 High cholesterol & plaque buildup in blood vessels, What tests and where available in Penang
TSsharp56
post Oct 20 2023, 01:29 PM, updated 3y ago
I am over 60 years old and having high cholesterol for years. I understand there is a risk of plaque buildup in the blood vessels although I have no symptoms.
Is there a medical check-up for plaque buildup available in the clinics or companies like BP Lab, etc in Penang? What tests should I request and the cost of such a test?
This post has been edited by sharp56: Oct 20 2023, 01:33 PM
sameday
post Oct 20 2023, 01:38 PM
can just go for this screening..
https://ihealmedical.com/heart-screening-package/ just opt for the heart scanning will do.
--> MSCT Coronary Angiography Using 640-Slice CT Scanner
https://ihealmedical.com/ct-angiography/
This post has been edited by sameday: Oct 20 2023, 01:40 PM
lorkh
post Oct 20 2023, 01:45 PM
i'd suggest you go for a full health screening including ECG stress test (running on treadmill) to check for heart abnormality.. over 50 cost from rm800 onwards... i don't think plague buildup in blood vessels will give any symptoms at all
TSsharp56
post Oct 20 2023, 01:52 PM
QUOTE(sameday @ Oct 20 2023, 01:38 PM)
Thanks for the info. What would be the approximate cost?
Don't I need to check for the blood vessels on the head (risk of stroke) in addition to the heart?
zannisenhart
post Oct 20 2023, 01:58 PM
CT coronary angiogram. This is the test to check coronary arteries of heart. Detect blockages. Approximately rm3k.
SupermanLick
post Oct 21 2023, 11:00 PM
👊PUNCH SOHAI🗣️
High flow dialysis machine can flash the plaque buildup
SUSsexysarah1992
post Oct 21 2023, 11:10 PM
QUOTE(sharp56 @ Oct 20 2023, 01:29 PM)
Go and take BG22 oat everyday la. U need to change your diet. I started taking oats and cut down on alot of oily food. My cholesterol levels have improved and i lost a ton of weight.
VeeJay
post Oct 22 2023, 03:34 PM
QUOTE(zannisenhart @ Oct 20 2023, 01:58 PM)
sharp56 This! Go for CTCA instead of MSCT, it has better accuracy.
Check out Columbia ASia, they normally run a better deal. All the best
Dothan
post Oct 22 2023, 03:38 PM
Dingle Berries
CT based scan is not optimum for heart as the heart keeps beating.
If you have symptom like breathlessness, chest pressure or pain, even very little, better get the real angiogram.
0.0156sec    0.73    5 queries    GZIP Disabled
Time is now: 30th November 2025 - 11:20 AM
