 [WTA] monitor for designing
TSmoiskyrie
post Aug 21 2020, 08:43 PM, updated 6y ago
Plan to find monitor that
100 srgb
IPs
Bright enough
24~27 inch
Colour accuracy
If can cheap la....
Malaysia either online or retail...
Sarawak...
Thanks
chocobo7779
post Aug 22 2020, 10:18 AM
Power is nothing without control
QUOTE(moiskyrie @ Aug 21 2020, 08:43 PM)
100 srgb
IPs
Bright enough
24~27 inch
Colour accuracy
If can cheap la....
Sarawak...
Thanks
Monitors with good color accuracy? Prepare to spend at least >RM10K for those professional grade Eizo stuff sweat.gif
https://www.rtings.com/monitor/reviews/best...-graphic-design
Also, if you are doing color critical work... buy yourself a color calibrator or find a monitor calibration service to calibrate your monitor - no point buying a decent monitor only to found out that it is poorly calibrated from the get go icon_idea.gif
This post has been edited by chocobo7779: Aug 22 2020, 10:29 AM
TSmoiskyrie
post Aug 22 2020, 10:24 AM
QUOTE(chocobo7779 @ Aug 22 2020, 10:18 AM)
Those Eizo monitor really that expensive ?
My office got 1, 27 inch I think,
Supply by printer company...
If take away colour accuracy?
Maybe not that bad one,...got?
chocobo7779
post Aug 22 2020, 10:32 AM
QUOTE(moiskyrie @ Aug 22 2020, 10:24 AM)
Depending on the models, there are some monitors (especially those HDR capable ones) that can even reach the RM20K+ mark sweat.gif
Might want to look at Dell Ultrasharps as they are often quite well calibrated from the factory icon_idea.gif
Also, do prepare some extra budget for a color calibrator or a monitor calibration service as well icon_idea.gif
You might also want to add BenQ SW/Viewsonic VP monitors into your list too icon_idea.gif
This post has been edited by chocobo7779: Aug 22 2020, 10:37 AM
TSmoiskyrie
post Aug 22 2020, 11:07 AM
Never know those type of monitor can cost so much
Thought almost only cost less that 10k...
Any brand also can as long local can get....
Last time survey viewsonic, 24 inch 400++...
Fhd enough?
chocobo7779
post Aug 22 2020, 11:14 AM
duplicate post
This post has been edited by chocobo7779: Aug 22 2020, 11:22 AM
chocobo7779
post Aug 22 2020, 11:22 AM
QUOTE(moiskyrie @ Aug 22 2020, 11:07 AM)
Fhd enough?
Personally I'd go with this:
https://www.lazada.com.my/products/benq-pd2...9011VLMoMG&mp=1
Pricey, but it's a 1440p panel and has a full sRGB gamut coverage (you might want to find someone with a color calibrator to calibrate the display) icon_idea.gif
IMHO, those cheap IPS monitors are not really worth it when it comes to color critical work - maybe fine if you are a hobbyist or so tongue.gif
If you prefer 16:10, this one will also do:
https://www.dell.com/en-my/work/shop/dell-2...chspecs_section (99% SRGB)
lolzcalvin
post Aug 22 2020, 05:59 PM
shibe in predicament
Asus ProArt PA27AC if you have the money for it. 100% sRGB, can use different gamma curve so 100% rec 709 as well. dE < 2 (most likely dE2000), supports hw calibration (means modifying monitor's color profile directly).
TSmoiskyrie
post Aug 22 2020, 07:00 PM
No money for those pro monitor...
Just thinking maybe got cheap monitor that can reproduce colour as close as possible....
As sometime customer want printing using laser printing but want colour follow 100% same as those offset/Pantone printer....
I tell my boss impossible, it they still promise customer can get 100% same colour...
Currently only rely on my thinkpad notebook which just have 88% srgb...
Srgb or adobe rgb more accurate for colour?
hiei1120 P
post Aug 23 2020, 11:05 AM
Probation
ACER-XV240YP
I suggest this 1 , now hot selling though with sRGB 99%
RM699
if have interested PM me
https://pictr.com/images/2020/08/23/7lEVtn.md.jpg
cmgan72
post Aug 27 2020, 06:10 PM
Daisyoix PC
i would recommend u this
Acer Nitro XV270P
Model : ACER NITRO XV270P
Panel : IPS Panel
Resolution : 1920 x 1080 (FHD)
Refresh Rate :165Hz oc (144hz)
G-sync compatible : Yes
Contrast : 100mil:1 (ACM)
Refresh Rate : 2msGtG (0.1ms min)
Colour Gamut : 98% sRGB
Brightness : 250nits (HDR 10)
Input : HDMI 2.0 x2 DP 1.2 x1 Audio out
Height Adjust : HEIGHT SWIVEL PIVOT
Speaker: Yes (2w)
RM879
TSmoiskyrie
post Aug 27 2020, 06:41 PM
QUOTE(cmgan72 @ Aug 27 2020, 06:10 PM)
Acer Nitro XV270P
Panel : IPS Panel
Speaker: Yes (2w)
RM879
got no speaker?
cos more prefer use headfone...
cos sometime watch blue cant let people know...
plus i dont like noise...
stevendeepdeep
post Sep 10 2020, 09:02 PM
QUOTE(moiskyrie @ Aug 27 2020, 06:41 PM)
got no speaker?
hahhaah big screen only syok bro.
TSmoiskyrie
post Sep 10 2020, 09:11 PM
currently 21.5 inch..
plan 24 inch but maybe will get 27 inch if new house got enough space...
if 30+ inch almost same price can consider also....
0.0241sec    0.75    5 queries    GZIP Disabled
Time is now: 21st December 2025 - 03:17 AM
