 Affordable Kapchai or Scooter Recommendation, For less than 10km commute.
TSinjang
post Sep 28 2022, 10:46 AM, updated 4y ago
Im currently searching for cheap cheap motorcycle for commuting to college back and forth. Secondhand also can. As long as the price is around RM2-4k.
Im eyeing on EX5, Wave 100 for now. But need better recommendation which including cheap maintenance, and price.
This post has been edited by injang: Sep 28 2022, 11:01 AM
Noryume
post Sep 28 2022, 11:01 AM
QUOTE(injang @ Sep 28 2022, 10:46 AM)
If want scooter avantiz or solaris quite ok. Basically both same bike.
Other to consider lagenda or modenas bike.
SpiderMon68
post Sep 28 2022, 11:09 AM
https://shopee.com.my/Honda-Sundiro-S07-Ele...cxoCtLMQAvD_BwE
RM4600 electric scooter from Honda
zegapain
post Sep 28 2022, 11:14 AM
Go check out modenas kriss good enough with low budget compare to honda.
TSinjang
post Sep 28 2022, 11:21 AM
QUOTE(Noryume @ Sep 28 2022, 11:01 AM)
How is the scooter maintenance and reliability compared to kapcai one? Planned to use max for at least 2 years before sell it back.
TSinjang
post Sep 28 2022, 11:22 AM
QUOTE(SpiderMon68 @ Sep 28 2022, 11:09 AM)
Good recommendation but the max speed is only 25kmh. The road that I will commute is quite busy.
jaycee1
post Sep 28 2022, 11:34 AM
AFK
Aveta Ranger 110. Other than the horrid front brakes, it is robust and reliable. The twin spar tubular frame on it is far stronger than normal kapchais. My friends go offroad on with with knobbies.
about 3k new if you can find discounts.
This post has been edited by jaycee1: Sep 28 2022, 11:37 AM
TSinjang
post Sep 28 2022, 11:49 AM
QUOTE(jaycee1 @ Sep 28 2022, 11:34 AM)
Good suggestion. love the design too, can feel the C70 vibe.
Strike Eureka
post Sep 28 2022, 05:52 PM
ego gear ok .....
iambryan1234
post Sep 28 2022, 07:17 PM
Forget the Kriss, Aveta Ranger is pretty solid but you might want to look into getting better front brakes.
There's a low mileage Honda Wave 100 going for 3k around my area if you're interested
Automatic bike/scooter going to be pricy so skip them unless you got skill issue
This post has been edited by iambryan1234: Sep 28 2022, 07:23 PM
Vellfire93
post Sep 28 2022, 07:44 PM
QUOTE(zegapain @ Sep 28 2022, 11:14 AM)
My father's 20+ years old kriss is still going strong even after the bike got into multiple accidents
iambryan1234
post Sep 28 2022, 08:00 PM
QUOTE(Vellfire93 @ Sep 28 2022, 07:44 PM)
The bikes based on Kawi Kazes are still fine, the Chinese ones are generally shit at everything
zegapain
post Oct 1 2022, 12:11 PM
QUOTE(iambryan1234 @ Sep 28 2022, 08:00 PM)
Maybe you are right. However, i owned 2 different old version of Kriss 100 both are in good condition. Hence, the latest Kriss im not sure of it.
iambryan1234
post Oct 2 2022, 04:24 AM
QUOTE(zegapain @ Oct 1 2022, 12:11 PM)
Electronics failure, using the brakes will actually cause your signal lights to go haywire, owners complaining about broken exhausts after a year or two, unstable as fuck, questionable reliability (its a zongsheng whaddaya expect) yada yada yada
Thats why the older ones that were co developed with Kawasaki are way better
This post has been edited by iambryan1234: Oct 2 2022, 04:25 AM
leon898
post Oct 4 2022, 11:00 AM
RM2k-RM4k means you are looking for cheapest bike:
i. Wave 100 1st model
ii. Wave 100R (better look)
iii. Suzuki smash 110 revo
iv. Suzuki smash v115
v. old modenas (kriss I/Kriss II)
0.0174sec    0.52    5 queries    GZIP Disabled
Time is now: 27th November 2025 - 06:39 PM
