*READY STOCK, first come first serve while stock last*
-Compact action camera with 1/2.3" CMOS sensor and wide f/2.8 lens that records up to 4K60p video and 12MP photos
-Capture up to 12MP raw and JPEG photos; record up to 4K60p or 1080p240 H.264 MOV or MP4 video at up to 100 Mb/s; supports slow-motion, hyperlapse, and time-lapse modes
-Crisp 2.25" touchscreen display on back with 640 x 360 resolution; additional 320 x 320 resolution display on front
-Electronic Image Stabilization (EIS) technology for stabilizing footage in standard record modes with 18-22% crop factor; EIS enabled all video modes except in slow-motion, hyperlapse, or time-lapse mode
-Slow-motion mode records up to 240 fps; maximum ISO is 3200
-Supports High Dynamic Range (HDR) video recording in 4K30p
-Lock screen function to prevent accidental touchscreen presses
-Dual microphones with noise reduction technology and dual speakers; can input audio with an external microphone using the USB Type-C input
-Durable enough to withstand drops from 5' and can be submerged down to 36' in water without a case for up to 30 minutes
-145° angle of view; narrow and dewarp field-of-view options
-Charge to 70% in 30 minutes with a separately available fast-charging adapter
-Records to microSD/SDXC/SDHC cards, UHS-I compatible cards with 30 MB/s write speed or higher recommended
-Connect with the Mimo app on iOS or Android smartphones using Bluetooth or Wi-Fi
Package Includes:
1x Osmo Action
1x Camera frame
1x Battery
1x Battery case
1x USB Type-C cable
1x Quick release base
1x Flat adhesive mount
1x Curved adhesive mount
1x Locking screw
FREE 1x Selfie Pole; 1x Extra gifts (while stock last only)
1 Year Osmo Malaysia warranty
For more info: https://www.dji.com/osmo-action?from=store-product-page
#osmo #actioncamera #osmoaction #dji #djiosmo #djiaction
Price: RM1577
Warranty:1 yr
Dealing method:POSTAGE
Contact method/details:pm
Item(s) conditions:new
This post has been edited by BlackG: Jun 9 2019, 01:58 PM
Jun 9 2019, 01:50 PM, updated 5y ago
Quote
0.0135sec
0.38
5 queries
GZIP Disabled
