 install reverse dashcam for perodua bezza, will it void warranty
TSokr2013
post Feb 24 2019, 06:15 PM, updated 7y ago
any accessory shop can recommend cheap n good pricing
dylan_chng
post Feb 24 2019, 06:18 PM
which state?
JoinedFeb2019
install urself
TSokr2013
post Feb 24 2019, 06:55 PM
QUOTE(dylan_chng @ Feb 24 2019, 06:18 PM)
which state?
im in kl.
i watched youtube.. looks easy tho. but it require to peel the back break cable . does this void warranty? some say add an extra socket but how ?
silrave
post Feb 24 2019, 10:23 PM
i also finding
any accessories shop got do help install service
how much will they charge ?
Ciypher
post Feb 24 2019, 10:33 PM
Done that before on my Premium X. The main point to look out for is the location for the camera wire to go inside the boot. My installer route the wire through the license plate light causing one of the clip to broke off and not getting a good seal.
Thus I reroute the wire myself through the Perodua Logo "White Colour Insert" by drilling it through. This method require the removal of the rear Chrome garnish and only applicable for camera with the small 4/5 pin connector.
SUSchrisseow
post Feb 24 2019, 10:47 PM
buy from lazada, and warranty don't void.
fireballs
post Feb 25 2019, 02:25 AM
10101
you will have to cut the wire for reverse sensing. unless u diy without cutting the cable. those abeng shops will just splice cable to install. possibly void warranty.
0.0168sec    0.26    5 queries    GZIP Disabled
Time is now: 15th December 2025 - 10:48 PM
