----------------> DIFFERENCE BETWEEN A3000 & A3003 <----------------
Much thanks darrenlam and MaUi^
A3000
Aspects
A3003
China / North America version
Region
EU / Asia (except China)
Supports all LTE bands for MY telco (EXCEPT for WEBE)
Band Support
Supports all LTE bands for MY telcos (INCLUDING WEBE)
AP warranty by local shop, not covered by Brightstar MY
Warranty
Official warranty by Brightstar MY
2-flat pin plug (China version)
Charger design
3-flat pin / 2-round pin plug (MY/EU version)
Hydrogen OS (but AP seller usually will flash it with Oxygen OS with Play Store)
Operating System
Oxygen OS
QUOTE(MaUi^ @ Aug 17 2016, 04:19 PM)
YES LTE and P1 LTE used a TDD-LTE band. Oneplus 3 A3000 model from North America are not supported TDD-LTE, only FDD-LTE (but with almost full band list). The A3000 China model and A3003 EU/Asia model support TDD-LTE on some band. Can check it below under the connectivity section :
Hi guys, if I get A3000, can I flash a ROM from XDA to change its OS to Oxygen OS? Any disadvantage that I should be concerned with A3000?
Most sellers would have flashed to oxygen os before selling you the phone. So basically there is no need to do anything on your part. But one seller did tell me that a3000 with flashed oxygen rom is a bit different from a3003 with stock oxygen rom.
So out of the box A3000 should be able to receive oxygen OS OTAs?
