Outline ·
[ Standard ] ·
Linear+
Some questions about table...
TSZeneticX
Nov 24 2021, 12:13 PM, updated 6 months ago
I'm looking to get a new table soon for my home office setup, but I not sure what size to get and whether the size I have in mind is appropriate
The table must be able to hold 2x 17 inch laptops, and at least a 21inch monitor (2 if possible) with some space to spare without feeling crowded. Is 180 x 80 enough?
This post has been edited by ZeneticX: Nov 24 2021, 12:13 PM
Skylinestar
Nov 24 2021, 02:44 PM
2 monitors at the side or behind the laptops?
TSZeneticX
Nov 24 2021, 03:09 PM
QUOTE(Skylinestar @ Nov 24 2021, 02:44 PM) 2 monitors at the side or behind the laptops? Side by side preferably without the use of monitor arms but if no choice then I'll consider monitor arms
Muusyc
Nov 24 2021, 03:47 PM
It's always good to go Ikea and get some ideas there.
ngks
Nov 24 2021, 06:27 PM
When buying online, make sure not to deceived by the sample photo, they have been alter to make it looks big and good. I almost fall for it when I bought a table last time, always look at the comments section. Always look at their actual size at their specification. Advertised photo vs actual This post has been edited by ngks: Nov 24 2021, 06:30 PM
TSZeneticX
Nov 24 2021, 07:24 PM
QUOTE(ngks @ Nov 24 2021, 06:27 PM) When buying online, make sure not to deceived by the sample photo, they have been alter to make it looks big and good. I almost fall for it when I bought a table last time, always look at the comments section. Always look at their actual size at their specification. Advertised photo vs actual  Wtf that's basically false advertising unless its stated explicitly the real product is not as shown in image But no worries for me, I'm actually more concerned with the size now rather than the actual design itself This post has been edited by ZeneticX: Nov 24 2021, 07:25 PM
kee71
Nov 25 2021, 06:50 PM
QUOTE(ZeneticX @ Nov 24 2021, 03:09 PM) Side by side preferably without the use of monitor arms but if no choice then I'll consider monitor arms imagine you need to move from the first screen to the last screen within 1800 mm length table dual monitor arm is better to put the big monitor. cz can adjust height, angle and position normal office table for staff around 1200-1500 length x 600-750 depth (mm)
TSZeneticX
Nov 25 2021, 07:21 PM
QUOTE(kee71 @ Nov 25 2021, 06:50 PM) imagine you need to move from the first screen to the last screen within 1800 mm length tableĀ dual monitor arm is better to put the big monitor. cz can adjust height, angle and position normal office table for staff around 1200-1500 length x 600-750 depth (mm) If both monitor at the middle i dont think should be a problem But now I not sure if there's enough space to fit my 2 17 inch laptops, that's the priority now. Monitor just 1 will do but if possible would prefer 2 Ideal setup is monitor(s) at the middle, laptop at the sides This post has been edited by ZeneticX: Nov 25 2021, 07:21 PM
kee71
Nov 25 2021, 07:37 PM
QUOTE(ZeneticX @ Nov 25 2021, 07:21 PM) If both monitor at the middle i dont think should be a problem But now I not sure if there's enough space to fit my 2 17 inch laptops, that's the priority now. Monitor just 1 will do but if possible would prefer 2 Ideal setup is monitor(s) at the middle, laptop at the sides 1800mm maybe ngam ngam for 4 , side by side. depends on the actual dimension. to be safe add another 100 or 200 mm or consider L shaped table for user friendly purpose to look at 4 screens at one time shud be 2 big monitors on top of the laptops, then the table 1200 / 1500 will do, cz big monitor doesnt eat much of your table space. just one pipe only
TSZeneticX
Nov 25 2021, 08:02 PM
QUOTE(kee71 @ Nov 25 2021, 07:37 PM) 1800mm maybe ngam ngam for 4 , side by side. depends on the actual dimension. to be safe add another 100 or 200 mm or consider L shaped table for user friendly purpose to look at 4 screens at one time shud be 2 big monitors on top of the laptops, then the table 1200 / 1500 will do, cz big monitor doesnt eat much of your table space. just one pipe only L shape table nice but need to plan nicely to fit into the space which i dont think is suitable for my current room. So my plan is get a normal big size table for now Will drop by ikea to check out some tables of size 180cm x 80cm soon
