Outline ·
[ Standard ] ·
Linear+
prime95 torture failed, need help pls!!
TSamduser
Jan 13 2007, 02:41 PM, updated 19y ago
» Click to show Spoiler - click again to hide... « AMD Athlon 64 Processor 3500+ CPU speed: 2320.73 MHz CPU features: RDTSC, CMOV, Prefetch, 3DNow!, MMX, SSE, SSE2 L1 cache size: 64 KB L2 cache size: 512 KB L1 cache line size: 64 bytes L2 cache line size: 64 bytes L1 TLBS: 32 L2 TLBS: 512 Prime95 32-bit version 24.14, RdtscTiming=1 Best time for 512K FFT length: 21.365 ms. Best time for 640K FFT length: 27.888 ms. [Sat Jan 13 13:24:57 2007] FATAL ERROR: Rounding was 0.474609375, expected less than 0.4 Hardware failure detected, consult stress.txt file. [Sat Jan 13 14:00:52 2007] FATAL ERROR: Rounding was 0.484375, expected less than 0.4 Hardware failure detected, consult stress.txt file. [Sat Jan 13 14:23:16 2007] FATAL ERROR: Rounding was 0.453125, expected less than 0.4 Hardware failure detected, consult stress.txt file. SPOILER]
This post has been edited by amduser: Jan 13 2007, 02:43 PM
TSamduser
Jan 13 2007, 02:42 PM
i get this result after 4-6mins of test, can anyone help me?? i didnt change anythings except for the graphic card memory MHz.
it say hardware failure detected, but my comp didnt restart, or come out any sound, i'm sure that my comp r not overheated
sorry for double post, coz me first time use spoiler.
EDIT: the task i'm running in background is flashget, bitcomet, ares, AVG, and on9.
This post has been edited by amduser: Jan 13 2007, 02:44 PM
newbieockids
Jan 13 2007, 03:03 PM
load optimize default in BIOS, save & exit, and re run the prime test.. tried yet?.. same result?..
This post has been edited by newbieockids: Jan 13 2007, 03:04 PM
TSamduser
Jan 13 2007, 03:16 PM
if optimized default all the things that i overclock be4 will be lost?
gengstapo
Jan 13 2007, 03:24 PM
QUOTE(amduser @ Jan 13 2007, 03:16 PM) if optimized default all the things that i overclock be4 will be lost? correct, it will run at default setup
TSamduser
Jan 13 2007, 03:29 PM
i optimized already, still running at same setup, ntg change also >.<
to gengstapo: can explain wat happen to my torture result? seems like some hardware hv failed, but when i plying games it gone so smooth and with extra gain in performance, but when i plying the NFSMW for a period of time(1-2hours, 2 blacklist)then gt pop-out error, ask me want to send error report or not, then my comp hang there, but when i ply other games, this wont happen
TSamduser
Jan 13 2007, 03:35 PM
[Sat Jan 13 15:33:58 2007] FATAL ERROR: Rounding was 0.5, expected less than 0.4 Hardware failure detected, consult stress.txt file. this is the result i get after i optimized default
gengstapo
Jan 13 2007, 03:44 PM
QUOTE(amduser @ Jan 13 2007, 03:29 PM) to gengstapo: can explain wat happen to my torture result? seems like some hardware hv failed, but when i plying games it gone so smooth and with extra gain in performance, but when i plying the NFSMW for a period of time(1-2hours, 2 blacklist)then gt pop-out error, ask me want to send error report or not, then my comp hang there, but when i ply other games, this wont happen im not expert here, but ive also experience sumthin' like that it shows when my overclock setup not stable in this case, when u run at stock setup it might be ur psu cant support all the hardware used in ur computer. try get a new psu with higher wattage
TSamduser
Jan 13 2007, 03:51 PM
if it is lack of watt, then my comp will be restart right? now my comp didnt restart, and i only OC my GPU core clock and CPU memory MHz only
davidletterboyz
Jan 13 2007, 03:52 PM
