Outline ·
[ Standard ] ·
Linear+
FlashGet v1.81 Final
TSsuper macgyver
Dec 12 2006, 01:14 AM, updated 19y ago
Changes in FlashGet Version 1.80 (2006.12): New Feature for V1.80 1. To add the feature of Bundle Scanning, which is a creation in the world. 2. To optimize the download speed after 99% download Bug Fixed List for V1.80 1. To fix the bug of the crash of BHO with Vista 2003 Download FlashGet http://down5.flashget.com/fg180en.exeThis post has been edited by super macgyver: Jan 16 2007, 09:09 AM
rayfoo
Dec 12 2006, 06:50 AM
bundle scanning, wonder what's that?
SUSDavid83
Dec 12 2006, 12:00 PM
It's good to have a newer version. My previous v.173 got problems; hangs after download.
SUSDavid83
Dec 12 2006, 03:03 PM
Flashget has incorporated BT in the latest v1.8
2uk3y
Dec 12 2006, 10:38 PM
thanks 4 up2date
cybersim2
Dec 14 2006, 08:22 AM
Any spyware ?
brinkc
Dec 20 2006, 10:19 AM
QUOTE(David83 @ Dec 12 2006, 03:03 PM) Flashget has incorporated BT in the latest v1.8  i hate this too, very annoying~~ will switch back to 1.73 later.
SUSDavid83
Dec 21 2006, 07:47 PM
It's annoying and it overtook association from BitComet.
Kelv
Dec 21 2006, 09:18 PM
I'm using Flashget to download torrent stuff but very slow. Any idea?
SUSDavid83
Dec 21 2006, 10:49 PM
Try to tweak its default configuration for BT. I didn't use it for BT download.
Kelv
Dec 22 2006, 09:56 AM
Do I need to alter the 'Listen Port'? The value now is 25746. Last time I use BitLord to download torrent stuff and never tweak before.
brinkc
Dec 22 2006, 10:03 AM
although i disable Flashget to be a default BT Clients. but it will auto prompt for a new BT task when i download any .torrent files.
bloodsucker
Dec 22 2006, 02:13 PM
QUOTE(brinkc @ Dec 22 2006, 10:03 AM) although i disable Flashget to be a default BT Clients. but it will auto prompt for a new BT task when i download any .torrent files. 'force' windows to open .torrent files using your original BT client rather than FlashGet.
malayneum
Dec 22 2006, 05:17 PM
anyone know how to download more than 3 files at one time?
almostthere
Dec 22 2006, 05:21 PM
Kepala abah ko
QUOTE(malayneum @ Dec 22 2006, 05:17 PM) anyone know how to download more than 3 files at one time? isn't that configurable under options for maximum number of downloads?
SUSDavid83
Dec 22 2006, 11:28 PM
QUOTE(bloodsucker @ Dec 22 2006, 02:13 PM) 'force' windows to open .torrent files using your original BT client rather than FlashGet. Done but it's overtaken again by Flashget ...
brinkc
Dec 27 2006, 10:01 AM
QUOTE(bloodsucker @ Dec 22 2006, 02:13 PM) 'force' windows to open .torrent files using your original BT client rather than FlashGet. i cant make it works, my default BT Clients still BitComet, but if i use flashget to download any .torrent files then it will auto open the torrent file itself QUOTE(David83 @ Dec 22 2006, 11:28 PM) Done but it's overtaken again by Flashget ...  there is a options setting but i forgotten where, try search yourself in every flashget setting This post has been edited by brinkc: Dec 27 2006, 10:02 AM
wongzai
Dec 27 2006, 05:04 PM
how the performance of BT running in FG????
GameSky
Dec 27 2006, 05:07 PM
brinkc: Easy,
- Tools -> Options - Click on Other, scroll down, and untick "Associate FlashGet with .torrent files", then click ok "/
matt_rix
Dec 27 2006, 11:27 PM
anyone know how to set proxy in flashget??didnt work for me..still cant connect to server
