Outline ·
[ Standard ] ·
Linear+
Recommend myvi lgi best rotor and pad
TSPlatinum Sand
May 21 2022, 12:22 PM, updated 4y ago
I have use this TF brand ,rotor with holes. Been using for 2-3 years d. But somehow feels like the rotor cepat nipis. Pad change only 1 time . I realized the rotor itself is much thinner than Ori myvi rotor. Now thinking to change new rotor,what brand is recommended? I saw alot online but still not sure which brand is more lasting. And 1 more thing happen, after change to TF rotor. I never had abs effect. Ever I emergency brake also no abs function. Weird
ktek
May 21 2022, 08:28 PM
ur spec got abs or not
ktek
how about ori lifespann
ktek
May 21 2022, 08:29 PM
StrikeQUAN he mod brakes a lott
TSPlatinum Sand
May 22 2022, 12:36 PM
QUOTE(ktek @ May 21 2022, 08:28 PM) Abs got. Myvi lagi best bro. Ori rotor use about 8-9 years d. Reason change Ori rotor is the rotor makan d,. Can skim but I decided change. Every time brake sure got sharp sound tats y I change to rotor with holes. New rotor seem to be lot thinner compare to Ori. Then since tat I never experienced my abs bro .
ktek
May 22 2022, 06:05 PM
leg brake + hand brake. see abs work or not
kdr93
May 23 2022, 04:00 PM
Go for TRW rotors.
They are quite good and reasonable price. It is a sub company under ZF, the famous gb manufacturer.
Default would be brembo, not sure if got discs for your model.
TSPlatinum Sand
May 23 2022, 04:26 PM
QUOTE(kdr93 @ May 23 2022, 04:00 PM) Go for TRW rotors. They are quite good and reasonable price. It is a sub company under ZF, the famous gb manufacturer. Default would be brembo, not sure if got discs for your model. I saw some ppl do use trw rotor. And I been asking their feedback. Brembo can't afford la bro. The price anytime might be more expensive than my car.i mean for Ori brembo .
kdr93
May 23 2022, 05:54 PM
QUOTE(Platinum Sand @ May 23 2022, 04:26 PM) I saw some ppl do use trw rotor. And I been asking their feedback. Brembo can't afford la bro. The price anytime might be more expensive than my car.i mean for Ori brembo . Actually no, brembo is also oem for small/economy cars. You may be surprised the price not too far off compared to toher brands. Can take alook at shopee/lazada and see the price range. Previously i used trw rotor + trw dtec ceramic pad, good brake feel and low dust. Price was was quite reasonable.
TSPlatinum Sand
May 23 2022, 07:23 PM
QUOTE(kdr93 @ May 23 2022, 05:54 PM) Actually no, brembo is also oem for small/economy cars. You may be surprised the price not too far off compared to toher brands. Can take alook at shopee/lazada and see the price range. Previously i used trw rotor + trw dtec ceramic pad, good brake feel and low dust. Price was was quite reasonable. Yes. I also got search at shopee.. mostly trw, questa ,borch , Daihatsu. And yah brembo rotor is below rm100. Btw how many years ur trw last?
kdr93
May 23 2022, 07:46 PM
QUOTE(Platinum Sand @ May 23 2022, 07:23 PM) Yes. I also got search at shopee.. mostly trw, questa ,borch , Daihatsu. And yah brembo rotor is below rm100. Btw how many years ur trw last? Installed 3 years ago, disc still looks good, but this past years did not drive much.
LA773
May 24 2022, 02:13 AM
QUOTE(kdr93 @ May 23 2022, 07:46 PM) Installed 3 years ago, disc still looks good, but this past years did not drive much. Trw rotor, middlepart got rust after sometime? Mine changed to brembo RM150 per pair, VERY easy get rust Think its low end product.. Fkk
kdr93
May 24 2022, 09:11 AM
Not really, got some surface rust, by can wipe off.
I also park my car indoors.
Last time even my original discs had rusted when park outside 2or 3 days.
But i do thnk the brembo sold is not the same highend discs used in expensive cars. This maybe a more budget option.
jycy98
May 24 2022, 09:46 AM
Bendix metal king good or not? Heard that it produce lots of brake dust. Is RM120 fair price for this brake pad?
Donidoni
May 24 2022, 09:56 AM
QUOTE(Platinum Sand @ May 21 2022, 12:22 PM) I have use this TF brand ,rotor with holes. Been using for 2-3 years d. But somehow feels like the rotor cepat nipis. Pad change only 1 time . I realized the rotor itself is much thinner than Ori myvi rotor. Now thinking to change new rotor,what brand is recommended? I saw alot online but still not sure which brand is more lasting. And 1 more thing happen, after change to TF rotor. I never had abs effect. Ever I emergency brake also no abs function. Weird Just use back the original Perodua rotor and brake pads. The price for original parts for perodua cars are quite reasonable and not much difference compared to OEM. But be careful of workshops selling 'fake' original.
matrix88
May 24 2022, 10:01 AM
QUOTE(kdr93 @ May 24 2022, 09:11 AM) Not really, got some surface rust, by can wipe off. I also park my car indoors. Last time even my original discs had rusted when park outside 2or 3 days. But i do thnk the brembo sold is not the same highend discs used in expensive cars. This maybe a more budget option. surface rust on brake disk is normal. wow. you go and wipe it off? means you have to remove the rim to do so??? surface rust if you drive and step on the brakes, it will be cleared in seconds.
TSPlatinum Sand
May 24 2022, 10:06 AM
QUOTE(Donidoni @ May 24 2022, 09:56 AM) Just use back the original Perodua rotor and brake pads. The price for original parts for perodua cars are quite reasonable and not much difference compared to OEM. But be careful of workshops selling 'fake' original. I been using rotor with holes. Honestly the braking is more effective compare to original rotor. But not tahan, after few years I can see the rotor become more nipis, the hole and there's some line can see the difference. Since I'm 70percent drive highway .just looking for more lasting rotor.
MrBaba
May 24 2022, 10:13 AM
QUOTE(Platinum Sand @ May 22 2022, 12:36 PM) Abs got. Myvi lagi best bro. Ori rotor use about 8-9 years d. Reason change Ori rotor is the rotor makan d,. Can skim but I decided change. Every time brake sure got sharp sound tats y I change to rotor with holes. New rotor seem to be lot thinner compare to Ori. Then since tat I never experienced my abs bro . Is it rotor issue or pad issue ? I recently change a cheap pad then every time press je got sound one zzz before don't have this issue one. Car like 4 yr old je
TSPlatinum Sand
May 24 2022, 10:27 AM
QUOTE(MrBaba @ May 24 2022, 10:13 AM) Is it rotor issue or pad issue ? I recently change a cheap pad then every time press je got sound one zzz before don't have this issue one. Car like 4 yr old je Suspect pad issue bro. Cheap pad makan rotor . Sound very sharp like metal to metal friction.
MrBaba
May 24 2022, 10:59 AM
QUOTE(Platinum Sand @ May 24 2022, 10:27 AM) Suspect pad issue bro. Cheap pad makan rotor . Sound very sharp like metal to metal friction. Yes that sound chilaka guess need change it soon. Mine some time u can hear the friction sound , some time sharp sound ...
