Could you all recommend video editing program for begginer to upload to youtube.com?
Many thanks
Video editing program, for beginners
Dec 27 2015, 05:06 PM, updated 10y ago
#1
1,984 posts Joined: Apr 2011 |
Many thanks |
Dec 31 2015, 05:42 PM
#2
3 posts Joined: Nov 2015 |
YouTube only supports two video formats including MP4 and FLV and there are some problem like the resolution might change, video length and other stuffs.I used to upload video to youtube by some video editor,maybe you can try search the keyword in google.
May 5 2016, 08:48 PM
#3
1,068 posts Joined: Oct 2012 |
May 6 2016, 06:59 PM
#4
5 posts Joined: May 2015 |
Windows Movie Maker
May 11 2016, 10:03 PM
#5
515 posts Joined: Jun 2010 From: SoME pLAcE |
May 12 2016, 12:28 PM
#6
Thank you very much to all.
Jun 5 2016, 09:15 AM
#7
VIP
1,271 posts Joined: Jan 2003 From: Terengganu |
Techsmith Camtasia Studio (https://www.techsmith.com/camtasia.html) worth to look into. Some of the feature:
I used it most of the time because of the feature, simplicity, drag & drop, not too technical & suit for most task. You can check lot of tutorial in the Youtube. Even after install it, it will show tutorial on how to use it. |
Jun 7 2016, 12:31 PM
#8
QUOTE(keyz @ Jun 5 2016, 09:15 AM) Techsmith Camtasia Studio (https://www.techsmith.com/camtasia.html) worth to look into. Some of the feature: Good...TQ
Jun 7 2016, 02:38 PM
#9
QUOTE(keyz @ Jun 5 2016, 09:15 AM) Techsmith Camtasia Studio (https://www.techsmith.com/camtasia.html) worth to look into. Some of the feature: Thank you
Feb 23 2017, 09:13 AM
44 posts Joined: Mar 2012 |
Windows Movie Maker is good enough for some basic video editing.
| Change to: | 0.0201sec
0.61
5 queries
GZIP Disabled
Time is now: 20th December 2025 - 01:42 PM |