QUOTE(gengstapo @ Jan 13 2007, 03:44 PM) im not expert here, but ive also experience sumthin' like that it shows when my overclock setup not stable in this case, when u run at stock setup it might be ur psu cant support all the hardware used in ur computer. try get a new psu with higher wattage When i was using nf7, i got this kind of errors too. It wont hang or anything, it just wont pass prime2004 when i open another program. Fixed it by changing nvidia chipset drivers...took ages to find out haha. I dont know if this can help...but no harm trying  amduser, downclock ur graphics card back to stock speed la...just to eliminate one more factor. This post has been edited by davidletterboyz: Jan 13 2007, 03:53 PM
TSamduser
Jan 13 2007, 04:00 PM
QUOTE(davidletterboyz @ Jan 13 2007, 03:52 PM) amduser, downclock ur graphics card back to stock speed la...just to eliminate one more factor. ok, i try, but stock speed i cant ply at full effet, details and resolution already T_T
gengstapo
Jan 13 2007, 04:03 PM
QUOTE(amduser @ Jan 13 2007, 03:51 PM) if it is lack of watt, then my comp will be restart right? now my comp didnt restart, and i only OC my GPU core clock and CPU memory MHz only if u running those "light" apps, sure ur comp wont having a prob but when u running extra apps such prime95, it fail u hehee
TSamduser
Jan 13 2007, 04:08 PM
=.= if not enough power, sure my PC will restart lar, now i hv optimized my GPU and memory clock of my GC, i still can running game at high details and resolutions, maybe it is cause by i change the frame buffer size in the BIOS to 256k^^
now running the prime95 test, hope it will alright
This post has been edited by amduser: Jan 13 2007, 04:08 PM
TSamduser
Jan 13 2007, 04:18 PM
i hv run the test, still cannot, it still pop-out error
davidletterboyz
Jan 13 2007, 04:21 PM
QUOTE(amduser @ Jan 13 2007, 04:18 PM) i hv run the test, still cannot, it still pop-out error Means it's not the graphics card...
TSamduser
Jan 13 2007, 04:22 PM
any opinion on which hardware? i can sure that it's not overheated
davidletterboyz
Jan 13 2007, 04:26 PM
Not sure....but u can forget about o/cing since it's not stable even at stock speed.
Which prime2004 test u running? small FFT? blend? large fft?
TSamduser
Jan 13 2007, 04:41 PM
i run the test in blend
gengstapo
Jan 13 2007, 04:43 PM
have u update ur BIOS?
TSamduser
Jan 13 2007, 05:02 PM
nope, how to update? mmy PC BIOS is award module BIOS, wat is the use of updating BIOS?
sHawTY
Jan 13 2007, 05:12 PM
QUOTE(amduser @ Jan 13 2007, 05:02 PM) nope, how to update? mmy PC BIOS is award module BIOS, wat is the use of updating BIOS? To help solving some bugs that is in the older bios. To help the bios identifying new processors. To help cure a problem that is in the older bios.
TSamduser
Jan 13 2007, 05:49 PM
where to update?
sHawTY
Jan 13 2007, 07:25 PM
QUOTE(amduser @ Jan 13 2007, 05:49 PM) Go to you're motherboard manufacturer website liao... Example: If u're using Gigabyte motherboard, go to: http://www.gigabyte.com.twSearch for you're motherboard model there, find the bios updates, then flash it to the newest version...
haylui
Jan 13 2007, 07:37 PM
my suggestion is that to clean the hardware and then run the default BIOS setting and see. If cannot then do a BIOS flash. There are a lots of factors affecting your system. Try one by one, PSU might be the factor since I am using PowerLogic PSU. Under some circumstances the voltage shot up to a very high value or drop drastically.
gengstapo
Jan 13 2007, 08:04 PM
QUOTE(sHawTY @ Jan 13 2007, 05:12 PM) To help solving some bugs that is in the older bios. To help the bios identifying new processors. To help cure a problem that is in the older bios. QUOTE(sHawTY @ Jan 13 2007, 07:25 PM) Go to you're motherboard manufacturer website liao... Example: If u're using Gigabyte motherboard, go to: http://www.gigabyte.com.twSearch for you're motherboard model there, find the bios updates, then flash it to the newest version... hehee.. nice eh, hope TS will understand ps: to TS, what is ur psu? izzit the atrix?
