QUOTE(Phyarc @ Jul 25 2021, 02:32 PM)
local market for double glazing is very expensive.
I know some friends who recently completed house renovation, using china supplier found from alibaba website.
Said to be "a lot cheaper" even with shipping.
However you need to factor in local installation cost.
So far feedback was that "it helped with sound insulation for swing doors but not sliding door". Which may be detailing issue or due to gap. Delivery can be done either by supplier or buyer. You can even do door to door service. Or if you have contact to handle freight forwarder side then only pay shipment to warehouse. Any question, the supplier can help answer. If you need contact just PM me.
Thanks in advance. Let me do some survey 1st.
QUOTE(mini orchard @ Jul 25 2021, 03:33 PM)
Start planning your move.
Meanwhile have cancelling noise inside your unit to distract your ears focus..... a water fountain or non stop background radio or music.
I think it still costs me cheaper to upgrade the window panels than to make my move, as I yet to find out which is the 'nice' place to stay. Would appreciate if you could recommend me a condo unit which fulfil my criteria such as within 15km to KL&PJ, 'low' density (not more than 10units / floor or 350units in the development), 'quiet' environment, unit at least 1000sf, preferably freehold but not necessarily & could be currently procured with less than RM400/sf 😅. FYI, all I have listed were the criteria that had been fulfilled back in 10 years ago when I bought the unit for own stay. The 'quiet' doesn't need to be no sound at all, dogs barking, ad hoc strong exhaust bike sound from motorcycle, sound of people quarelling from the neighborhood, thunder like firecrackers sound during count downs are all acceptable, but not the constant 'shhh shhh shaa shaaa'
QUOTE(jack2 @ Jul 25 2021, 03:34 PM)
Why you bought/stay there at the first place? Complain to Majlis...
change your windows... very expensive.. small windows cost about RM5000. I asked before and the result is good.. 60% at least.
If you could predict what will happen in the future I will salute you. If I had the choice, I'd move, pls recommend a location that fulfills all of the criteria listed above.
QUOTE(ceo684 @ Jul 25 2021, 04:30 PM)
For road noise, my boss had a unit next to busy road w double glazed windows and when closed I cannot hear the traffic noise. It was on Jalan Tun Razak.
Good to hear from you. I'll find out further on the double glazed glass.
