posts Joined: Jan 2003 From: Toronto |
It's cheaper to get an extra long cable.
Wireless Guitar setups are expensive and the average priced ones doesn't sound good at all. Zakk Wylde uses like, a 50ft Monster Cable..... he hates the quality of any wireless system, no matter HOW expensive. |
Oct 31 2007, 10:51 PM
#4
QUOTE(SweetTooth @ Oct 31 2007, 10:16 PM) jumping on stage? performing for looks eh jumping no problem. but spinning and SPIN WHILE JUMPING that need wireless cabel maT.T i achieve that but got darn cabel block my wayT.Tyou can jump with a cable no problems. even herman li did it when he came here few months back just be very sure of what you're doing and dont trip over when you jump. you can try hooking your cable to your strap so that its abit higher and you wont trip over it that easily. other than that should be fine. if you still insist on a wireless cable, i can't help you there QUOTE(blacktrix @ Oct 31 2007, 10:16 PM) It's cheaper to get an extra long cable. zzzzzzzzzzzzzzzzWireless Guitar setups are expensive and the average priced ones doesn't sound good at all. Zakk Wylde uses like, a 50ft Monster Cable..... he hates the quality of any wireless system, no matter HOW expensive. so wireless cabel sucks T.T how much does the cheapest cost |
Oct 31 2007, 11:07 PM
#5
VIP
Probably the cheapest I can recommend is the AKG wireless system.....
http://www.musiciansfriend.com/product/AKG...tem-?sku=275682 About USD 250...... but good luck finding it here in Malaysia. |
Oct 31 2007, 11:12 PM
#6
QUOTE(ongpohheng @ Oct 31 2007, 10:51 PM) jumping no problem. but spinning and SPIN WHILE JUMPING that need wireless cabel maT.T i achieve that but got darn cabel block my wayT.T try jumping OVER the cable?zzzzzzzzzzzzzzzz so wireless cabel sucks T.T how much does the cheapest cost i don't see why its so hard to spin, the cable won't be in the way most of the time. improvise? |
Oct 31 2007, 11:25 PM
#7
VIP
Closest distributor for AKG Distributor are in Singapore:
ASI DISTRIBUTION PTE LTD. 289B Outram Road 169071 Singapore Eric Chow Phone: +65 6225 1661, Mobile +65 94571101 Fax: +65 6225 1771 Maybe you can contact them and see if they have a satellite distributor here in KL |
Oct 31 2007, 11:48 PM
#8
3,373 posts Joined: Jan 2003 From: My House |
Herman did a rather decent spin with the cable.
and how do you play decently when 'spinning' anyway? I think quite a few guitarists pulled off the jump-spin rather well with cables |
Nov 1 2007, 12:15 AM
#9
QUOTE(blacktrix @ Oct 31 2007, 11:07 PM) Probably the cheapest I can recommend is the AKG wireless system..... OMG http://www.musiciansfriend.com/product/AKG...tem-?sku=275682 About USD 250...... but good luck finding it here in Malaysia. so expensive? i thought it wil be 500-700 range. >>..<< too expensive for a student to affordT.T QUOTE(nerd @ Oct 31 2007, 11:48 PM) Herman did a rather decent spin with the cable. any video of them jump-spin with cable?? i want to watch and learn and how do you play decently when 'spinning' anyway? I think quite a few guitarists pulled off the jump-spin rather well with cables many band like fall-out-boys or simple plan achieve jump-spin with wireless cabel during live concert |
Nov 1 2007, 12:27 AM
VIP
Nov 1 2007, 12:48 AM
sorry, my bad. didn't recall him using a wireless CABLE system. i know he used the wireless wah though |
Nov 1 2007, 01:26 AM
5,231 posts Joined: Jan 2005 From: Pea Jay |
Focus on the music and don't do too much stunt lar... seriously, it's not worth it to spend so much on a wireless system, no matter how cool the idea is.
Plus, there're lotsa other cable-friendly stunts that you can pull off live. |
Nov 1 2007, 01:50 AM
just do a power slide
follow what tenacious D teach in the pick of destiny |
Nov 1 2007, 08:25 AM
203 posts Joined: Jul 2007 From: Indianapolis, USA (but still a PJ boy) |
If it's just one show, I don't think it's worth it. Also, for most gigs in Malaysia, the venue/organizers provide a backline (the amps, drumkit) for all the bands. If you get a wireless system, you might have to set it up beforehand and maybe even have to share...
Play the music, and the rocking out will come naturally. And note that sometimes those jumps and stuff are exaggerated for music vids. When they do it live, it's usually just accompanied by a held chord or a slide down/up the fretboard - not much finger gymnastics while jumping around, that's for sure. QUOTE(SweetTooth @ Nov 1 2007, 01:50 AM) But then you'd have to worry about stage size and/or rugburn (or stageburn?). Ouch! |
Nov 1 2007, 10:00 AM
Moderator
4,765 posts Joined: Jan 2003 From: Kuala Lumpur |
wireless with have not only have a slight drop of quality but also add slight compression.
