Outline ·
[ Standard ] ·
Linear+
Honda city 2017 new facelift push start problem, Cannot start engine
TSoks911
Jun 10 2017, 08:03 PM, updated 9y ago
My Honda city not able to start the engine since this morning . Even push start few times also the same. The dashboard indicators showing two icon lights up as show in picture . Anyone know what's happening ? Tq New Update 11/6/17: just got it fixed by changing new battery. The previous battery was in low voltage. Only 2 months old already like that . The original battery named FB. Honda should pay more attention on QC This post has been edited by oks911: Jun 12 2017, 03:47 PM Attached thumbnail(s)
Ginny88
Jun 10 2017, 08:09 PM
Honda quality getting worse and worse.
Clingxcling
Jun 10 2017, 08:13 PM
have u check the battery ? see loose or not and also check your gear nob, is it on P before u start
This post has been edited by Clingxcling: Jun 10 2017, 08:14 PM
boxer07
Jun 10 2017, 08:16 PM
go back sc and claim warranty . ntg much u can do
based on ur photo,it is not push start issue. should be ur car battery problem ..
drive to Setia Alam Honda if ur are in Selangor. press for few more time and u should be able to start it
This post has been edited by boxer07: Jun 10 2017, 08:18 PM
motherker
Jun 10 2017, 08:29 PM
Bro Press the brake hard n push the button
TSoks911
Jun 10 2017, 09:50 PM
QUOTE(boxer07 @ Jun 10 2017, 08:16 PM) go back sc and claim warranty . ntg much u can do based on ur photo,it is not push start issue. should be ur car battery problem .. drive to Setia Alam Honda if ur are in Selangor. press for few more time and u should be able to start it Ya u are right .. engine started after I tried push start several times . Will go Honda SC tomorrow. Not sure tomorrow Sunday they willing to serve me or not . I planning to go Glenmarie .
TSoks911
Jun 10 2017, 09:51 PM
QUOTE(motherker @ Jun 10 2017, 08:29 PM) Bro Press the brake hard n push the button Ya I thought that too. But no matter how hard I tried also cannot start . Sien
TSoks911
Jun 10 2017, 09:53 PM
QUOTE(Clingxcling @ Jun 10 2017, 08:13 PM) have u check the battery ? see loose or not and also check your gear nob, is it on P before u start I not sure whether it's battery issue or not. Ya I put P also cannot start .. strange ... only 2 months car . Bad luck
boxer07
QUOTE(oks911 @ Jun 10 2017, 09:50 PM) Ya u are right .. engine started after I tried push start several times . Will go Honda SC tomorrow. Not sure tomorrow Sunday they willing to serve me or not . I planning to go Glenmarie . it is depend on how u describe the issue to them .I changed my car battery on Saturday when the issue arise ,and they do not believe it is due to starter issue . the same problem on Sunday and they processed the warranty claim for starter...need to wait for 1week for that part . mine at setia alam Honda This post has been edited by boxer07: Jun 10 2017, 09:53 PM
TSoks911
Jun 10 2017, 09:55 PM
QUOTE(boxer07 @ Jun 10 2017, 09:53 PM) it is depend on how u describe the issue to them .I changed my car battery on Saturday when the issue arise ,and they do not believe it is due to starter issue . the same problem on Sunday and they processed the warranty claim for starter...need to wait for 1week for that part . mine at setia alam Honda So the culprit is starter ?? Are You having similar issue as mine?
boxer07
Jun 10 2017, 09:56 PM
QUOTE(oks911 @ Jun 10 2017, 09:55 PM) So the culprit is starter ?? Are You having similar issue as mine? most probably urs starter issue ... unless u always short distance trip ...
TSoks911
Jun 10 2017, 10:37 PM
QUOTE(boxer07 @ Jun 10 2017, 09:56 PM) most probably urs starter issue ... unless u always short distance trip ... Ok noted. Thanks for ur feedback
TSoks911
Jun 11 2017, 01:57 PM
Update: just got it fixed by changing new battery. The previous battery is low voltage. Only 2 months old already like that .
prasys
Jun 11 2017, 02:27 PM
Heros Never Die
I highly recommend you toget a OCB2 adapter for your car. It helps you to troubleshoot such problems
I learned that from my Fiesta when it gave me all sorts of weird indicator that it's not working. Upon plugging in my OCB2 adapter and connected it to my phone .The battery was at 9V
TSoks911
Jun 11 2017, 04:58 PM
QUOTE(prasys @ Jun 11 2017, 02:27 PM) I highly recommend you toget a OCB2 adapter for your car. It helps you to troubleshoot such problems I learned that from my Fiesta when it gave me all sorts of weird indicator that it's not working. Upon plugging in my OCB2 adapter and connected it to my phone .The battery was at 9V May I know how much and where to purchase that adaptor?
ZOOL COOL
Jun 12 2017, 03:37 AM
my mil honda city battery also died after 2 or 3 months butying just recently. Read in facebook also some of my friends having the same battery issue. we need to escalate this issue to honda. seems systemic
yhsiau
Jun 12 2017, 08:54 PM
Looks like the battery power is weak... Button start type ignition won't allow to crank the engine if the battery power is weak/low. Unlike the key pushing ignition type(mechinical type), U can still attempt to crank even the battery power is weak/low.
BTW, the Honda is farking stingy(should I say shitty cost down)... only 1 ground/earth cable on the battery connection. Unlike the rest of Jap Car manufacturer which offer 2 ground/earth cables(1 to body & 1 to engine) battery connection.
Goodluck to those 6 years+ Honda city users, you will experience the symptom slow cranking during start up the engine due to cable oxidized(heat built up due to high resistance).
boxer07
Jun 12 2017, 08:56 PM
QUOTE(yhsiau @ Jun 12 2017, 08:54 PM) Looks like the battery power is weak... Button start type ignition won't allow to crank the engine if the battery power is weak/low. Unlike the key pushing ignition type(mechinical type), U can still attempt to crank even the battery power is weak/low. BTW, the Honda is farking stingy(should I say shitty cost down)... only 1 ground/earth cable on the battery connection. Unlike the rest of Jap Car manufacturer which offer 2 ground/earth cables(1 to body & 1 to engine) battery connection. Goodluck to those 6 years+ Honda city users, you will experience the symptom slow cranking during start up the engine due to cable oxidized(heat built up due to high resistance). the battery cable so expensive that 6yrs old Honda car owner not afford to replace ? LOL ...push start also can crank ,who tell u cannot crank ..? aiyo ...i tried before la..
yhsiau
Jun 12 2017, 09:01 PM
QUOTE(boxer07 @ Jun 12 2017, 08:56 PM) the battery cable so expensive that 6yrs old Honda car owner not afford to replace ? LOL ...push start also can crank ,who tell u cannot crank ..? aiyo ...i tried before la.. Why don't you go and look at other Jap brands car battery connections. It should be 2 cable connections on the negative pole. 1 to engine, 1 to body. Most of the car user never look into this til it caused problem on starting the engine. Some still experiencing slow cranking after replaced a new battery.
TSoks911
Jun 13 2017, 09:53 AM
QUOTE(yhsiau @ Jun 12 2017, 09:01 PM) Why don't you go and look at other Jap brands car battery connections. It should be 2 cable connections on the negative pole. 1 to engine, 1 to body. Most of the car user never look into this til it caused problem on starting the engine. Some still experiencing slow cranking after replaced a new battery. It can be Quite annoying if 1st attempt cranking failure. I can't imagine what will happen in coming 5 years.
