 Atos Fuel Consumption
TSxain
post Apr 13 2018, 10:45 AM, updated 8y ago
Hi,
Recently i bought a 2nd hand atos. I thought the fuel consumption is saving.. I did a recond change of the gear box right after i bought it since there was a slight problem when it shift between gears. the guy who change it did tell me it will save much more after the change. but its like the same.
turns out like 1 full tank around RM70 can go around 250km only. rclxub.gif rclxub.gif
whats the normal fuel consumption for this car?
its the 2008 Hyundai Atos 1.0 GLM auto.
lsm1991
post Apr 13 2018, 12:16 PM
not a known fuel efficient car...
you can try look it up on fuelly.
alphaz
post Apr 13 2018, 12:36 PM
that's terrible like not even 8km/l, although about similar fc to satria neo 1.3
BelaCHAN
post Apr 13 2018, 12:42 PM
Thats very bad fuel FC.
A LOT of things contribute to fuel econ, but engine is most important.
I think your engine condition is bad dy.
May require overhaul (hence 2nd hand...)
TS Got a lemon unit.
e-fatty
post Apr 13 2018, 12:46 PM
For your ref, my 2011 fiesta does 450km for that amount. That's conservative calculation. It would probably be 350km in all city driving
loutze
post Apr 13 2018, 04:30 PM
Had an Inokom Atos once, new car manual can easily get 350~400KM
0.0140sec    1.44    5 queries    GZIP Disabled
Time is now: 17th December 2025 - 03:32 PM