a normal unit like the sennheiser will cost about rm2k+. dont get it unless u really know what u're doing. setting it up will take a while and u need to work with the sound ppl too. you dont want them to set wireless microphones, etc to your guitar's wireless frequency. alot of other things to consider. dont get that guitar bug(the link blacktrix posted). quality is a little fuzzy and ive seen people who use it experience problems (fuzz, cracks/pop and tempororily no sound). well maybe it was bad luck, but we guitarist already have enough of gear. the more 'canggih' gears u add in, the more chances of u having technical problems during the show and ruin ur show. no offence, but a wireless system for just a concert in school??!! spend more time trying to make music that make the crowd jump and spin around, not yourself syiok sendiri up on stage. |
Nov 1 2007, 12:43 PM
1,399 posts Joined: Sep 2004 From: KL PJ |
get a great cable is reli better
buy smtn like MONSTER cable and ul appreciate the minimum toneloss |
Nov 1 2007, 02:17 PM
VIP
That's why I said, get a super long monster cable instead....... you'll be much happier with the overall results.
Nov 1 2007, 05:24 PM
2,283 posts Joined: Apr 2007 |
Meh,spinning a guitar?That is so not metal XD
Nov 1 2007, 06:26 PM
1,171 posts Joined: Jun 2006 From: temporarily Munich |
regi had a cable on
http://www.youtube.com/watch?v=8vdJvHE8qxA Don't mind the noise in the first 3:45 of the clip though |
Nov 1 2007, 07:23 PM
1,170 posts Joined: May 2007 |
Nov 1 2007, 07:28 PM
209 posts Joined: Dec 2006 |
guitar spinning is metal la..those 80's rock guitarists did it way back then..
Nov 1 2007, 07:42 PM
Staff
30,735 posts Joined: Jan 2003 |
yea la, malmsteen and every other guitarist from the 80s did that already.
Nov 1 2007, 07:53 PM
QUOTE(Bassix @ Nov 1 2007, 06:26 PM) regi had a cable on Omg nice spin!this is so damn cool and im soooo GOING TO LEARN THAT MOVE http://www.youtube.com/watch?v=8vdJvHE8qxA Don't mind the noise in the first 3:45 of the clip though QUOTE(Rossie @ Nov 1 2007, 07:23 PM) NICE NICE!! but he was using wireless syetemTTit seems that buying wireless cabel is a reckless disicion i guess. Any more guitar stunts i can do with a cabel???????? This post has been edited by ongpohheng: Nov 1 2007, 07:54 PM |
Nov 1 2007, 08:18 PM
QUOTE(ongpohheng @ Nov 1 2007, 07:53 PM) Omg nice spin!this is so damn cool and im soooo GOING TO LEARN THAT MOVE Hang your vocalist?NICE NICE!! but he was using wireless syetemTT it seems that buying wireless cabel is a reckless disicion i guess. Any more guitar stunts i can do with a cabel???????? |
Nov 1 2007, 08:20 PM
QUOTE(ongpohheng @ Nov 1 2007, 07:53 PM) it seems that buying wireless cabel is a reckless disicion i guess. yeah. sweep an arpeggio, thats a stunt Any more guitar stunts i can do with a cabel???????? or you can do a guitar spin. if you're not too confident, do it at the end of the gig. quickly detach the cable before you do it |
Nov 1 2007, 08:23 PM
Nov 1 2007, 08:27 PM
wait.. wireless guitar cable.. doesn't it sound very contradictory? lol
Nov 1 2007, 08:36 PM
Nov 1 2007, 08:39 PM
detach the cable wit the amp on
den u can listen to how a tube blows |
Nov 1 2007, 08:41 PM
Nov 1 2007, 08:42 PM
Staff
it'll be so obvious if you plug out the cable...
then everyone will just think...what a monkey |
Nov 1 2007, 08:52 PM
well, as long as it makes TS look cool
Staff
the only cool looking monkey around is mojo jojo.
Nov 1 2007, 08:53 PM
QUOTE(Everdying @ Nov 1 2007, 08:42 PM) T.T man,why couldnt wireless system cost as cheap as a computer's wireless router........ Any video or any tips?? just last 2 week i on stage play the song avril lanvinge-girlfriend with some girls. but i wasnt able to do any stunts because of the stupid cabelT.T |
Nov 1 2007, 08:59 PM
Staff
go watch 'pick of destiny'.
learn the powerslide |
what stunts are you looking at? backflips?
Nov 1 2007, 09:05 PM
Nov 1 2007, 09:07 PM
Staff
linkin park can do backflips?
i thought they can only bendover and wait for zakk wylde to come in. |
Nov 1 2007, 09:09 PM
VIP
Ok, This is going waaaaaaaaaaaaaaaaaaaaaaaay off topic already.
If you are decided about a wireless guitar system, then I'm going to close this thread and you can continue your discussion in the Guitar Phreaks Club thread. |
Nov 1 2007, 09:15 PM
QUOTE(blacktrix @ Nov 1 2007, 09:09 PM) Ok, This is going waaaaaaaaaaaaaaaaaaaaaaaay off topic already. well,after reading all the post, i guess im not buying wireless due to too many reasons.If you are decided about a wireless guitar system, then I'm going to close this thread and you can continue your discussion in the Guitar Phreaks Club thread. ANyway,thz for the support guys! -CLOSED- |
| Change to: | 0.0247sec
0.60
5 queries
GZIP Disabled
Time is now: 19th December 2025 - 03:04 PM |
