QUOTE(Skylinestar @ Feb 2 2023, 11:23 AM)
Hmmm. That is complicated for non IT people.Is this bad luck for SSD?, Feels like premature failure
Feb 2 2023, 02:35 PM
72 posts Joined: Jan 2023 |
Feb 3 2023, 11:14 PM
1,760 posts Joined: Nov 2020 |
QUOTE(Nirnama @ Feb 2 2023, 02:35 PM) Yeah it's not about brand but specific model, like Kingston A400 was bad but KC2500 was the best bang for buck SSDor recently a lot of Samsung SSDs having problem even for IT people its complicated Since the manufacturers dont tell you what stuff is inside so you have to rely on 3rd party reviews but even then, manufacturers like to change out components over time either to cut costs, or forced to change due to component shortages, which would cause an improvement or decrease in peformace. When the community go complain, well, they say they didnt sell it based on components, just model and expected peformance so they have the right to change stuff as long as the peformance is still close to as advertised For most consumers they just expect you to grab whatever is in your budget and enjoy without thinking about the specs inside Nirnama liked this post
Feb 3 2023, 11:21 PM
#23
10,538 posts Joined: Oct 2017 |
how to check what controller that SSD use?
Feb 4 2023, 11:12 AM
#24
QUOTE(PJng @ Feb 3 2023, 11:21 PM) Best way is to just pop open your SSD, but depending on the manufacturer your warranty may be void2nd best would be just 3rd party reviews on sites and databases such as techpowerup's SSD database or NewMaxx's SSD Spreadsheet Or just go stick with well known reputable models like the Crucial MX500 |
Feb 4 2023, 11:52 AM
#25
QUOTE(PRSXFENG @ Feb 4 2023, 11:12 AM) Best way is to just pop open your SSD, but depending on the manufacturer your warranty may be void 2 month ago i get transend s230 sata ssd 1TB, less that RM250, hope no issue2nd best would be just 3rd party reviews on sites and databases such as techpowerup's SSD database or NewMaxx's SSD Spreadsheet Or just go stick with well known reputable models like the Crucial MX500 |
Feb 9 2023, 02:58 PM
144 posts Joined: Aug 2022 |
Get a reliable brand. I using Samsung and so far 2 years+ and still perfect condition.
Feb 9 2023, 03:02 PM
#27
1,111 posts Joined: Oct 2021 |
Feb 9 2023, 03:29 PM
955 posts Joined: Jan 2003 From: setapak |
among many.. crucial SSD still working...
Mar 27 2023, 09:15 PM
274 posts Joined: Mar 2015 |
QUOTE(Skylinestar @ Jan 29 2023, 08:45 PM) Powered up my PC today and saw this message: were you able to extract much of the files?CODE ata2: COMRESET failed (errno=-16) ata2: reset failed, giving up i took out the ssd and put it inside my ugreen usb casing. read it on another pc. this is the info: SSD life left = 0 2 years old only. It is Patriot Burst 240GB. I bought it on shopee. Ad says manufacturer warranty. But the packaging for the ssd does not have CUDO distributor sticker. I have bought many corsair stuff that has CUDO sticker. Will CUDO at Imbi entertain my RMA? https://www.patriotmemory.com/distributors/asia UPDATE1: Sent to CUDO for warranty. UPDATE2: CUDO replaced Patriot Burst (with dram cache) with Patriot P210 (without dram cache). |
Mar 28 2023, 07:26 AM
#30
10,092 posts Joined: Jan 2003 From: Sarawak |
Mar 30 2023, 07:43 PM
6,491 posts Joined: Jan 2003 From: Zion |
So i came across this situation where a PC will hang for unknown reasons. The PC has a kingtston A400 480GB installed in it, split into 2 partitions. The hard disk is 90% filled with OS, Apps & Data.
So decided to reduce the drive usage by moving out files until the SSD has about 60% used. The hang problem went away. Ran Crystaldiskinfo and the disk is 97% healthy. 3 percent is problematic and is shown as bad blocks. So TRIM is working. The next week i decided to try something. I created a 7% (34GB) Over Provisioning partition that does not have a drive letter assigned to it and labeled it OP. I moved back all the files and filled the drive about 90% used capacity. And its already 2 weeks and the PC did not hang. Summary is, TRIM works. But it will use space. And space does not magically appear. Creating a special partition to accommodate all these damaged blocks kind of makes sense why the PC did not hang. Even Samsung drives offers this function for all their SSD drives for obvious reasons. But this does not solve SATAFIRM issue where it is clearly hardware controller issue. Nothing to do with the NAND chips. This post has been edited by netmatrix: Mar 30 2023, 07:45 PM |
Change to: | 0.0150sec
0.30
5 queries
GZIP Disabled
Time is now: 29th March 2024 - 04:45 PM |
