 (WTA) Fans Suggestion For Casing, CM690 III Green Chasis
TSAeonixG
post Sep 7 2015, 05:44 PM, updated 11y ago
Hi Forumers,
Kindly ask for suggestion for adding fans for my newly bought CM690 III Green Chasis, my intention was to build a green theme lighting rig.
But there's this Airflow category where there's Normal and Static Pressure type which i'm confuse about which fan i should install and how the air flow will go.
I also want to not that I haven't bought any air cooler for my processor yet as I'm planning to use the Intel stock cooler. (don't want to spend too much yet plus i dont do any overclocking)
I'm currently looking at CORSAIR AIR SERIES SP140 12CM LED CASING FAN & COOLER MASTER SICKLE FLOW X 12CM CASING FAN (Both Green)
Any opinion/suggestion are welcome smile.gif
SUSsupersound
post Sep 8 2015, 01:54 PM
10k Club
I won't really bother on pressure, more on air flow.
This casing can install 2 20 cm fan for extra flow. Moire important, it is a quiet fan.
Then you can install green LED strips to suit your taste.
Oyaji
post Sep 16 2015, 11:38 AM
QUOTE(AeonixG @ Sep 7 2015, 05:44 PM)
Hi Forumers,
Since we have similar case, this is what I would do:
-keep the 20cm at the front of the case
-put a pair of 140mm fans on top. If it can be mounted with 120mm fan holes then I put 2 on top, one at the back. I prefer prolimatech usv 14 for this setup.
-one fdb or ball bearing fan at the bottom
all of those fans must be in black
lastly get those green led strips
as for the fans ur listed, I would get the sickle flow x over the SP LEDs due to the corsairs LED used sleeve bearings, not advisable to put on top of casings.
TSAeonixG
post Sep 16 2015, 09:08 PM
QUOTE(Oyaji @ Sep 16 2015, 11:38 AM)
haha, I've already build up my rig 2 days ago. This is how it all looks;
P.S. I added 2 Bitfenix LED Fan on top and one LED strip at the bottom
Oyaji
post Sep 17 2015, 06:01 AM
QUOTE(AeonixG @ Sep 16 2015, 09:08 PM)
I assume u put 120mm bitfenix on top. Do you have any trouble mounting it on top using metal screws? I got trouble mounting my turbinemaster with rubber screws. Must be the diameter is too short.
TSAeonixG
post Sep 17 2015, 08:40 PM
QUOTE(Oyaji @ Sep 17 2015, 06:01 AM)
Actually, I mounted 2 Bitfenix 140mm on top instead. No trouble mounting, just need to screw harder brows.gif
Oyaji
post Sep 18 2015, 04:39 AM
QUOTE(AeonixG @ Sep 17 2015, 08:40 PM)
maybe if it isn't too much for you, maybe you could post a pic of those fans mounted on top of the case with the cover open. Just want to see how it look like lol.
TSAeonixG
post Sep 21 2015, 10:31 AM
QUOTE(Oyaji @ Sep 18 2015, 04:39 AM)
0.0199sec    0.42    5 queries    GZIP Disabled
Time is now: 20th December 2025 - 07:49 AM
