 Spigen Screen Protector
TSryder_78
post Jan 18 2018, 08:45 AM, updated 8y ago
For those who bought the Spigen Screen Protector, how do you find its worth or performance? I've just got the Spigen for the LG V20 and found the screen protector to be slightly smaller in size than the original plastic protective sheet that came together with the phone. For this reason the Spigen sheet does not cover up to the edges of the phone, and in my case especially the top and bottom of the phone whereby there is quite a lot of area not covered by the Spigen screen protector.
Other than this slightly issue, the quality seems good. There is little difference in terms of clarity although I thought it's slightly clearer with the Spigen. The only main advantage of the Spigen I can think of is the higher durability and stronger surface of the sheet when compared to the original plastic protective sheet that came with the phone, thus making the screen more scratch-proof.
By the way, does anyone know what is the purpose of the Dust Removal Sticker? How do we use this? There doesn't seem to be any instructions that mention on the usage of this Dust Removal Sticker.
jimmybcmy
post Jan 18 2018, 09:11 AM
that sticker is used for remove the fine dust sticky dust on your screen before you put on the protector.
Just paste the sticker on the screen and then pull it off, the dust will stick on the sticker and your screen is clean.
TSryder_78
post Jan 18 2018, 09:55 AM
QUOTE(jimmybcmy @ Jan 18 2018, 09:11 AM)
Thanks for the response. I used the Zeiss lens wipe for that purpose before I installed the screen protector to the phone. The instructions mentioned about using this lens wipe before installing the screen protector but didn't mention anything on the Dust Removal sticker.
jimmybcmy
post Jan 18 2018, 10:10 AM
QUOTE(ryder_78 @ Jan 18 2018, 09:55 AM)
Use the sticker when there is very fine sticky dust or oily finger print marks etc. that hard to be removed with lens wipe. If you see the screen surface perfectly clean after used the lens wipe, then no need to use the sticker. But take note that those very fine dust are very hard to see.
This post has been edited by jimmybcmy: Jan 18 2018, 10:12 AM
TSryder_78
post Jan 18 2018, 11:07 AM
Yes, that's true. After using the lens wipe, there might be still fine dust sticking onto the partially wet screen. And perhaps this is where the Dust Removal sticker will come in handy. Though I didn't notice any dust sticking onto the screen after I was finished with the lens wipe. Perhaps next time.
0.0158sec    0.60    5 queries    GZIP Disabled
Time is now: 23rd December 2025 - 03:42 AM
