Outline ·
[ Standard ] ·
Linear+
Reverse Camera but image flipped, Reverse camera but image flipped
TSnewsreadr7
Aug 12 2017, 09:22 PM, updated 7y ago
Hi Sifus, Hope my entry is in the correct 'room', otherwise please kindly relocate it. I just bought a very cheap reverse cam and a 4" LCD from an online store for my car. When both the items arrived I sent them to a car accessories shop to get them installed. When all is done n i was at home I noticed that the image display is inverted - subject on the right appears on the left side of the LCD screen (??? is my description correct?), unlike images on the mirror. Totally confusing. Was told by the techy guy i hired that the cam/lcd screen r powered by reverse lamp. There's only 3 buttons behind the lcd screen - brightness, contrast and picture. now can no longer view the switches at the rear of the display. Seeking everyone's advice here on how to correct this please. I understand, some cheap things produce cheap results Please help. Thanks
magnesium
Aug 12 2017, 09:34 PM
i install myself reverse camera and lcd on my lorry
maybe problem with camera installation eg upside down
maybe you upload a picture for clearer answer from others
TSnewsreadr7
Aug 12 2017, 09:53 PM
A lamp post which is on the left side of the road, appears on the right side in the screen. Image not upside down.
If using a mirror, the lamp post still appear on the left of the mirror.
This post has been edited by newsreadr7: Aug 12 2017, 09:55 PM
makky
Aug 12 2017, 09:59 PM
Flip the camera around can't?
lsm1991
Aug 12 2017, 10:28 PM
ts.... basically your camera isnt mirror-ing/flipping the image?? usually thats a feature built into the camera itself.... some headunits (if thats what you are using to display the image) have that option... QUOTE(makky @ Aug 12 2017, 09:59 PM) Flip the camera around can't? topkek...
therain01
Aug 12 2017, 11:53 PM
QUOTE(newsreadr7 @ Aug 12 2017, 09:22 PM) Hi Sifus, Hope my entry is in the correct 'room', otherwise please kindly relocate it. I just bought a very cheap reverse cam and a 4" LCD from an online store for my car. When both the items arrived I sent them to a car accessories shop to get them installed. When all is done n i was at home I noticed that the image display is inverted - subject on the right appears on the left side of the LCD screen (??? is my description correct?), unlike images on the mirror. Totally confusing. Was told by the techy guy i hired that the cam/lcd screen r powered by reverse lamp. There's only 3 buttons behind the lcd screen - brightness, contrast and picture. now can no longer view the switches at the rear of the display. Seeking everyone's advice here on how to correct this please. I understand, some cheap things produce cheap results Please help. Thanks I think you need to dig harder on the lcd screen. Check with the seller where to disable flip image.
Richard
Aug 12 2017, 11:57 PM
If its a rear view camera then the it would be mirror image same as how a rear view mirror..
You need to mount the camera pointed behind the vehicle ..
This post has been edited by Richard: Aug 12 2017, 11:59 PM
Vervain
Aug 13 2017, 09:33 AM
TS. Image is not flipped. either you got a front camera or you HU didn't flip it.
TSnewsreadr7
Aug 20 2017, 07:18 PM
Fixed already. Learned that there's a white looping wire close to the cam jacks. Was told to cut it off to correct the flipped image. Now, awesome result! Kudos to all advises here.
matrix88
Aug 20 2017, 07:29 PM
1 ) either your headunit have the function to flip 2 ) there is one wire from the camera (some do), that when you cut this wire, the image is flipped. check yours
SUSwaiora_protuner
Aug 20 2017, 07:34 PM
QUOTE(magnesium @ Aug 12 2017, 09:34 PM) i install myself reverse camera and lcd on my lorry maybe problem with camera installation eg upside down maybe you upload a picture for clearer answer from others QUOTE(makky @ Aug 12 2017, 09:59 PM) Flip the camera around can't? QUOTE(Richard @ Aug 12 2017, 11:57 PM) If its a rear view camera then the it would be mirror image same as how a rear view mirror.. You need to mount the camera pointed behind the vehicle .. LOL im collecting automotive expert /k answers...lol
TSnewsreadr7
Aug 20 2017, 08:36 PM
QUOTE(matrix88 @ Aug 20 2017, 07:29 PM) 1 ) either your headunit have the function to flip 2 ) there is one wire from the camera (some do), that when you cut this wire, the image is flipped. check yours corrected already This post has been edited by newsreadr7: Aug 20 2017, 08:38 PM Attached thumbnail(s)
