 How to choose the right water pump?, Help and advise needed!
TSAfterburner1.0
post Nov 9 2018, 03:40 PM, updated 8y ago
House type: DS link house
Years old: 10 to 14 yrs
Occupants: 2 Pax
Toilet: 4
Q:
1. Which water pump to choose if i want to boost up my water pressure and have nice strong shower?
2. Which brand offers sufficient warranty? pls share your testimony if any....
3. Water pump is to be installed next to the water tank rite up in the roof? why i see some ppl ask if the water pump can be place infront of the house?
4. Which horse power or ww is sufficient for DS link house?
5. Any installer contact to share?
Thank you in advance....
makky
post Nov 9 2018, 03:46 PM
Hitachi 1hp.... dont buy 0.5 or 0.75 hp ....
SUS2feidei
post Nov 9 2018, 03:47 PM
Ayam tatau, ayam virgin (c)
this one
Iceman74
post Nov 9 2018, 03:52 PM
If you want to install water pump, make sure your piping is all ok or replace with new one to withstand the pressure. If not, later bocor everywhere also cannot see, leaving watermark all over the place.
you can direct lay new water pipe to your bathroom just for showering with the rest untouched since you are DS.
Q:
me chose GRUNDFOS. Model no you can ask those seller introduce
GRUNDFOS so far ok, more than 2 years now
Me install next to my water tank. Nobody will installed next to water meter(me forgot why and i think can get in trouble with syabas) I believe it is wrong way to do it and create low pressure for other house when you using it.
normally depending how many bathroom/water tap need
My installer from kepong. U can search those qualify dealer around your place first
This post has been edited by Iceman74: Nov 9 2018, 03:59 PM
idoblu
post Nov 9 2018, 03:54 PM
stars for sale
Your house over 10 years old sked paip bocor if suddenly got higher pressure
spicy.jalapeno
post Nov 9 2018, 03:58 PM
1. Depends on piping condition, distance from pump to outlet, elevation etc.
2. What the hell is sufficient warranty?
3. Your pump can be placed anywhere, but the question is how are you going to run the piping? Our water regulation allows you to tap directly to the kitchen sink only, all other outlets shall be served by the water tank.
4. See 1.
5. No comment.
TSAfterburner1.0
post Nov 9 2018, 04:06 PM
QUOTE(Iceman74 @ Nov 9 2018, 03:52 PM)
Q:
Thanks bro.... im stuck with Tsunami brand or Hitachi, one offer 2 yrs and the other 5 yrs... TSunami brand RM749, Hitachi RM500 +
Cereal
post Nov 9 2018, 04:07 PM
Q:
the reason you should not install a pump at the water meter is because it will cause cavitation at the pump suction. cavitation will prematurely wear out the pump impeller.
ycs
post Nov 9 2018, 04:09 PM
MEMBER
my grundfos 10 yrs old
SUSmemekfalui
Got place to put big water tank ?
MR_alien
post Nov 9 2018, 04:19 PM
Mr.Alien on the loss
as of today, any china brand also can already
mushigen
post Nov 9 2018, 04:22 PM
QUOTE(Cereal @ Nov 9 2018, 04:07 PM)
Cavitation will also damage pump casing as it's one of the main enemies of centrifugal pumps.
TSAfterburner1.0
post Nov 9 2018, 04:33 PM
thats for the insights bro..... apparently some ppl use pump when they r staying in flats i.e 4th floor to increase the water pressure.... so i was a bit confuse how does this pump work....
tahfeikei
post Nov 9 2018, 04:37 PM
TALK TO MY ENGRISH
QUOTE(Afterburner1.0 @ Nov 9 2018, 03:40 PM)
Occupants: 2 Pax
Toilet: 4
Q:
i used 2 different water pumps before.
sorry i cant recall the brands...some british one. first one, had pipes bursting. it seems pressure too high. changed a second one with lower pressure. again pipes bursting.
now totally no more water pumps. less headaches.
Erza Scarlet
post Nov 9 2018, 04:41 PM
Q:
For the no 3, thats not the reason. The real reason is the pump will be damaged if you run it dry. Hence you can see some of these when choosing pump brand "dry run protection". So the pump suction should be installed in airtight connection. Which mean it need to pump by sucking the water from abundant source.
If you directly installed it from water meter, lets say the syabas source is kinda slow and your pump need more than it could supply, the pump will be running dry. The component inside the pump such as mechanical seal will be damaged and this gonna cause leak.
As for where to install it you need to check the pump manual. It will show you the maximum length of the suction from the ground level. Thats if you wanted to install it on the 2nd floor. Same with discharge, there is a maximum range. Just in case, make sure you tell your installer to do the bypass valve in your piping system. Lets say if you temporarily have no electricity, you can bypass the system, low pressure water, but hey at least you can use it.
ihm11
post Nov 9 2018, 04:42 PM
rmb put 1-way valve on the bypass
Iceman74
QUOTE(Afterburner1.0 @ Nov 9 2018, 04:06 PM)
Last time me also thinking cheaper brand but heard spare parts and servicing them got problem later on when they no longer in production.
Me also heard those brand after many years usage the pressure not so great anymore, may need to services more often.
Btw my pump placement is elevated and got shelter from rain and sunlight but is open space although the supplier said can withstand it
As u know, the pump need to switch on/off multiple times, that why me only do piping to my rain shower on both bathroom and my washing machine only. Washing basin and others tap connection to my old piping.
ayamback
post Jan 4 2019, 11:08 AM
Which one did u go for in the end?
Top[X]meN
post Mar 25 2019, 06:40 AM
No point also if you have a good pump for water tank, but water supply from main meter very slow.
Gon Freaks
post Mar 25 2019, 06:42 AM
i am using 2 water pump for my house.
5 bath room. 2 tanks.
0.5hp joven.
2 Pages  1 2 >Top
0.0172sec    0.49    5 queries    GZIP Disabled
Time is now: 15th December 2025 - 04:40 AM
